PFMEA no effect ratings
N
nitros1
Can I put a failure mode with classification 1 or No Effect for all its categories?
Customer - No effect
Assembly plant - No effect
Final User - No effect.
Even though is a failure mode, can an auditor ask why is then included in the PFMEA?
Thanks.
Golfman25
What kind of failure has "no effect?" Seems by definition it would have to effect something, no?
N
nitros1
well according to the official severity table of that company there is such category.
Marc
Fully vaccinated are you?
Is this from the AIAG FMEA manual table?
I don't have a manual available to look at (well, I may but it would be archived in my barn).
What we really need is an example of a failure mode which has no effect(s) from you.
What good is a function that has no effect when it fails?
Jean_B
The reasons for including a failure mode where there is no effect usually have more to do with the system around risk management than with the risk itself (which could be neglible and thus eligible for exclusion of consideration in some cases).
I can still imagine multiple entry scenarios for such a case:
1. The risk had to be listed to show it has been considered (possibly due to a previous auditor requiring inclusion into the file due to observation of the failure mode in actuality (or fantasy)), even when its effect is deemed to be zero by the organisation.
2. The FMEA has led the risk to be controlled (designed out if it is severity), with the team deeming there to no longer being an effect, but entering it into the original severity column (or only using a single column approach).
3. There is a checklist approach for risks which need to be entered, but due to the scope or subject of the FMEA, it could never come to fruition. Result: lowest classification you can give.
4. There is no clear linkage of failure modes in the foreseeable sequence of events, thus a failure mode may occur for the process but the chain breaks before you get to customer/end user or the part of the assembly plant which relies on it.
5. Inexperienced Risk Management Team makes entry in illogical manner. What it says is not what they mean, or system cannot accomodate what they mean.​
Currently we have only severities assigned. Expanding it to the failure mode itself, the entire row of information on the risk, the full risk management system it came from and eventually the actual product and company is needed to give further advice.
N
nitros1
Well as an example I encountere, a faliure mode like this : missing parts in the box in the packaging station. Such failure mode would have absolutely no effect on the final customer if we as tier 1 sell it to the vendor first.
So what do you guys think about my first question??
tazer
I think this is more a confusion between FMEA and risk management.
From my experience several manufacturers confuse the two. As a result, I often find lines from a (hazardous) situations that does not cause any damage to the patient, the user or the environment. Those should not be included in the risk analysis list but should, if necessary, be addressed in the FMEA process.
For my part, the AMDEC is a tool for doing the risk analyzis but is not the risk analysis.
Typically the case of forgetting a component in the box must be dealt with in the FMEA and give rise to a CAPA outside the risk management process.
PS: I like the answer of Jean_B
Marc
Well as an example I encountere, a faliure mode like this : missing parts in the box <snip>
Missing parts in the box makes it close to impossible for a consumer to assemble, and in the case of a manufacturer can shut down a line.
These are not "minor" issues. There is a definite effect on the final customer when parts are missing.
:2cents:
J PFMEA in relation to suppliers FMEA and Control Plans 7
N PFMEA for rework, disassembly (automotive). FMEA and Control Plans 7
Q Definitions of Function in PFMEA ISO 14971 - Medical Device Risk Management 2
A PFMEA detection for "none" FMEA and Control Plans 5
Q Risk Controls in PFMEA ISO 14971 - Medical Device Risk Management 12
M When is the Best Time to Initiate PFMEA? ISO 13485:2016 - Medical Device Quality Management Systems 11
O Process Flow Diagram, DFMEA, PFMEA, Control Plan integrated softwares FMEA and Control Plans 7
R Installation Activities in pFMEA? FMEA and Control Plans 4
D PFMEA IATF 16949 - Automotive Quality Systems Standard 5
N Must PFMEA Occurrence Factor be Changed Periodically? FMEA and Control Plans 17
A PFMEA - Minor Non-Conformance for field left blank IATF 16949 - Automotive Quality Systems Standard 56
M PFMEA bending of steel tube FMEA and Control Plans 11
I IEC 60812 or ISO 14971 for PFMEA? What should we use? ISO 14971 - Medical Device Risk Management 3
J PFMEA severity with no knowledge of operating conditions FMEA and Control Plans 3
T PFMEA vs MFMEA or DFMEA on equipment/machinery FMEA and Control Plans 19
C Inspection Operation in PFMEA FMEA and Control Plans 13
J PFMEA/control plan question- PLEASE HELP ! IATF 16949 - Automotive Quality Systems Standard 8
C Pass through characteristics on PFMEA FMEA and Control Plans 3
S Initial PFMEA FMEA and Control Plans 6
L PFMEA for test procedures (ISO 14971) ISO 14971 - Medical Device Risk Management 5
K PFMEA Severity (9-1) mitigation needed? FMEA and Control Plans 20
Sonja D AIAG VDA PFMEA and Control Plan training FMEA and Control Plans 9
J Error Proofing sensors in PFMEA FMEA and Control Plans 2
DuncanGibbons Process flow & PFMEA for production planning and simulation activities? Process Maps, Process Mapping and Turtle Diagrams 9
D PFMEA Software search Quality Assurance and Compliance Software Tools and Solutions 8
P Benefit risk analysis on pFMEA ISO 14971 - Medical Device Risk Management 10
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 10
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 28
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
karinca PFMEA (Process FMEA) - Can be common for 3000 products? FMEA and Control Plans 2
