PFMEA for manufacturing - Please review my Process FMEA
Annette
Historically, our company has created the PFMEA's listing every dimension on a print. We do not get the DFMEA from our customers, yet we are very vague with the failure mode. They have passed PPAP submissions to the Big Three, but I don't feel that there are correct. I am looking for some advice as to how they should be addressed.
Thanks,
Caster
An Early Cover
Some quick thoughts
Annette said:
Historically, our company has created the PFMEA's listing every dimension on a print. We do not get the DFMEA from our customers, yet we are very vague with the failure mode. They have passed PPAP submissions to the Big Three, but I don't feel that there are correct. I am looking for some advice as to how they should be addressed.Thanks,
Hi Annette
I have no doubt that the Big 3 accept this as is. However, someday you may get a knowledgeable SQE or auditor. It happened to us and we are still trying to get an acceptable FMEA together.
I see very low RPNs, can you defend these numbers with data? Or are they set low so no action is needed? Hey - we do it.
On that point, there is not a single improvement activity arising from the FMEA. Are your PPMs zero? If you ever had a return, the FMEA should have been reviewed and revised. What is the point of FMEA? There should be some improvement actions IMHO.
Finally this is a PART FMEA, not a Process FMEA. Machines make dimensions, where are the speeds, feeds, coolant, CNC programs, tool break detectors, first offs, etc?
Where are the move operations (do you get handling damange?)
We got hammered on our last audit for this same thing. Part focused, not process focused.
Ford has a really detailed FMEA handbook if you have access to their supplier portal.
All this said, it may be a tough sell tying to improve on this if the customer already buys it. Good luck, I'm keen to see what others have to say.
Helmut Jilling
Auditor / Consultant
I agree with Castor
I agree with Castor's comments. Also, the date on this FMEA is 2003. Any revisions should include bringing the scoring into the range the 3rd ed. sets forth. Most Big 3 customer SQE's require it nowadays.
To get a Detection of 3 would require everything to be error-proofed. Not very likely, I assume.
Bill Ryan - 2007
This is the methodology we use and I will argue that Annette's PFMEA does address the Process. I agree with you that it probably needs more depth in regards to the Potential Causes (as you listed), but when carried over to the Control Plan, the Causes will/should show up in the Process Characteristics column - which is where they belong. The Failure Modes will/should show up in the Product Characteristics column - which is where they belong. I've gone through too many excersizes with arguments (read: wastes of time) on whether something is a Mode or a Cause and this methodology (Mode=measureable on the product and Cause= measureable in the process) certainly gets that out of the way.
I also concur that ratings appear to be a little on the low side and all processing steps/actions don't appear to be detailed.
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
O PFMEA - Reducing Severity (S) Ranking - Manufacturing Process Design Changes FMEA and Control Plans 4
N PFMEA for Non-Manufacturing Processes such as audits, direct procurement, etc. FMEA and Control Plans 5
G Manufacturing -> Warehouse -> Tier 1/OEM - Process flow, PFMEA, & Control Plan FMEA and Control Plans 9
P Is PFMEA for Manufacturing and Assembly Processes Only? FMEA and Control Plans 11
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A PFMEA severity score different applications FMEA and Control Plans 11
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
M I need a sample Reverse PFMEA Process Checklist FMEA and Control Plans 2
C PFMEA example with machining (lathe+mill) FMEA and Control Plans 1
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
B Proactive efforts to reduce risk - PFMEA risk reduction activities IATF 16949 - Automotive Quality Systems Standard 8
N PFMEA no effect ratings FMEA and Control Plans 15
N DFMEA, Drawings and PFMEA of an Assembly Process FMEA and Control Plans 12
A PFMEA for DC Motor FMEA and Control Plans 5
