PFMEA (Process FMEA - Potential Causes and Failure) - Operator's Role
MasterBB
Potential cause of failure is defined as an indication of how the failure occur.
Should you avoid mentioning the operator or is it a common practice that some include the operator within this Column (Potential Causes of Failure)?
Examples: A. Operator error; inadequate operator quidelines specified.
B. Operator does not properly assemble part x into Y.
C. Don't mention the operator.
What do you think?
Do you include the operator as seen in A&B?
Or you would rephrase it otherwise & not mention the operator.
Looking for some best practices on the subject.
What do you think?
Thanks in advance
Duke Okes
Re: PFMEA (Potential Causes/Failure) - Operator's Role
"A" is not actually an operator error. if they followed inadequate guidelines it would be an error of the person who developed the guideline.
"B" might be operator, but it depends on why s/he improperly assembled the parts. For example, could it be because a part was incorrectly presented to the operator by the supplier (e.g., packaged in wrong orientation).
So I would tend to leave the operator out, and just mention the error that might occur. However, remember that pFMEAs normally assume that all previous process steps were done correctly, so "A" typically would not be listed, while "B" would, but generically (improperly assembled), since cause of improper assembly would be unknown until root cause analysis was conducted.
E
erozas2003
The main objective of PFMEA is to identify failure modes and the potential causes, and then evaluate risks. In my experience is a good practice to document operator failures as operator error, then the other indicators of PFMEA (severity of failure, occurrence and current controls) will lead you to the operations that need to be improved.
I heard in the past that we cannot fix operator errors, but we should fix the system to avoid that the operator make mistakes, we need to make error proof process, PFMEA is an excellent tool to assess your process and implement improvements.
Regarding the options A, B or C... I think that you need help of a crossfunctional team that includes operators; they really know what problems may occur on each single step of the process. If you are making PFMEA in the office or just not including operators, you will not see all potential failure modes
Regards.
Lalo
Sorry for my english translation, i do my best.
“Intellectual growth should commence at birth and cease only at death” A. Einstein
:bonk:
sitapaty
What do you think?
What do you think?
Thanks in advance
You cannot mention the operator's fault in the cause colomn.You have to assign a properly trained operator for the job.Even otherwise you have to assume that you have assigned a good operator.
Untrained operator is again an NC against the organization.In FMEA you have to assume the earlier operations are satisfactory although it is not always true.
Sitapaty
H
Hipolit
Looking at the evolution of the PFMEA in my present job I must say that the more mature analyze is the less “operator failure” you will see in the cause of the failure column. The question is why the operator made a mistake that led to occurrence of failure. In my opinion 80% of statements “operators failure” are not depth enough, take a while to look at the workstation ergonomics, presentation and flow of material. Good practice from my side, go to shop floor and X-ray the particular process/machine/workstation, tray to work yourself as an operator and then you have the best opportunity to avoid the pencil-pushing blind cups (as once Dirty Harry saidJ :bigwave:
H
Hipolit
Sadly life is brutal and no matcher how you will secure the process (ergonomics, material presentation) people tend to make mistakes is just in ours nature. Keep them trained, obeying wisely written standards and highly motivated and this should help;) Personally I tried to avoid putting “operator failure” as common cause of potential failure. As an example think of a situation as bellow: 8D report for a customer complaint ends up in cause: operator failure, corrective action: training or additional training of assembly staff, the question is: how on earth you can ensure that after the training operator will not repeat the same or similar mistake?
A generic operator error is too general. Get specific and use details such as installed upside down, reversed, etc. This will encourage recommended actions to error proof or mistake proof rather than to train or create job aids.
H
Hipolit
Question remains, why did the operator put the part in the wrong position. Training was inaccurate, part geometry makes it difficult or maybe there’s not enough guiding in assembly fixture itself? As a helping device to determined what was the initial rout cause we can use 5why or fishbone diagram.
sitapaty
Both Dr.Deming and Dr.Juran have said that human error is a cause for about 20% of rejections.The rest is 'Management Inefficiency'
-sitapaty
I beleive that is Miner's point. Remember that in a PFMEA we don't necessarily need to go to root - root -root cause in the form. only enough level of detail to capture the causal system and enable preventive action. Also remember that not all items on an FMEA require or need action. if the severity and occurrence are low enough - compared to other items - then we may elect to leave the item alone, at least for a while. If we were to get to all of the possible final root causes of every potential failure mode we would never release anything...
The OP's question was if we thought operator actions should be included in a PFMEA. *I* do include them as they are real causes of failures. I use the tyupe of language Miner has advocated to capture the action without casting aspersions on the competancy of the operator. This follows modern thought and practices of 'mistake-proofing'.
R Is PFMEA (Process FMEA) for OEM sufficient to address Risk? ISO 13485:2016 - Medical Device Quality Management Systems 7
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
R PFMEA (process FMEA) for Incoming Material stage FMEA and Control Plans 7
P PFMEA (Process FMEA) Recommended Actions help FMEA and Control Plans 9
G Very Basic PFMEA (Process FMEA) Guidelines FMEA and Control Plans 17
M PFMEA (Process FMEA) - What is the best approach? FMEA and Control Plans 14
M PFMEA (Process FMEA) for Attribute Data Inspection Process FMEA and Control Plans 2
T PFMEA (Process FMEA) Recommended Actions Column FMEA and Control Plans 10
B Process FMEA (PFMEA) Same Multiple Causes for Different Effects FMEA and Control Plans 6
M Changing PFMEA (Process FMEA) RPN Values based on a Rejection FMEA and Control Plans 5
Q Using a Custom Process FMEA (PFMEA) Form FMEA and Control Plans 4
D PFMEA (Process FMEA) Process and Rankings (S-O-D) Document Control Systems, Procedures, Forms and Templates 8
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
L PFMEA (Process FMEA) Forms - Dyadem FMEA Software Products FMEA and Control Plans 5
L Rotational Molding and Machining PFMEA (Process FMEA) - Plastics - example wanted FMEA and Control Plans 6
Chennaiite PFMEA (Process FMEA) for Vehicle Assembly wanted FMEA and Control Plans 4
H How to perform interesting PFMEA (Process FMEA) Training Training - Internal, External, Online and Distance Learning 6
5 Changes to Control Plans or PFMEA's (Process FMEA) FMEA and Control Plans 6
P PFMEA (Process FMEA) Acceptable Effectivity Rate for Reoccurances of Issues FMEA and Control Plans 1
T DFMEA (Design FMEA) - We already have a PFMEA (Process FMEA) FMEA and Control Plans 5
D Laser Welding PFMEA (Process FMEA) - Metal FMEA and Control Plans 14
Casana Detection level in PFMEA (Process FMEA) - Bulk Fluids FMEA and Control Plans 10
P Problem with "failure mode? interpretation in PFMEA (Process FMEA) FMEA and Control Plans 8
R Addressing Inspection in PFMEA (Process FMEA) FMEA and Control Plans 2
S Pfmea (Process FMEA) at Process Audit FMEA and Control Plans 4
J When to Update PFMEA (Process FMEA) - Rejection is found at the customer FMEA and Control Plans 12
V Integrating the FMEA process with problem investigation/RCA process and PFMEA FMEA and Control Plans 4
C DFMEA (Design FMEA) and PFMEA (Process FMEA) - Who should lead? FMEA and Control Plans 14
C PFMEA (Process FMEA) Detection Scale - Aerospace engine components FMEA and Control Plans 4
H How to Make PFMEA (Process FMEA) from the beginning to the end FMEA and Control Plans 4
H Corrective Action: When to update the Process FMEA (PFMEA) FMEA and Control Plans 15
M Process FMEA (PFMEA) Assumptions Regarding Causes Identification FMEA and Control Plans 6
M Process FMEA (PFMEA) for D.C. Welding of Sheet Metal Parts - Electrode Material FMEA and Control Plans 1
N How to Calculate RPN in Design FMEA (DFMEA) vs. Process FMEA (PFMEA) FMEA and Control Plans 9
J When to update a PFMEA (Process FMEA) FMEA and Control Plans 17
S Detection Criteria Examples - PFMEA (Process FMEA) - Emergency Safety Fixtures FMEA and Control Plans 2
E PFMEA (Process FMEA) Class Symbols FMEA and Control Plans 6
Kales Veggie Informational How to develop a Control Plan from a PFMEA (Process FMEA) FMEA and Control Plans 61
kedarg6500 Supplier PFMEA (Process FMEA) Audit Form FMEA and Control Plans 4
Y Process FMEA (PFMEA) vs. Equipment FMEA (EFMEA) Differences FMEA and Control Plans 15
J Updating a PFMEA (Process FMEA) after a Process Failure FMEA and Control Plans 3
J The real Link between a PFMEA (Process FMEA) and the Control Plan FMEA and Control Plans 19
W Actual examples of FMEA (DFMEA, PFMEA) for Car Assembly Process IATF 16949 - Automotive Quality Systems Standard 5
L PFMEA (Process FMEA) issue about lower RPN - AIAG 3rd edition page 55 FMEA and Control Plans 13
M Connections between PFMEA (Process FMEA) and the Control Plan. FMEA and Control Plans 20
M PFMEA Severity - What is Process FMEA Severity estimation based on? FMEA and Control Plans 77
K Change in Occurrence for Low Volume Assembly Process FMEA (PFMEA) FMEA and Control Plans 8
M Include Risk of Rework in a PFMEA (Process FMEA)? FMEA and Control Plans 5
