Pharmaceutical Analytical Method Validation and Gauge R&R
v9991
I have seen couple of templates of R&R studies they are primarily seem to be analysis of same-set-of-parts analyzed by multiple personnel.
Data is assessed to outline the variation of Equipment-appraiser-R&R-part & total; all of them are assessed wrt Measurement unit, tolerance analysis, study variaion, % contribution.
Now for analytical method validation in pharma and biotech industries...as per ICH Q2 ( ref. pg. 11, 12 onwards for brief methodology and acceptance criteria)
i have one particular question....how do these two correlate....
for eg., is it adequate to comply with ICH Q2 standards or is there a opportunity &^ need to adopt R&R analysis of the data.
I am sorry for asking a very-broad & generic question,
CAN I REQUEST for understanding the application of R&R analysis for Accuracy studies.
3-concentrations (70% - 100% - 130%); 3- preparations analysis; analyzed on 5 different days;
Traditionally, the acceptance criteria is that, values observed should be within the specification limits i.e., 98-102% of target concentrations for test parameter of assay.
similarly there are other parameters viz., robustness, ruggedness, etc.,
thank you...
The general answer is NO. the common Gauge R&R is really only intended to assess precision and NOT accuracy. additionally the mathematical incorrectness of the %tolerance calculation would drive your stats group crazy and lead to rejection by your regulatory body.
there are several appropriate techniques for analytical method assessment,, you should use those.
v9991
thank you,
...other parameters viz., robustness, ruggedness, etc.,
robustness :- where minor deliberate changes are made to the method and system suitability is verified.
ruggedness :- where the equipments - analysts are varied and equivalence is established.
how about using R&R for above scenario?
Again no. Youden, bland Altman, non-inferiority, mcnemer's test, confidence intervals etc are methods to use depending on what you are doing.
v9991
considering that i apply R&R , precision i.e, repeatability & reproducibility.
the general acceptance criteria is <10; accepted with caution 10-30 and not acceptable >30%
are these ranges applicable and valid for complex analytical methods, such as ones of pharma, which involves multiple steps i.e., weighing-dilution(s)-measurement and comparison with (primary or reference) standard
no. remember these ranges are rules of thumb (with no empirical or statistical basis) for a ratio that is mathematically invalid. Just because an approach is commonly used doesn't mean its acceptable.
v9991
thank you Bev D;
1) so, can you also please comment on the another point i mentioned...viz., direct measurements viz., using of measurements such as verniers, temperature sensors, pressure sensors
VERSUS indirect/complex techniques involving such as ones i tried to list out..."weighing test - dilution - absorbance/response of UV - compare with standard response"!
2) another point on these accpetable ranges for RU&R, given the complex techniques, i am planning to characterize these ranges based on multiple data & batches; and arrive a given range for, at-least each for given product AND at-best the given test technique/method
how does the above approach sound?
v9991
thank you Bev D, can you pl. kindly point out the "mathematical incorrectness" part for me please.
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
E Non-GMP examples in Pharmaceutical industry Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
D Clothes changing in pharmaceutical factory Manufacturing and Related Processes 8
A Reduced Testing of Pharmaceutical Raw Materials Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
H Communication plan according to ISO9001 - Pharmaceutical field Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
P ISO 5 Pharmaceutical clean room design Process Maps, Process Mapping and Turtle Diagrams 2
A Any recommendation for ASQ's CPGP (Pharmaceutical GMP Professional) Certification exam questions? ASQ - American Society for Quality 2
A Pharmaceutical Manufacturer's obligations - Laboratory Test instruments General Measurement Device and Calibration Topics 0
E IVD Classification in Japan based on the Japanese Pharmaceutical Affairs Law Japan Medical Device Regulations 2
S Pharmaceutical and Healthcare Sciences Society ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 5
S Any suggestions for ASQ CPGP (Certified Pharmaceutical GMP Professional) exam prep? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
C Revision of Japan's Pharmaceutical Affairs Law (PAL) in 2014 Japan Medical Device Regulations 10
Ajit Basrur FDA Loosens Pharmaceutical Regulations on 13 Companies Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
J What is the gowning requirements for the Pharmaceutical Packaging area ? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 7
C Very Small OTC (Over The Counter) Pharmaceutical Company Requirements US Food and Drug Administration (FDA) 6
R Manufacturing Documentation in Pharmaceutical Environment Document Control Systems, Procedures, Forms and Templates 2
V Examples of Design and Process FMEA for Pharmaceutical Product Development ISO 14971 - Medical Device Risk Management 7
P Japanese Pharmaceutical Affairs Law (JPAL) Internal Audit Checklist Quality Manager and Management Related Issues 4
M Pharmaceutical Product Sample Retention Requirements Manufacturing and Related Processes 1
D Pharmaceutical Manufacturer Audit Checklist Template Manufacturing and Related Processes 9
M Cheap/Free CAPA Software for small Pharmaceutical company Quality Assurance and Compliance Software Tools and Solutions 8
C Balance Calibration SOP for a Pharmaceutical Environment General Measurement Device and Calibration Topics 4
AnaMariaVR2 FDA embraces ICH Guidance on Pharmaceutical Quality Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
G Benefits of Blister Packaging for Pharmaceutical Products Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
S Database of ISO 13485 Certified Pharmaceutical Companies ISO 13485:2016 - Medical Device Quality Management Systems 1
I Medical Device Validation and Pharmaceutical Validation differences? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
AnaMariaVR2 Certificate of Pharmaceutical Product (CPP or CoPP) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
I What are examples of a Combination Product (Medical device and Pharmaceutical) ? ISO 13485:2016 - Medical Device Quality Management Systems 14
AnaMariaVR2 Watchdog may Blacklist some Pharmaceutical Companies US Food and Drug Administration (FDA) 1
AnaMariaVR2 A Profile of the Pharmaceutical Manufacturing Industry: Russia Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
R Cleaning Validation Protocols for a Pharmaceutical Company Qualification and Validation (including 21 CFR Part 11) 2
P How to get FDA Approval of an API (Active Pharmaceutical Ingredients) Plant in India US Food and Drug Administration (FDA) 3
S Instrument Calibration Laboratory setup for API Pharmaceutical Company General Measurement Device and Calibration Topics 1
P FDA Approved API (Active Pharmaceutical Listing) Bioequivalence Study Lab for India Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
R Is AQL sampling plans applicable for Bulk Pharmaceutical Manufacturing (API)? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
G Pharmaceutical Risk Assessment - Use of Medical Staff Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
Q Japanese Pharmaceutical Affairs Law (PAL) doc and "Essential Principle Checklist" Japan Medical Device Regulations 2
M ISO 13485 x ICH Q10 Pharmaceutical Quality System - Comparison Evaluation ISO 13485:2016 - Medical Device Quality Management Systems 2
G Pharmaceutical Company - Water Requirements Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
L Substitution of Certificate of Pharmaceutical Product (CPP) for Singapore Other Medical Device Regulations World-Wide 2
M Lean SOP (Standard Operating Procedure) for Pharmaceutical Distribution Company Lean in Manufacturing and Service Industries 8
AnaMariaVR2 70.8% of Pharmaceutical Companies Looking to Work with New Logistics Partners US Food and Drug Administration (FDA) 0
AnaMariaVR2 2011 Top 10 Players in the Japanese Pharmaceutical Market US Food and Drug Administration (FDA) 0
A Control and Management of Promotional Materials for Medical Device and Pharmaceutical Document Control Systems, Procedures, Forms and Templates 14
C Certified Pharmaceutical GMP Professional (CPGP) Certification Journey Imported Legacy Blogs 5
C Role and Benefits of PIC/S (Pharmaceutical Inspection Cooperation Scheme) Other Medical Device Regulations World-Wide 2
S Pharmaceutical AQL Standards and Benchmarks AQL - Acceptable Quality Level 5
D Printed Packaging Material Suppliers to Pharmaceutical Companies Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 13
U Batch and Master Batch Record Template for Pharmaceutical Industry Document Control Systems, Procedures, Forms and Templates 9
