Hello
I have a doubts about step 2 and step 3 on the first 2 column.
My company makes Springs, and the customer asked me a PFMEA following AIAG VDA
From what i understood, in the step 2, in the first column (Process Item name) you have to write the final product of your process flow (eg. SPRING) and in the second column (Process step name) the name of process step on the process flow (incoming inspection of raw material)
Example below:
Step 2: Structure Analysis
Process Item name or name of process: Spring process
Process step name: incoming inspection of raw material
Step 3: Function Analysis
Function of the process item: Make the spring within defined cycle time and respecting the quality
Function of the process step: Ensure that the incoming material respects the internal quality standards
another example of my process:
Process step name: Profiling Process
Function of the process step: Make the profile of Spring
So in the end:
1- the column "Process Item name or name of process" will be always the same
2- the column "Process step name" will be the name of the name of process step on the process flow
3- the column "Function of the process item" will be always the same
4- the column "Function of the process step" will be the function of process step on the process flow
Is that right?
Example below:
So in the end:
Is that right?
