PFMEA Severity - What is Process FMEA Severity estimation based on?
  • Thread starter Matthew_Hopkins
  • Start date
Chennaiite
Never-say-die
#71
Re: Severity estimation in a PFMEA is a bit confusing
Dear All,
Can anyone give a better clarity in addressing the effects ?
My understanding is , if a failure is detected, on the inhouse effect we should indicate whether to sort or rework or scrap. Should we also consider the detection here?
You may wish to read Suggested Evaluation criteria for Severity rating mentioned in AIAG Manual (Page 88). It speaks about 'Customer effect' which is applicable to End user and also 'Manufacturing/Assembly effect' which could be applied to your immediate Customer's as well as your inhouse production process.
If certain defects are not noted by customer can we indicate no effect or what should we indicate?
If Customer's process is not capable of detecting a particular defect supplied, you can consider 'No effect' at your Customer end, provided it does not result in unsafe Customer operation.
P
praveenraaaj
#72
Thanks for your reply.
But I still have ambiguity even after reading, should we also consider the inhouse effects if the problem occurs or detected at some point ?
Can we indicate NO EFFECT for customer and End user if it has no unsafe operation but only possibility reduced performance or inconvenience but cannot be detected by them?
Thanks !
#73
If a problem caused by your process creates a problem for your customer or the end user, it will undoubtedly cause a problem for your company.
If the product creates a problem for your customer or the end user, it will create a problem for you and your customer. The fact that your customer might not detect the issue before releasing the product doesn't mean that the problem doesn't exist.
Chennaiite
Never-say-die
#74
In addition to Jim's
Yes. The effect of the problem inhouse might be like reduced production volumes, high scrap rate, rework, etc.
Reduced Performance and Inconvenience are detectable certainly by the end user, may be not by your next tier Customer. Therefore, 'no effect' for end user is ruled out.
Helmut Jilling
Auditor / Consultant
#76
I read all threads in this post and am confused further :frust:
So would Severity in PFMEA be based on Process / End user ?
If you read in the AIAG FMEA manual (this is an automotive guidebook in the USA automotive industry), it shows a table for Severity for PFMEA. The table has a column for the process and customer, and one column for the end user. You select an answer from both columns, and use the higher number of the two scores. So, it is based on both, whichever is higher, on each risk item.
mraroldis
#77
Re: PFMEA Severity - What is Process FMEA Severity estimation based on
Hello All
How could be estimate in a proper way Severity from 2nd. Party or 3rd. Party Supplier?
Can be estimate Severity (2nd. & 3rd. Party Supplier) less than 1st. Party Supplier?
This is in order that 3rd. Party Supplier send its finished product to 2nd. Party Supplier and this to 1st. Party Supplier and then to Auto Maker.
Example: FORD (Auto Maker)
Supplier 1st. Party: Alternator Maker (Auto Component)
Supplier 2nd.Party: Bearing Maker (Alternator Component)
Supplier 3rd Party: Plastics (Bearing Component)
Helmut Jilling
#78
Hello All
If you are looking at a PFMEA, Severity looks at the impact on the process and the product. Whether you are at tier 1 or tier 3, the Severity can be the same. It is the final impact on the product and the process.
O PFMEA - Reducing Severity (S) Ranking - Manufacturing Process Design Changes FMEA and Control Plans 4
A PFMEA severity score different applications FMEA and Control Plans 11
C Determining PFMEA Severity for Armored Parts FMEA and Control Plans 5
G Internal vs. External PFMEA Severity Rankings FMEA and Control Plans 12
C Does the PFMEA Severity have to match the DFMEA Severity? FMEA and Control Plans 3
G AIAG PFMEA (3rd edition) Severity Rankings - Define a "portion of the product" FMEA and Control Plans 3
Ron Rompen Development of the PFMEA - SEVERITY scores not derived from the DFMEA - Ford FMEA and Control Plans 13
R PFMEA - RPN - Severity, Occurrence and Detection - Which one does not change? FMEA and Control Plans 67
M PFMEA Severity Ranking - 9 is with warning and a 10 is without warning FMEA and Control Plans 5
Howard Atkins Differences Between QS-9000 and VDA PFMEA Severity Index VDA Standards - Germany's Automotive Standards 4
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 20
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
M I need a sample Reverse PFMEA Process Checklist FMEA and Control Plans 2
C PFMEA example with machining (lathe+mill) FMEA and Control Plans 1
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
B Proactive efforts to reduce risk - PFMEA risk reduction activities IATF 16949 - Automotive Quality Systems Standard 8
N PFMEA no effect ratings FMEA and Control Plans 15
N DFMEA, Drawings and PFMEA of an Assembly Process FMEA and Control Plans 12
A PFMEA for DC Motor FMEA and Control Plans 5
Crimpshrine13 PFMEA Scope - Oversized Special Characteristic FMEA and Control Plans 4
B PFMEA and Control Plan Links APQP and PPAP 2
B Update our PFMEA after Supplier updates their PFMEA? FMEA and Control Plans 4
Q PFMEA Scope and Detection Controls FMEA and Control Plans 1
A VDA 4 and PFMEA - What's main difference? VDA Standards - Germany's Automotive Standards 0
A Corrective Action Column in Control Plan and aligning PFD, PFMEA and Control Plan FMEA and Control Plans 6
R Is PFMEA (Process FMEA) for OEM sufficient to address Risk? ISO 13485:2016 - Medical Device Quality Management Systems 7
J Example PFMEA for Hydraulic Cylinders wanted FMEA and Control Plans 0
