PFMEA - RPN - Severity, Occurrence and Detection - Which one does not change?
Paul Simpson
#41
You study the effects of your process with regard to meeting the specifications. If the DFMEA process has been properly done, if you meet the specifications, the concerns of the DFMEA have been addressed, whether you know specifically what they are or not. This is one reason that I always stress that the PFMEA should address the supplier's process, and its potential failure modes with regard to the specifications.
Then all the severities are the same - Failure to meet specification!You might as well have a PFMA. :)
Going back to how I understand FMEA came about - it was to prioritize actions on the things that have most potential for harm (at NASA) so if you take out the Severity category you loses a lot of the power of the tool.
Helmut Jilling
Auditor / Consultant
#42
I would suggest this is a theoretical position. It does not work this way in the real world.
That is why the PFMEA ranking scale for Severity was changed to a double column scale - one for the effect on the OE customer assembly line, and one for the end user. Neither of those are just meeting the specifications.
The writers of a PFMEA are supposed to determine the level of Severity for both and use the higher of the two. That is difficult to do without seeing the DFMEA, but not impossible to come up with a realistic number.
Stijloor
#43
Putting this in an automotive context; the effect of failure can also impact dealerships (servicing the vehicle) and even worse: a nonconpliance with a government regulation. All subsequent activities and people affected by the failure mode should be considered.
Stijloor.
#44
Stijloor.
But if a supplier meets the customer's specifications, there should be no worries, right? If a supplier provides a product that is in 100% conformance to the specifications he was given, and something blows up on the OEM assembly line, or in the field, it's a case of "The operation was a success, but the patient died," and none of it is the fault of a supplier who did what he was told to do.
I've been involved in instances where an automotive OEM was warned that what they were asking for was wrong, and the OEM's response was, "Let us worry about that." In other cases, after being supplied with product that conformed to specifications that somehow blew up in the customer's face, the customer made concerted efforts to shift blame to the supplier, saying, "You should have known this was going to happen." The sad fact is that in automotive work, you're often dammed if you do and dammed if you don't, so the best you can do is meet the specifications and cross your fingers.
The Taz!
#45
I think that anyone who has worked in automotive for any length of time has been in similar situations. I remember another supplier once telling me that he actually saw an OEM Work Instruction that actually said that if you have rejects, blame the supplier in all cases.
If a supplier advises a customer that there is a potential safety hazard, and is told basically to ignore it by the customer, the supplier should document the conversation; date, time, who, what, etc. and maintain the record. You may have your customer tap dancing if something "bad" happens, but at least you have some record of the conversation.
We expect to partner with the customer, but partner desks were invented for a reason. You still have to watch out for your company's best interest and do your due diligence.
JMHO
The Taz!
Helmut Jilling
#46
...If a supplier advises a customer that there is a potential safety hazard, and is told basically to ignore it by the customer, the supplier should document the conversation; date, time, who, what, etc. and maintain the record. You may have your customer tap dancing if something "bad" happens, but at least you have some record of the conversation.
JMHO
The Taz!
Excellent advice. It is unfortunate that some customers still lean this way, and then they wonder why their business suffers...:confused:
I would remind us that point #8 of the ISO Quality Management Principles is:
Principle 8 - Mutually beneficial supplier relationships.
It states in part,
An organization and its suppliers are interdependent and a mutually beneficial relationship enhances the ability of both to create value.
Key benefits:
  • Increased ability to create value for both parties. Flexibility and speed of joint responses to changing market or customer needs and expectations.
  • Optimization of costs and resources.
Applying the principles of mutually beneficial supplier relationships typically leads to:
  • Establishing relationships that balance short-term gains with long-term considerations.
  • Pooling of expertise and resources with partners.
  • Identifying and selecting key suppliers.
  • Clear and open communication.
  • Sharing information and future plans.
  • Establishing joint development and improvement activities.
And, my favorite -
  • Inspiring, encouraging and recognizing improvements and achievements by suppliers.
I cannot help but wonder how much better the US based auto industry would be, if we simply did these principles which we "claim" to be "committed" to...:agree1:
sushant_kulkarni
#47
Sorry Taz but that statement doesn't "ring true" to me. Occurence will change due to better prevention not detection (unless, of course, I completely missed your meaning - which is very possible at this time of the day :rolleyes:)
Whatever u say is correct that the reson now AIAG gives new current control detection & prevention.
MedQE
#48
Paul,
I am sure Jim will provide an example. I have one that may help.
Let's use a tire (tyre) as an example.
A standard tire is designed to hold air at a certain pressure and resist puncture. The failure mode could be puncturing, losing air pressure. The effect of losing air pressure is a possible roll-over, seriously injuring the passenger(s).
A design change may include filling the tire with a foam-type material in addition to holding air at a certain pressure. When a puncture occurs, the tire may lose pressure, but the foam provides some stability preventing deformation of the tire, thus avoiding a possible roll-over. Now the severity is reduced. The occurrence is reduced as well.
I am sure there are better examples. Thoughts anyone?
Hope this helps (a little).
Stijloor.
In the tire example shown above the severity is not changed despite the design change of adding foam. If I were to evaluate this hazard I would consider the worst possible consequence (severity) as "death" due to a rollover. By adding foam to the tire you have reduced the probability that a rollover or death will occur. But you have not changed the fact that the hazard is being evaluated relative to the worst possible consequence which is death so the severity is unchanged.
Stijloor
#49
Hello MedQE,
Have you looked at all the posts in this thread?
Using my tire (tyre) example, can you expand on this?
What would be required to reduce severity?
I am anxious to learn.
Stijloor.
Redbeard
#50
Severity of a hazard never changes! The design does not have anything to do with the hazard. It has to do with the probaility of occuring and detection to prevent it.
If death is the hazard it does not matter if it was a good design ore not you are still dead.
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
C PFMEA RPN - Feedback regarding adjusted RPN FMEA and Control Plans 3
S PFMEA RPN - At what RPN level do you take actions in the FMEA? APQP and PPAP 4
M Changing PFMEA (Process FMEA) RPN Values based on a Rejection FMEA and Control Plans 5
I PFMEA RPN Numbers Medical Device Risk Management FMEA and Control Plans 1
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
C PFMEA RPN rankings - Preventative action must be opened if RPN over 100 ISO 14971 - Medical Device Risk Management 9
N How to Calculate RPN in Design FMEA (DFMEA) vs. Process FMEA (PFMEA) FMEA and Control Plans 9
L PFMEA (Process FMEA) issue about lower RPN - AIAG 3rd edition page 55 FMEA and Control Plans 13
B Corrective Actions Priority - Process FMEA (PFMEA) RPN Limits - Recommended Actions FMEA and Control Plans 20
A Does anyone actually do a Pareto of the Top 5 (highest) RPN's of PFMEA? FMEA and Control Plans 8
S Process FMEA (PFMEA) RPN Corrective Action Plan FMEA and Control Plans 6
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A PFMEA severity score different applications FMEA and Control Plans 11
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
