PFMEA severity score different applications
AlanC
Hi All,
how to manage multi customer applications for the same process in terms of severity scoring. E.g The product produced may go into a safety critical application and score a severity of 9 or a non safety application and would score eg 4. The product goes down the same process but multi end customers can use the product in various ways. Do you have one PFMEA and have several lines for the different severity scores depending application, create several PFMEA's depending application ( but this turns it into a product and not process FMEA as the process is the same for both) or do you just enter the most severe case within the FMEA
cheers
Alan
optomist1
A Sea of Statistics
different uses/applications dictate different RPNs, severity...thus different PFMEAs....my guess is that the customer SQE or release engineer would state the same
leftoverture
I believe the PFMEA is a risk analysis tool of your process and, therefore, I would suggest using the worst case application to determine your rankings. And then take actions based on the risk associated with the higher RPN and/or criticality scores. Doing two because of the different applications makes one a meaningless paperwork exercise so I would avoid this practice.
optomist1
A Sea of Statistics
I disagree, and if is in the automotive field, unless the parts/assemblies are identical in all aspects, the OEM SQE/Release engineer would likely request separate PFMEAs/Control Plans...
leftoverture
I interpret that the original poster as indicating the parts/process is identical. With that in mind, I still say we need to push back on our customers when they ask us to do things that don't make sense. We don't want to let the automtive guys push us around. A process FMEA is about OUR process, not theirs. We have control over how it is ranked, and we can see this in the AIAG manual with a careful reading. It doesn't happen too often but I push back when my customers disagree with something in our PFMEAs. I mean this with all sincerity....letting customers badger us into meaningless paperwork exercises is not a lean practice and is a disservice to our own companies! We may not win every argument but I sure believe we need to try.
GRP
A few months late, but for whatever it is worth, I agree with your statement. Suppliers should coordinate and establish an effects and severity ranking table with their clients, based on the application.
The process is the same, but the application is different. The PFMEA severity ranking should be tailored to the application. Your organization might have different rules for processing, maintaining and documenting characteristics related with government regulation or safety.
In the interest of the supplier, having separate PFMEAs will avoid burdening with responsibility a project with lower severity.
leftoverture
Honestly I think you are confusing DFMEA and PFMEA. For the DFMEA, I agree with you. Different applications may have different rankings. But for the PFMEA, it is about the process. The owner of the process should set the rankings based primarily on the process not the application. For example, in my field of plastic molding, a threaded insert of the wrong length could have a low severity in the DFMEA because the part would still assemble and perform well whereas in the PFMEA, it could have a high severity because it could damage the mold and stop production. Always remember that the PFMEA is a tool primarily for the process owner, not the end user.
GRP
If you have a DFMEA from your own organization or from the client, you should take the effects and severity and incorporate them to the PFMEA rankings. This is an opinion.
You should do this because the effects of a failure mode are not only related to the process owner, but also to the client, the end user, and govt/safety regulations. And you have to account effects both on process and product. This is in well-known FMEA sources.
Think of a trim component for the automotive industry. What severity would you give to a tiny dent or scratch? If you just take the guideline from any of the said sources you could say a 2-4, maybe a 5 or 6. But if you have tuned your rankings and aligned them with the DFMEA and/or the client you could end up with an 8. The client might argue the appearance of a trim component is its primary function, and anything less than none is unacceptable.
I can think of another case of a plastic injected holder. This seemingly inoffensive component held together a set of parts which constituted a device linked to a function, the failure of which implied a govt regulation noncompliance. A "process-owner-only" PFMEA could have ranked a failure mode related to the characteristic with a 7, say scrap < 100% (process effect), but the whole picture yielded a 9.
Imho, practitioners of PFMEA should tune their effects and severity rankings by taking input from an available DFMEA or by coordinating this with their clients, and always consider both process and product effects; generally pooling all effects and sev together and using the highest one.
Back to the original post from AlanC, if you look at SAEJ1739 it is stated that manufacturers of stock products may not know the applications/uses of their products, .e.g. screws. In this case the PFMEA can consider a general severity such as no primary function, degraded primary function, and so on...
Here's the way that it should work: The customer does the DFMEA and the results are incorporated in the design output--drawings and specifications, mainly. Thus if the supplier satisfies the specifications given to them, the design requirements will be met. The PFMEA should address the supplier's process(es) and not the customer's. It's the responsibility of the customer to ensure that they adequately communicate their requirements. When developing Risk Priority Numbers (RPNs) for the manufacturing process, the supplier should take into account only the potential failures of their own processes, and the concomitant risks to their own business, not the customer's.
Over the years I've seen many situations where a supplier met all of the specifications, but somehow or another the product didn't work as intended. The operation was a success but the patient died. This is solely the responsibility of the design authority. This is not to say that a supplier shouldn't bring to light things that the customer might have missed.
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
O PFMEA - Reducing Severity (S) Ranking - Manufacturing Process Design Changes FMEA and Control Plans 4
C Determining PFMEA Severity for Armored Parts FMEA and Control Plans 5
G Internal vs. External PFMEA Severity Rankings FMEA and Control Plans 12
C Does the PFMEA Severity have to match the DFMEA Severity? FMEA and Control Plans 3
M PFMEA Severity - What is Process FMEA Severity estimation based on? FMEA and Control Plans 77
G AIAG PFMEA (3rd edition) Severity Rankings - Define a "portion of the product" FMEA and Control Plans 3
Ron Rompen Development of the PFMEA - SEVERITY scores not derived from the DFMEA - Ford FMEA and Control Plans 13
R PFMEA - RPN - Severity, Occurrence and Detection - Which one does not change? FMEA and Control Plans 67
M PFMEA Severity Ranking - 9 is with warning and a 10 is without warning FMEA and Control Plans 5
Howard Atkins Differences Between QS-9000 and VDA PFMEA Severity Index VDA Standards - Germany's Automotive Standards 4
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
M I need a sample Reverse PFMEA Process Checklist FMEA and Control Plans 2
C PFMEA example with machining (lathe+mill) FMEA and Control Plans 1
