PFMEA for many products - How to reduce the number of FMEAs?
Joe_winter
#11
Cokyat,that is an enjoyness to read your words.ripple effect? yes, that is agreeable.
Best regards!
s-bell
#12
astudent said:
I know little about FMEA. Hope someone can help me.
If I have, say, 100 product and each of them has his own bill of materials (for ex. on the average 10 items per product), how many PFMEA have I to write?
Looking at your problem another way, take a step back and consider the following.
What has happened that you now need to prepare PFMEA's for your existing processes? Are you planning for TS accreditation? What benefit will completing the FMEA’s in retrospect give you?
In my opinion their are two options available to you.
1) Review your processes and determine families for legacy / generic FMEA's based on similar processes (i.e. injection moulding, progression stamping, spot welding). Create the generics then refer to the generics where required from product specific FMEA's
For unique assembly / manufacturing processes you would still need to prepare a specific PFMEA.
2) Place a line in the sand with your current processes and determine that new products and processes entering the factory be subject to D/PFMEA. For your existing products you could perform mini PFMEA reviews based upon future customer and internal concerns. This would mean that you are reviewing the process in an FMEA format but as more of a corrective than preventative action. However the information you get could be used to help new projects. If you are looking for accreditation your registrar may be able to clarify if he would accept this approach. My opinion is that most are OK with it.
At this moment in time you should know the issues with your products and processes and therefore the PFMEA is an “after the event” exercise and may not prove an efficient use of time.
I would consider option 2 above, but at the same time look to develop generic FMEA’s based upon common manufacturing processes. IMHO I would always look to have an FMEA for each product but refer to a generic. This way you save work in document creation but can review product specific concerns against a specific FMEA.
I hope this is of some help.
Marc
#14
MikeL said:
One of my clients make auto batteries.
We have one set of FMEA's that cover the hundred or so different products because the basic processes are the same.
Where one battery is quite different from the others we make up a separate addendum page that looks at the different risks. same with PCP's.
much easier where you want to make an improvement. Only have to change one FMEA/PCP
Yuppers! 'Common Sense' with respect to families of parts. Do NOT over complicate the requirements (or their intent)!!!
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A PFMEA severity score different applications FMEA and Control Plans 11
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
M I need a sample Reverse PFMEA Process Checklist FMEA and Control Plans 2
C PFMEA example with machining (lathe+mill) FMEA and Control Plans 1
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
B Proactive efforts to reduce risk - PFMEA risk reduction activities IATF 16949 - Automotive Quality Systems Standard 8
N PFMEA no effect ratings FMEA and Control Plans 15
N DFMEA, Drawings and PFMEA of an Assembly Process FMEA and Control Plans 12
A PFMEA for DC Motor FMEA and Control Plans 5
Crimpshrine13 PFMEA Scope - Oversized Special Characteristic FMEA and Control Plans 4
B PFMEA and Control Plan Links APQP and PPAP 2
B Update our PFMEA after Supplier updates their PFMEA? FMEA and Control Plans 4
Q PFMEA Scope and Detection Controls FMEA and Control Plans 1
