PFMEA Severity - What is Process FMEA Severity estimation based on?
  • Thread starter Matthew_Hopkins
  • Start date
#61
Re: Severity estimation in a PFMEA is a bit confusing
Jim, this is going to be my last attempt to synchronize with you on this thread. Again, I agree with your premise, but again, you did not answer my question -
"What is the purpose of a PFMEA, automotive style particularly, if not to evaluate the failure mode and the risks involved?"
I have not said at any point that potential failure modes should not be evaluated, thus your question is not to the point. What I have said is that job shops should not use the AIAG book method of characterizing or identifying potential failure modes.
If applying a RPN number to a permaturely rusting part is not a failure mode that a painter must evaluate on a PFMEA, then we are in a parallel universe...
I have also already said, in so many words, that if I meet the specifications consistently and the thing corrodes in end use, it's ultimately the designer's problem, not mine.
Here are a few things that might result in premature corrosion of a painted part:
  • Inadequate film build (not enough paint)
  • Excessive porosity of the paint layer
  • Adhesion failure
Each of these potential eventualities should be addressed by the specifications--if not directly, then by the specification of testing for corrosion resistance and paint adhesion. Now, if I look at each of those bad things, I can associate each one of them with process failures of one kind or another. For example, film build might be inadequate due to incorrect dwell/cycle times, or the presence of Faraday cages or other part geometry issues. Adhesion failure may be due to poor surface preparation, among other things.
The things I would characterize as process failure modes are those things that can cause undesirable results where "undesirable results" equals failure to successfully complete the customer's specified testing, because that's the criterion I've been given by the customer.
"Poor surface preparation" is a potential process failure mode. Given that as a failure mode, and inability to pass the required testing as an effect, I can look to and prevent the causes of poor surface preparation, make a conforming part, and never consider what might happen to the part after it leaves my building.
My goal is to meet the specifications.
Stijloor
#62
<snip>What I have said is that job shops should not use the AIAG book method of characterizing or identifying potential failure modes.
Jim,
Right or wrong, the AIAG FMEA manual has become the de facto guideline for FMEA activities. A lot of emphasis is placed on the effects of failure modes as noticed/experienced by the Customer. Not speaking for Helmut, but I believe that this is one of the points he is trying to make.
Stijloor.
#63
Jim,
Stijloor.
I understand that. If constrained by shortsighted customers, you have no choice but to indulge their shortsightedness. Nonetheless, I know that some customers appreciate a conscientious demonstration of risk analysis, having seen too many "by the book" PFMEAs that are largely impotent and demonstrate that the supplier views them as a paperwork exercise.
speck
#64
Jim, I agree with your premise, but I don't think you are answering my question. A painter MUST evaluate the consequences of underpainting a part. And, those consequences only occur later to the end user. The failure mode is premature rusting. Isn't that the very purpose of a PFMEA? The spec indicates the paint mill thickness, the PFMEA considers the risk of failures. Why do you have a problem with that? The purvey of a designer is to specify the paint, the rest is process management.
Leaving the AIGA guidelines and train of thought for a moment, you as the painter and the painting FMEA risk team have decided that the required mil thickness for a particular coating should be .00X" thick. This has shown that undercarriage rust preventative measures are adequate for government DNR service vehicles that you manufacture just like it, only a little larger. You just analyzed the risk and performed all the necessary risk assessments. OK. What your customer's marketing team failed to tell you, (and probably their own design team) is that this particular line of products will not be used in Omaha, NE like the other ones, they will be shipped to Florida and will be used strictly on the beaches where the saltwater and corrosion will destroy the undercarriage parts in 6 months because the mil thickness was a fraction of the needed thickness needed for adequate protection.
If the design responsible parties do their job with DFMEA's they will tell you as a painter the specification and you as the processor should evaluate every process failure that will create a mil thickness not meeting that spec in any way shape or form. I believe this is the difference between process and design FMEA’s. Again if there is no difference and we have to call meetings with the end user (sometimes 6 tiers or more up the food chain) to determine the end use is on a beach and not in Nebraska, why don’t we call them PDFMEA’s? As a painter you cannot possibly pretend to understand all the end use situations. I would never buy a vehicle that was "designed" by a painter.
Of course a specification written by the automotive end users will always make every attempt to cover their own !%#@'s. I can hear and see GM or Chrysler now "Of course these vehicles are to be used in a saltwater environment didn't you follow the AIGA guidelines and consider these vehicles can be used as landrovers on Mars"
TO GM - "Sir , you do what you do best and design the thing, and I'll do what I do best and paint it. Let me know when you want a copy of my process FMEA's so you can analyze and consider all risks during your DFMEA process resulting from my painting process's. I can be held accountable for not meeting your specification but not because the product was used in saltwater. For saltwater use applications I have a completely different process for that right here as specifically requested by FORD. We have been manufacturing their maritime products for 8 years and they are completely happy as they have performed thorough DFMEA's and realized the need for a mil thickness 4 times your specification. My PFMEA clearly shows that this is suitable for use in freshwater environment. It's a shame your purchasing department did not forward that to your design team for consideration."
Am I just completely wrong in my thinking? :confused:
Helmut Jilling
Auditor / Consultant
#65
...you as the painter and the painting FMEA risk team have decided that the required mil thickness for a particular coating should be .00X" thick. This has shown that undercarriage rust preventative measures are adequate for government DNR service vehicles that you manufacture just like it, only a little larger. You just analyzed the risk and performed all the necessary risk assessments....
...If the design responsible parties do their job with DFMEA's they will tell you as a painter the specification and you as the processor should evaluate every process failure that will create a mil thickness not meeting that spec in any way shape or form. I believe this is the difference between process and design FMEA’s....
...Am I just completely wrong in my thinking? :confused:
Speck, I think your first excerpt is incorrect, and your second excerpt rightly explains the answer to your question in the first excerpt.
The painter would rarely be defining the paint spec or thickness spec. As your second statement indicates, that should be done by the design responsible parties. The product risks would be considered on their DFMEA.
The painter would take those specs, and evaluate the failure modes and risks and impact to the product if his painting process does not hold the spec. In other words, what happens if he under- or over-applies the paint? What would the failure consequences be? Those would be evaluated on the PFMEA.
#66
OK, first you say the product risks would be considered on the DFMEA, then you say the painter would evaluate "...risks and impact to the product..." Why would the painter worry about the product (as opposed to the specifications) if the designer built product risk mitigation into the design?
If I'm the painter, my primary concern is not meeting the specifications. Of course I know that if I don't meet the specifications, something bad might happen. The customer might measure paint thickness and find it lacking, or the parts might corrode in the field (which might be the result of not meeting the specifications, and might not). On the other hand, if thickness exceeds the specification, at best I'm wasting paint.
Helmut Jilling
#67
...If I'm the painter, my primary concern is not meeting the specifications. Of course I know that if I don't meet the specifications, something bad might happen. The customer might measure paint thickness and find it lacking, or the parts might corrode in the field (which might be the result of not meeting the specifications, and might not). On the other hand, if thickness exceeds the specification, at best I'm wasting paint.
Jim, huh? ...that is the purpose of a PFMEA! To evaluate the effects of a process failure upon the product..., and the risks that it would impose upon the customer.
P
praveenraaaj
#70
Dear All,
I would like to discuss this topic again for better understanding and clarity.
We have been asked to indicate the effects of failure mode addressing the following:
Inhouse Effect:
Customer Effect:
Enduser Effect:
Can anyone give a better clarity in addressing the effects ?
My understanding is , if a failure is detected, on the inhouse effect we should indicate whether to sort or rework or scrap. Should we also consider the detection here?
If certain defects are not noted by customer can we indicate no effect or what should we indicate?
Need all your help!
Kind Regards,
R Praveen
O PFMEA - Reducing Severity (S) Ranking - Manufacturing Process Design Changes FMEA and Control Plans 4
A PFMEA severity score different applications FMEA and Control Plans 11
C Determining PFMEA Severity for Armored Parts FMEA and Control Plans 5
G Internal vs. External PFMEA Severity Rankings FMEA and Control Plans 12
C Does the PFMEA Severity have to match the DFMEA Severity? FMEA and Control Plans 3
G AIAG PFMEA (3rd edition) Severity Rankings - Define a "portion of the product" FMEA and Control Plans 3
Ron Rompen Development of the PFMEA - SEVERITY scores not derived from the DFMEA - Ford FMEA and Control Plans 13
R PFMEA - RPN - Severity, Occurrence and Detection - Which one does not change? FMEA and Control Plans 67
M PFMEA Severity Ranking - 9 is with warning and a 10 is without warning FMEA and Control Plans 5
Howard Atkins Differences Between QS-9000 and VDA PFMEA Severity Index VDA Standards - Germany's Automotive Standards 4
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 20
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
M I need a sample Reverse PFMEA Process Checklist FMEA and Control Plans 2
C PFMEA example with machining (lathe+mill) FMEA and Control Plans 1
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
B Proactive efforts to reduce risk - PFMEA risk reduction activities IATF 16949 - Automotive Quality Systems Standard 8
N PFMEA no effect ratings FMEA and Control Plans 15
N DFMEA, Drawings and PFMEA of an Assembly Process FMEA and Control Plans 12
A PFMEA for DC Motor FMEA and Control Plans 5
Crimpshrine13 PFMEA Scope - Oversized Special Characteristic FMEA and Control Plans 4
B PFMEA and Control Plan Links APQP and PPAP 2
B Update our PFMEA after Supplier updates their PFMEA? FMEA and Control Plans 4
Q PFMEA Scope and Detection Controls FMEA and Control Plans 1
A VDA 4 and PFMEA - What's main difference? VDA Standards - Germany's Automotive Standards 0
A Corrective Action Column in Control Plan and aligning PFD, PFMEA and Control Plan FMEA and Control Plans 6
R Is PFMEA (Process FMEA) for OEM sufficient to address Risk? ISO 13485:2016 - Medical Device Quality Management Systems 7
J Example PFMEA for Hydraulic Cylinders wanted FMEA and Control Plans 0
