Hi everyone! I'm new around here and have a question. I've been tasked with creating a PFMEA on a dip painting operation on a large steel part that consists of the following steps, each with its own tank and controlled by an overhead shuttle:
1. Alkaline Cleaner
2. Rinse
3. Hot Rinse
4. Dryer
5. Cooling
6. Acrylic Enamel Dip
7. Flash dry
8. Cure Dry
9. Cool Off
The problem is that this is being done backwards and we're trying to put the cart before the horse. We have no DFMEA, and Quality is chomping at the bit for a control plan without a PFMEA. As I understand PFMEA the process requirements would be something like (and this is hardly an all encompassing list): No soil contaminants (Alkaline cleaner step), Cleaning solution removed (hot rinse step), part fully coated (acrylic enamel dip step), Paint dry film thickness 2 mil (cure dry).
This would mean root causes (again, hardly comprehensive) in the PFMEA would be things like Alkaline Cleaner pH too low (Alkaline Cleaner too low), water temperature too low (hot rinse step), paint level too low (acrilyc enamel dip step), paint concentration too low in dip tank (cure dry step).
Where I'm getting confused is that some of the process requirements that Quality is including in their (too early) control plan in the product/process specification/tolerance section is things like tank pH, paint viscosity, and solution temperature, and this seems to me to be root causes in a PFMEA, possibly to inform a DFMEA on this painting "machine" and not process requirements. After all, design isn't going to call out wet paint viscosity on a drawing, they're going to call out things like adhesion, DFT, paint hardness, and paint coverage. Then, my thinking goes, the PFMEA will drum up stuff in the root cause section such as cleaner pH, paint viscosity, etc... Then, ideally, this would parlay into other documents such as gage r&r or design FMEA on this new painting "machine" to help suss out the time to failure parameters like paint viscosity and cleaner pH.
Does anyone have any insight into this? Am I on the right track or should things like tank pH and wet paint viscosity be included as process requirements?
1. Alkaline Cleaner
2. Rinse
3. Hot Rinse
4. Dryer
5. Cooling
7. Flash dry
8. Cure Dry
9. Cool Off
