PFMEA for Phosphating Process
bhartigambhir
We are preparing the PFMEA for our one product in which phosphating is recommanded. We don't know anything about phosphating. Can anyone help me or give some example of Phosphating Failure Mode.
I assume that you are outsorcing this part of the process, then? If so, I suggest that you enlist the help of the supplier for this part of your FMEA.
Well, for starters: How about phosphating layer too thin, too thick, uneven or not covering the entire surface?
/Claes
bobdoering
Stop X-bar/R Madness!!
There is also crystal size (too large/too small) and poor adhesion.
Absolutely! (...although difficult to measure without SEM). Also, control of the bath chemistry, BUT equally important - if not more so - is control of the washes and rinses prior to the phosphating!!
I second Claes' advice to work with the supplier on this. What you need to do, if you're unfamiliar with the process, is consider the reasons for the coating (corrosion resistance, lubrication, providing a base for paint, etc.) and determine the potential failure modes of the supplier's process that could affect design intent.
David DeLong
I would suggest that your supplier create the process FMEA since it is their process. They own it and your company doesn't. You can contribute with failure modes from a customer perspective but the process changes, controls, etc. are a supplier's responsibility.
If they don't know how to create an process FMEA, it would be mutually beneficial that you participate in their initial FMEA but with more of a training perspective.
If you continued to develop a process FMEA on your own, it would be more customer show than value.
bobdoering
Might want to share the DFMEA criteria. What is the point of the phosphate? Pass through SC's.
bhartigambhir
Thanks, everyone for your valuable suggestion. Actually I had asked to our supplier also but they are on very small level so they told me where they fails but in technical langauage want to know what are the failures normally have this process
P
prototyper
What type of phosphating process do your supplier use? Is it a dip process or a spray process? The failure modes are slightly different.
Also, it may help to think of the effects that could be seen in the finished coating then work backwards.
Consider poor corrosion resistance and poor adhesion. Ask your supplier what phosphate condition could lead to this, what in their process could cause this and what controls they have in place for each failure mode they suggest.
PFMEA should be a collaboration of expert opinion. Your suppliers are the expert in the phosphating process, but if they are not familiar with PFMEA it will be down to you to ask the appropriate questions to get the necessary information out of them.
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A PFMEA severity score different applications FMEA and Control Plans 11
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
M I need a sample Reverse PFMEA Process Checklist FMEA and Control Plans 2
C PFMEA example with machining (lathe+mill) FMEA and Control Plans 1
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
B Proactive efforts to reduce risk - PFMEA risk reduction activities IATF 16949 - Automotive Quality Systems Standard 8
N PFMEA no effect ratings FMEA and Control Plans 15
N DFMEA, Drawings and PFMEA of an Assembly Process FMEA and Control Plans 12
A PFMEA for DC Motor FMEA and Control Plans 5
Crimpshrine13 PFMEA Scope - Oversized Special Characteristic FMEA and Control Plans 4
B PFMEA and Control Plan Links APQP and PPAP 2
B Update our PFMEA after Supplier updates their PFMEA? FMEA and Control Plans 4
Q PFMEA Scope and Detection Controls FMEA and Control Plans 1
