Pfmea (Process FMEA) at Process Audit
stevenlee
Dear all,
I have a question with the PFMEA.Does the in process audit must be analysis in PFMEA ?? can we have that as a process?
Thanks,
Steven
Re: Pfmea at process audit
Are you asking whether the in-process 'quality' audit should be included as an item in the PFMEA?
If so, quality audits are typically looked at as one of the controls for the other process items. If there is some chance that the audit could have a detrimental impact on the quality, include it. Otherwise, the only failure modes typically associated with inspection are:
  • Reject a good product
  • Accept a bad product
  • Fail to follow procedure for nonconforming product
I'd add one more item to the list--failure to properly identify inspection status when the inspection is finished.
G
gholland
Your risk control measures have to be verified to be effective. If they are not effective or you don't verify them then you can't use them to reduce your RPN numbers. The inspection itself isn't part of your 'process' that you are evaluating but you do need to run some sort of verification that your in process inspection is effective in detecting the failure you are looking for. This verification would be referenced in the pFMEA.
R Is PFMEA (Process FMEA) for OEM sufficient to address Risk? ISO 13485:2016 - Medical Device Quality Management Systems 7
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
R PFMEA (process FMEA) for Incoming Material stage FMEA and Control Plans 7
P PFMEA (Process FMEA) Recommended Actions help FMEA and Control Plans 9
G Very Basic PFMEA (Process FMEA) Guidelines FMEA and Control Plans 17
M PFMEA (Process FMEA) - What is the best approach? FMEA and Control Plans 14
M PFMEA (Process FMEA) for Attribute Data Inspection Process FMEA and Control Plans 2
T PFMEA (Process FMEA) Recommended Actions Column FMEA and Control Plans 10
B Process FMEA (PFMEA) Same Multiple Causes for Different Effects FMEA and Control Plans 6
M Changing PFMEA (Process FMEA) RPN Values based on a Rejection FMEA and Control Plans 5
Q Using a Custom Process FMEA (PFMEA) Form FMEA and Control Plans 4
D PFMEA (Process FMEA) Process and Rankings (S-O-D) Document Control Systems, Procedures, Forms and Templates 8
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
L PFMEA (Process FMEA) Forms - Dyadem FMEA Software Products FMEA and Control Plans 5
L Rotational Molding and Machining PFMEA (Process FMEA) - Plastics - example wanted FMEA and Control Plans 6
Chennaiite PFMEA (Process FMEA) for Vehicle Assembly wanted FMEA and Control Plans 4
H How to perform interesting PFMEA (Process FMEA) Training Training - Internal, External, Online and Distance Learning 6
M PFMEA (Process FMEA - Potential Causes and Failure) - Operator's Role FMEA and Control Plans 11
5 Changes to Control Plans or PFMEA's (Process FMEA) FMEA and Control Plans 6
P PFMEA (Process FMEA) Acceptable Effectivity Rate for Reoccurances of Issues FMEA and Control Plans 1
T DFMEA (Design FMEA) - We already have a PFMEA (Process FMEA) FMEA and Control Plans 5
D Laser Welding PFMEA (Process FMEA) - Metal FMEA and Control Plans 14
Casana Detection level in PFMEA (Process FMEA) - Bulk Fluids FMEA and Control Plans 10
P Problem with "failure mode? interpretation in PFMEA (Process FMEA) FMEA and Control Plans 8
R Addressing Inspection in PFMEA (Process FMEA) FMEA and Control Plans 2
J When to Update PFMEA (Process FMEA) - Rejection is found at the customer FMEA and Control Plans 12
V Integrating the FMEA process with problem investigation/RCA process and PFMEA FMEA and Control Plans 4
C DFMEA (Design FMEA) and PFMEA (Process FMEA) - Who should lead? FMEA and Control Plans 14
C PFMEA (Process FMEA) Detection Scale - Aerospace engine components FMEA and Control Plans 4
H How to Make PFMEA (Process FMEA) from the beginning to the end FMEA and Control Plans 4
H Corrective Action: When to update the Process FMEA (PFMEA) FMEA and Control Plans 15
M Process FMEA (PFMEA) Assumptions Regarding Causes Identification FMEA and Control Plans 6
M Process FMEA (PFMEA) for D.C. Welding of Sheet Metal Parts - Electrode Material FMEA and Control Plans 1
N How to Calculate RPN in Design FMEA (DFMEA) vs. Process FMEA (PFMEA) FMEA and Control Plans 9
J When to update a PFMEA (Process FMEA) FMEA and Control Plans 17
S Detection Criteria Examples - PFMEA (Process FMEA) - Emergency Safety Fixtures FMEA and Control Plans 2
E PFMEA (Process FMEA) Class Symbols FMEA and Control Plans 6
Kales Veggie Informational How to develop a Control Plan from a PFMEA (Process FMEA) FMEA and Control Plans 61
kedarg6500 Supplier PFMEA (Process FMEA) Audit Form FMEA and Control Plans 4
Y Process FMEA (PFMEA) vs. Equipment FMEA (EFMEA) Differences FMEA and Control Plans 15
J Updating a PFMEA (Process FMEA) after a Process Failure FMEA and Control Plans 3
J The real Link between a PFMEA (Process FMEA) and the Control Plan FMEA and Control Plans 19
W Actual examples of FMEA (DFMEA, PFMEA) for Car Assembly Process IATF 16949 - Automotive Quality Systems Standard 5
L PFMEA (Process FMEA) issue about lower RPN - AIAG 3rd edition page 55 FMEA and Control Plans 13
M Connections between PFMEA (Process FMEA) and the Control Plan. FMEA and Control Plans 20
M PFMEA Severity - What is Process FMEA Severity estimation based on? FMEA and Control Plans 77
K Change in Occurrence for Low Volume Assembly Process FMEA (PFMEA) FMEA and Control Plans 8
M Include Risk of Rework in a PFMEA (Process FMEA)? FMEA and Control Plans 5
