PFMEA (Process FMEA) - Can be common for 3000 products?
Hello all,
We're producing plastic injection parts (nearly 3000 different types of products) and it's impossible to track their PFMEA and Control plan. So, I'd like to know if it's possible to make a common PFMEA for every step of process, such as;
1. Receiving Inspection FMEA
2. Material Preparation FMEA​
3. Injection Process FMEA​
4. Felt Assembly FMEA​
5. Screw Tightening FMEA​
..etc.​
I know that it'll be impossible to implement all C/M that we take in PFMEAs to all related products but at the end FMEA is also a database for the failure modes of process.
Do you know that if it's allowed by IATF certificated bodies to make a generic FMEA like I indicate above?
Thank you,
Golfman25
We had the same problem - make 2500 metal parts. After several attempts we settled on a "universal" fema that covers everything. We keep that updated and current. When we need one for a specific part we cut and paste from the master. Once that specific Fmea is printed it is essentially "obsolete" as all updates are done to the master. So far so good, it works for us.
GRP
Hello all,
..etc.​
Thank you,
My reading of the IATF standard is that it does not go into details of PFMEA, but it states that the control plan shall show linkage to- and incorporate information from the PFMEA.
If you look at AIAG, SAE and at least one major OEM, it is acceptable to use family fmeas, check FMEA/DCP Structure and Quantity - Similar Parts and Processes
R Is PFMEA (Process FMEA) for OEM sufficient to address Risk? ISO 13485:2016 - Medical Device Quality Management Systems 7
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
R PFMEA (process FMEA) for Incoming Material stage FMEA and Control Plans 7
P PFMEA (Process FMEA) Recommended Actions help FMEA and Control Plans 9
G Very Basic PFMEA (Process FMEA) Guidelines FMEA and Control Plans 17
M PFMEA (Process FMEA) - What is the best approach? FMEA and Control Plans 14
M PFMEA (Process FMEA) for Attribute Data Inspection Process FMEA and Control Plans 2
T PFMEA (Process FMEA) Recommended Actions Column FMEA and Control Plans 10
B Process FMEA (PFMEA) Same Multiple Causes for Different Effects FMEA and Control Plans 6
M Changing PFMEA (Process FMEA) RPN Values based on a Rejection FMEA and Control Plans 5
Q Using a Custom Process FMEA (PFMEA) Form FMEA and Control Plans 4
D PFMEA (Process FMEA) Process and Rankings (S-O-D) Document Control Systems, Procedures, Forms and Templates 8
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
L PFMEA (Process FMEA) Forms - Dyadem FMEA Software Products FMEA and Control Plans 5
L Rotational Molding and Machining PFMEA (Process FMEA) - Plastics - example wanted FMEA and Control Plans 6
Chennaiite PFMEA (Process FMEA) for Vehicle Assembly wanted FMEA and Control Plans 4
H How to perform interesting PFMEA (Process FMEA) Training Training - Internal, External, Online and Distance Learning 6
M PFMEA (Process FMEA - Potential Causes and Failure) - Operator's Role FMEA and Control Plans 11
5 Changes to Control Plans or PFMEA's (Process FMEA) FMEA and Control Plans 6
P PFMEA (Process FMEA) Acceptable Effectivity Rate for Reoccurances of Issues FMEA and Control Plans 1
T DFMEA (Design FMEA) - We already have a PFMEA (Process FMEA) FMEA and Control Plans 5
D Laser Welding PFMEA (Process FMEA) - Metal FMEA and Control Plans 14
Casana Detection level in PFMEA (Process FMEA) - Bulk Fluids FMEA and Control Plans 10
P Problem with "failure mode? interpretation in PFMEA (Process FMEA) FMEA and Control Plans 8
R Addressing Inspection in PFMEA (Process FMEA) FMEA and Control Plans 2
S Pfmea (Process FMEA) at Process Audit FMEA and Control Plans 4
J When to Update PFMEA (Process FMEA) - Rejection is found at the customer FMEA and Control Plans 12
V Integrating the FMEA process with problem investigation/RCA process and PFMEA FMEA and Control Plans 4
C DFMEA (Design FMEA) and PFMEA (Process FMEA) - Who should lead? FMEA and Control Plans 14
C PFMEA (Process FMEA) Detection Scale - Aerospace engine components FMEA and Control Plans 4
H How to Make PFMEA (Process FMEA) from the beginning to the end FMEA and Control Plans 4
H Corrective Action: When to update the Process FMEA (PFMEA) FMEA and Control Plans 15
M Process FMEA (PFMEA) Assumptions Regarding Causes Identification FMEA and Control Plans 6
M Process FMEA (PFMEA) for D.C. Welding of Sheet Metal Parts - Electrode Material FMEA and Control Plans 1
N How to Calculate RPN in Design FMEA (DFMEA) vs. Process FMEA (PFMEA) FMEA and Control Plans 9
J When to update a PFMEA (Process FMEA) FMEA and Control Plans 17
S Detection Criteria Examples - PFMEA (Process FMEA) - Emergency Safety Fixtures FMEA and Control Plans 2
E PFMEA (Process FMEA) Class Symbols FMEA and Control Plans 6
Kales Veggie Informational How to develop a Control Plan from a PFMEA (Process FMEA) FMEA and Control Plans 61
kedarg6500 Supplier PFMEA (Process FMEA) Audit Form FMEA and Control Plans 4
Y Process FMEA (PFMEA) vs. Equipment FMEA (EFMEA) Differences FMEA and Control Plans 15
J Updating a PFMEA (Process FMEA) after a Process Failure FMEA and Control Plans 3
J The real Link between a PFMEA (Process FMEA) and the Control Plan FMEA and Control Plans 19
W Actual examples of FMEA (DFMEA, PFMEA) for Car Assembly Process IATF 16949 - Automotive Quality Systems Standard 5
L PFMEA (Process FMEA) issue about lower RPN - AIAG 3rd edition page 55 FMEA and Control Plans 13
M Connections between PFMEA (Process FMEA) and the Control Plan. FMEA and Control Plans 20
M PFMEA Severity - What is Process FMEA Severity estimation based on? FMEA and Control Plans 77
K Change in Occurrence for Low Volume Assembly Process FMEA (PFMEA) FMEA and Control Plans 8
M Include Risk of Rework in a PFMEA (Process FMEA)? FMEA and Control Plans 5
