PFMEA Potential Failure Mode for Weight
N
nguyentoan
At column Potential Failure Molde we only consider Failure of quality or all (ex: include delivery in time, not enough material weight) ?
EX: at Material Incoming process we need consider failure mode is not enough material weight or not?
Marc
Fully vaccinated are you?
I believe there is a language issue. Are you asking if a process FMEA should address receiving inspection of raw materials?
N
nguyentoan
No.
I want to ask at process Material Incoming
Potential Failure mode is "Delivery not in time" it is OK or not?
I mean at potential failure mode we only consider quality failure or all failure (ex: Delivery not in time (not related quality problem))
Marc
Delivery "not in time" has long been a potential failure mode, and is often very critical for many reasons. Just consider the JIT (just in time) "system". I have seen entire lines go down because of a failure to get parts, or to get a lot of bad parts.
Delivery time is part of quality whether you realize it or not.
ScottK
Not out of the crisis
Kind of depends on how you frame your PFMEA.... if it's strictly risk of product failure then it probably doesn't need to be on there.
If you are looking at risk of failure in the overall process (which can impact delivery to customers) then it should.
Ron Rompen
A good PFMEA addresses ANY issue which can impact the customer, including delivery issues, quality issues, etc.
Basically, anything you do to make the part and ship it to your customer should be on the PFMEA. If you ship to your customer, be sure you know and understand who is responsible for the parts from the time they leave YOUR dock until the time they arrive at the customers facility. Although most plants ship 'FOB our dock' or 'ex works' this is not always the case, and if not, then you need to consider possible failures in the transportation chain as well.
Ron Rompen Wording of potential cause of failure in a PFMEA FMEA and Control Plans 8
M PFMEA (Process FMEA - Potential Causes and Failure) - Operator's Role FMEA and Control Plans 11
K Developing a PFMEA - Confused about Potential Failure modes FMEA and Control Plans 7
J PFMEA in relation to suppliers FMEA and Control Plans 7
N PFMEA for rework, disassembly (automotive). FMEA and Control Plans 7
Q Definitions of Function in PFMEA ISO 14971 - Medical Device Risk Management 2
A PFMEA detection for "none" FMEA and Control Plans 5
Q Risk Controls in PFMEA ISO 14971 - Medical Device Risk Management 12
M When is the Best Time to Initiate PFMEA? ISO 13485:2016 - Medical Device Quality Management Systems 11
O Process Flow Diagram, DFMEA, PFMEA, Control Plan integrated softwares FMEA and Control Plans 7
R Installation Activities in pFMEA? FMEA and Control Plans 4
D PFMEA IATF 16949 - Automotive Quality Systems Standard 5
N Must PFMEA Occurrence Factor be Changed Periodically? FMEA and Control Plans 17
A PFMEA - Minor Non-Conformance for field left blank IATF 16949 - Automotive Quality Systems Standard 56
M PFMEA bending of steel tube FMEA and Control Plans 11
I IEC 60812 or ISO 14971 for PFMEA? What should we use? ISO 14971 - Medical Device Risk Management 3
J PFMEA severity with no knowledge of operating conditions FMEA and Control Plans 3
T PFMEA vs MFMEA or DFMEA on equipment/machinery FMEA and Control Plans 19
C Inspection Operation in PFMEA FMEA and Control Plans 13
J PFMEA/control plan question- PLEASE HELP ! IATF 16949 - Automotive Quality Systems Standard 8
C Pass through characteristics on PFMEA FMEA and Control Plans 3
S Initial PFMEA FMEA and Control Plans 6
L PFMEA for test procedures (ISO 14971) ISO 14971 - Medical Device Risk Management 5
K PFMEA Severity (9-1) mitigation needed? FMEA and Control Plans 20
Sonja D AIAG VDA PFMEA and Control Plan training FMEA and Control Plans 9
J Error Proofing sensors in PFMEA FMEA and Control Plans 2
DuncanGibbons Process flow & PFMEA for production planning and simulation activities? Process Maps, Process Mapping and Turtle Diagrams 9
D PFMEA Software search Quality Assurance and Compliance Software Tools and Solutions 8
P Benefit risk analysis on pFMEA ISO 14971 - Medical Device Risk Management 10
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 10
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 28
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
