PFMEA - Is having the DFMEA An Absolute Requirement when doing a PFMEA
shallowmike
#11
Design FMEA
Help,
We are currently producing several ppaps and have a requirement to supply design fmeas. This is new to us to what depth do you go when producing this type of document with regards to press tools. We have been unable to get hold of an example to guid us through this. Can anyone help ta.
Shallow Mike
#12
shallowmike said:
Help,
Shallow Mike
It would help if you told us what type of work is involved, and what a "press tool" is.
Bill Ryan - 2007
#13
There are different "types" of FMEAs that I've seen - Concept, System, Design, Process, Machine, Service, etc. The AIAG PPAP manual's definition of Design FMEA to be supplied with PPAP is "parts or materials for which they (supplier - my insertion) are design-responsible" (sect I.2.2.4). You may be dealing with a Customer Specific Requirement, but I have not had to supply anything other than a PFMEA with any PPAPs.
Our die cast machines (as their own entities) are nothing other than "big presses". Could your customer be asking for a Machine FMEA by chance? I know we haven't addressed your immediate question - but we'll get there with a little more info.
W
wslabey
#14
Dfmea
No, a DFMEA is not required, but it sure makes the PFMEA easier since it identifies the signficant and critical characteristics (that should also be on the drawing). Concept - System - Component and Part DFMEAs are possible. I push my customers for a copy of the DFMEA. They are usually system level DFMEAs. I have never received a component or part DFMEA.
shallowmike
#15
Dfmea
Basically when we receive an order to supply a pressed component we may also have to design and build a progression press tool to stamp the piece part as part of our production process. A requirement of ppap at level 3 is to supply a press tool DFMEA to show that the tool is capable of meeting the customers requirements. Or so we are lead to believe.If this is the case, do we as suppliers decide on the depth of the DFMEA, ie do we have to take each pilot pin, punch and die forming stages which can amount to a lot of stages in a large press tool, and do the numbers? As well as this there is the question of the design itself surely by producing this document we are potentially giving away a lot of design info and at the end of the day who owns this confidential information? We as a company do not design the component part but in some cases do design the tool that produces that part and which forms part of the overall production process. I hope this gives more of an insight and look forward to some possible suggestions guys
Shallowmike
Manix
Get Involved!!!
#16
Just a quicky to say I have just had this scenario this week.
We are tier 2 on this project and the Tier 1 asked to review our PFMEA. They said they would get the customer DFMEA so we may do the PFMEA but alas, NO DFMEA has ever materialised.
Howard Atkins
Forum Administrator
#17
And probably never will. :mad:
This is an almost impossible document to receive
Bill Ryan - 2007
#18
It is not a requirement of PPAP level 3 to supply a DFMEA unless you are part design responsible (at least in AIAG's eyes). A DFMEA will not show that the tool is "capable" of anything. There is also no requirement that, should you give them a DFMEA, you must disclose anything proprietary.
Given that, if your customer is still demanding a DFMEA - yes you decide the "depth" to take it to. The excercise may be beneficial to your company so you could, possibly, end up with a "customer copy" on a more superficial level. I don't have a lot of practice with the DFMEA methodology but we do have some Covers that do - so please post any specific questions you have and hopefully someone will be able to help (you'll probably even get some of my "book learning" answers too :rolleyes: )
The Taz!
#20
I feel that a Design FMEA's biggest benifit is to the supplier not the customer. . . the Design (and System) FMEA start the control process and give meaning and purpose to the lower level documents and controls instituted in process; PFMEA, Machine FMEA, PCP, Work Instructions, Inspection Instructions, etc.
This is a risk minimization trickle down function (Say that fast three times). As I stated in an earlier post, rarely will a customer give the supplier their DFMEA, but they will usually pass down significant and critical characteristics from FMEA's (their or their customer's).
Not necessary, but a great starting point. Without it, you are usually relying on Tribal Knowledge to determine what to control, how and to what degree.
:soap:
L Core Tools - PFMEA - Not having the word ''NONE'' in Recommended Actions FMEA and Control Plans 10
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A PFMEA severity score different applications FMEA and Control Plans 11
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
M I need a sample Reverse PFMEA Process Checklist FMEA and Control Plans 2
C PFMEA example with machining (lathe+mill) FMEA and Control Plans 1
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
B Proactive efforts to reduce risk - PFMEA risk reduction activities IATF 16949 - Automotive Quality Systems Standard 8
N PFMEA no effect ratings FMEA and Control Plans 15
N DFMEA, Drawings and PFMEA of an Assembly Process FMEA and Control Plans 12
A PFMEA for DC Motor FMEA and Control Plans 5
Crimpshrine13 PFMEA Scope - Oversized Special Characteristic FMEA and Control Plans 4
B PFMEA and Control Plan Links APQP and PPAP 2
B Update our PFMEA after Supplier updates their PFMEA? FMEA and Control Plans 4
