PFMEA (Process FMEA) Detection Scale - Aerospace engine components
Charlie H
Hi All,
With all the reading I've done on FMEA I still have questions.
1. When it comes to detectability, is rated on the present operation or one further into the process?
2. If the product is complex (aerospace engine componets), should the whole process be done at one time or one operation at a time?
3. How do you rate an operation of the process if an earlier operation is addressed with a high RPN?
Sorry if I seem greedy with my questions but I'll stop here for now.
Stijloor
Re: PFMEA detection scale
Charlie,
No you're not greedy with questions, that's why we're here to help you.
I am a little hesitant to respond to your post because most of my FMEA experience is with automotive suppliers. You mentioned aerospace components and that made me somewhat reluctant...
However, some of of our Fellow Covers have a lot of aerospace experience, so I let them go first. ;)
What guidance document do you use for your FMEA process?
Stijloor.
Charlie H
Stijloor,
I'm not sure what you mean by guidance document. Im sure once you tell me I'll kick my self for not thinking of it. But I'm new to Conituous Improvement and my company is new to FMEA.
So even if everybody out there are not experts, taking a wild guess at it might help for some good conversation on the topic at least.
Ajit Basrur
Charlie,
Stijloor.
I think the aerospace industry use the same FMEA concepts as automotive as I had read an article that the current FMEA concepts were derived in the 1960s during the Apollo programs. :)
Hi All,
I am not an expert so would to direct you to refer the various threads that we have on related subject. Use the SEARCH function to get more responses. Being a weekend, the response would be bit slow than usual.
Roger Thorpe - 2008
Charlie H,
I joined the forum today and think I may be able to help.
My background has also been automotive for the last 13 years as an FMEA consultant to that sector. However I also work in Motorsport, genral purpose industrial, railway support, healthcare and banking sectors. Some of my customers also supply the aerospace industry.
Firstly, the 'book that others have refered to in automotive terms is the QS9000 - FMEA 4th edition handbook as the industry reference standard. Is there an equivelant for the aerospace sector? There maybe, although I've yet to find one. I believe that most sectors look to the automotive sector as 'leading the way' when it comes to FMEA.
Now to your questions.
1. Detection - the issue of what it is, how useful it is and geographically where it is located in the process. In short the further it is from the process step being considered the less useful, because you add value to the product before it reaches your detection point. Equally to suggest you don't have anything when afew steps later in the next process (even if it is not the one being considered) would be misleading.
2. This question is a universal one not just constrained to your situation.
My recommendation is simple and adopted repeatedly over the last 10 years. Use a modular approach. Identify your core processes and match modular Process FMEAs to each of them ensuring there are no overlaps and no gaps.
Typical areas would be Manufacturing, assembly, goods in, packing/shipping and logistics. The first two are likely to be further subdivided as necessary.
If you need a more precise answer contact me directly with details of your 'core processes'
3. Please can you re-phrase this question as I am unclear as to what is meant, sorry.
Oh, by the way your by not greedy, bring it on, what's your second group of questions?
Trust this helps
Roger
R Is PFMEA (Process FMEA) for OEM sufficient to address Risk? ISO 13485:2016 - Medical Device Quality Management Systems 7
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
R PFMEA (process FMEA) for Incoming Material stage FMEA and Control Plans 7
P PFMEA (Process FMEA) Recommended Actions help FMEA and Control Plans 9
G Very Basic PFMEA (Process FMEA) Guidelines FMEA and Control Plans 17
M PFMEA (Process FMEA) - What is the best approach? FMEA and Control Plans 14
M PFMEA (Process FMEA) for Attribute Data Inspection Process FMEA and Control Plans 2
T PFMEA (Process FMEA) Recommended Actions Column FMEA and Control Plans 10
B Process FMEA (PFMEA) Same Multiple Causes for Different Effects FMEA and Control Plans 6
M Changing PFMEA (Process FMEA) RPN Values based on a Rejection FMEA and Control Plans 5
Q Using a Custom Process FMEA (PFMEA) Form FMEA and Control Plans 4
D PFMEA (Process FMEA) Process and Rankings (S-O-D) Document Control Systems, Procedures, Forms and Templates 8
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
L PFMEA (Process FMEA) Forms - Dyadem FMEA Software Products FMEA and Control Plans 5
L Rotational Molding and Machining PFMEA (Process FMEA) - Plastics - example wanted FMEA and Control Plans 6
Chennaiite PFMEA (Process FMEA) for Vehicle Assembly wanted FMEA and Control Plans 4
H How to perform interesting PFMEA (Process FMEA) Training Training - Internal, External, Online and Distance Learning 6
M PFMEA (Process FMEA - Potential Causes and Failure) - Operator's Role FMEA and Control Plans 11
5 Changes to Control Plans or PFMEA's (Process FMEA) FMEA and Control Plans 6
P PFMEA (Process FMEA) Acceptable Effectivity Rate for Reoccurances of Issues FMEA and Control Plans 1
T DFMEA (Design FMEA) - We already have a PFMEA (Process FMEA) FMEA and Control Plans 5
D Laser Welding PFMEA (Process FMEA) - Metal FMEA and Control Plans 14
Casana Detection level in PFMEA (Process FMEA) - Bulk Fluids FMEA and Control Plans 10
P Problem with "failure mode? interpretation in PFMEA (Process FMEA) FMEA and Control Plans 8
R Addressing Inspection in PFMEA (Process FMEA) FMEA and Control Plans 2
S Pfmea (Process FMEA) at Process Audit FMEA and Control Plans 4
J When to Update PFMEA (Process FMEA) - Rejection is found at the customer FMEA and Control Plans 12
V Integrating the FMEA process with problem investigation/RCA process and PFMEA FMEA and Control Plans 11
C DFMEA (Design FMEA) and PFMEA (Process FMEA) - Who should lead? FMEA and Control Plans 14
H How to Make PFMEA (Process FMEA) from the beginning to the end FMEA and Control Plans 4
H Corrective Action: When to update the Process FMEA (PFMEA) FMEA and Control Plans 15
M Process FMEA (PFMEA) Assumptions Regarding Causes Identification FMEA and Control Plans 6
M Process FMEA (PFMEA) for D.C. Welding of Sheet Metal Parts - Electrode Material FMEA and Control Plans 1
N How to Calculate RPN in Design FMEA (DFMEA) vs. Process FMEA (PFMEA) FMEA and Control Plans 9
J When to update a PFMEA (Process FMEA) FMEA and Control Plans 17
S Detection Criteria Examples - PFMEA (Process FMEA) - Emergency Safety Fixtures FMEA and Control Plans 2
E PFMEA (Process FMEA) Class Symbols FMEA and Control Plans 6
Kales Veggie Informational How to develop a Control Plan from a PFMEA (Process FMEA) FMEA and Control Plans 61
kedarg6500 Supplier PFMEA (Process FMEA) Audit Form FMEA and Control Plans 4
Y Process FMEA (PFMEA) vs. Equipment FMEA (EFMEA) Differences FMEA and Control Plans 15
J Updating a PFMEA (Process FMEA) after a Process Failure FMEA and Control Plans 3
J The real Link between a PFMEA (Process FMEA) and the Control Plan FMEA and Control Plans 19
W Actual examples of FMEA (DFMEA, PFMEA) for Car Assembly Process IATF 16949 - Automotive Quality Systems Standard 5
L PFMEA (Process FMEA) issue about lower RPN - AIAG 3rd edition page 55 FMEA and Control Plans 13
M Connections between PFMEA (Process FMEA) and the Control Plan. FMEA and Control Plans 20
M PFMEA Severity - What is Process FMEA Severity estimation based on? FMEA and Control Plans 77
K Change in Occurrence for Low Volume Assembly Process FMEA (PFMEA) FMEA and Control Plans 8
M Include Risk of Rework in a PFMEA (Process FMEA)? FMEA and Control Plans 5
