Philosophy of CMM Software and CMM
Z
zancky
#21
hi Hawat,
I have got a special real case:
a valve housing that can not be assembled if the mean diameter is out of tolerance and, "icrendibile visu", the roundness is smaller then 0.03 mm:mg:!!
it can not be controlled by any go-nogo plug gage!
(for those who think lower roundness is better and for anyone involved in ISO and ASME we need a drawing symbol to state a minimum ovality!):lmao:
Z
zancky
#23
Now that's a special case! Do you need ovality or would tri-lobed work?
the part is a valve housing (let's think about a closed tube/pipe on the bottom and a flange at the opening and small wall thickness). the customer needs to insert a magnetic plug on the bottom with interference (there is a final station in order to roll outside housing wall to fix the plug). if the interference is given by the two diameter (bottom of the housing and plug diameter) the friction is so strong that will deform the total valve length. So in order to have no clearance between plug and housing inside diameter we are "using" the roundness. :bonk:"lobed" will be perfect but it is a press drawing part.
Z
zancky
#24
I have got a new issue: roundness.
drawing requirement about roundness in every standard is about circle and doesn't need any other reference/datum.
into the real world cylinder and cylindricity are self-reference features not circle and so not roundness. In some cases we need a reference/datum axis in order to determine the circle/diameter ( let's think about a circle created by the revolution of an inside/outside rib) and so the roundness (e.g unwritten assumption)
working with CMM usually we look for some (from 1 to 2) reference axis into the parts in order to align the CMM system axis before performing the measure. Cometime the requirement is a hole diamter therefore we can apply the cylinder feature first on the parts to be measured.
something different happens working with roundness machine o dial bore gaes with which the "alignement" process may be performed by looking for the minimum roundness error
I would like to know Your opinion/experience and I have attached 2 file for example
thanks
True Position
#25
I am sorry to say, my math skills have been lost due to lack of use. Is your concern that since you align to the cylinder on the CMM the software will correct for any errors in the hole/pin's axis compared to a roundness checker which would just trace an oval pattern on a mis-aligned hole/pin and report how round/out of round the oval was? (Or potentially report an oval as round.)
Z
zancky
#26
sorry but it was difficult to me to explain.
I would like to point out that
- In the real world sometime a diameter and a roundness requirements on the drawing may be just a question how You align the part and it may be there is no indication on the drawing how to proceed.
- CMM can give a affordable result respect to round tester if you find a reference axis
- My friend procedure always minimizes the actual roundness: in my example an oval cylinder has 0 roundness measure
hope it is clearer
Stimpy
#27
Learn mode in MCosmos is awesome. I've written thousands of programs, 99.9% of which were written in Learn mode. Works great, easy to use. I've never had any issues.
tribalarm
#28
I too find Learn Mode really easy to use and haven't had an issue with it.
I also program directly in edit mode but find this a lot more time consuming.
Along with the fact if you use Mitutoyos Offline programming then you HAVE to program through learn mode.
The automatic feature recognition on Calypso is different to this but Mitutoyo Cosmos has the same auto recognition, just start measuring a feature and it will perform the same as Calypso, ie work out what element you are trying to measure, rather than selecting from the menu.
G Training Employees about Quality - Philosophy / Mind set Misc. Quality Assurance and Business Systems Related Topics 1
G Design Philosophy - Iran Medical Device Registration Other Medical Device Regulations World-Wide 7
M Philosophy and Quality! Philosophy, Gurus, Innovation and Evolution 5
Q Understanding the general Philosophy with Complaints and CAPAs ISO 13485:2016 - Medical Device Quality Management Systems 7
E Evaluating Lean Knowledge: Lean Philosophy Course for Production Engineering Students Lean in Manufacturing and Service Industries 1
S Test Philosophy for Electronics Supplier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
K "Leadership Philosophy" Funny Stuff - Jokes and Humour 6
M Quality Tools and Philosophy! Quality Tools, Improvement and Analysis 7
Randy Part of my life philosophy...How about you? Coffee Break and Water Cooler Discussions 18
A Where does the Lean Manufacturing philosophy / tool set come from? Lean in Manufacturing and Service Industries 32
B Management Philosophy Philosophy, Gurus, Innovation and Evolution 3
G A Difference in Management Philosophy!! Funny Stuff - Jokes and Humour 1
D Ppm - Does anyone have anything good on ppm philosophy? Philosophy, Gurus, Innovation and Evolution 10
M Open Book Management Philosophy - Letting the employees see all information Philosophy, Gurus, Innovation and Evolution 35
T Customer Service Orientated on CRM philosophy Service Industry Specific Topics 3
L Fitness for Purpose; A negative philosophy, or required business driver? Misc. Quality Assurance and Business Systems Related Topics 24
T Productivity In Service - CRM philosophy environment Service Industry Specific Topics 3
W Deming's philosophy in education? Philosophy, Gurus, Innovation and Evolution 5
Marc Calibration Uncertainty Philosophy - Reality vs. Basic Theory (& Guardbanding) Measurement Uncertainty (MU) 7
D Philip Crosby vs. The Deming Philosophy Preventive Action and Continuous Improvement 29
Marc Zero Defects & Taguchi Loss Function - ISO 9000 and the Zero Defects Philosophy Quality Tools, Improvement and Analysis 32
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C CMM Granite too hard General Measurement Device and Calibration Topics 4
A Cg, Cgk and GRR of a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
L In house calibration - Our CMM's are outside certified can I use them to certify our standards General Measurement Device and Calibration Topics 4
M Honeywell CMM's - Why Honeywell will no longer sell their manuals Federal Aviation Administration (FAA) Standards and Requirements 2
Marco Bernardi Plane measurement with a 3D touch machine like a CMM. Calibration and Metrology Software and Hardware 3
Marco Bernardi Diameters measurement with 3D touch machine like a CMM Calibration and Metrology Software and Hardware 4
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
V Recording CMM dimensional results on CFG-1003 APQP and PPAP 3
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
J CMM Accuracy Formula General Measurement Device and Calibration Topics 3
J Manual Vision CMM Calibration General Measurement Device and Calibration Topics 7
D CMM Room cleanliness requirements ISO 17025 related Discussions 7
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
D Can a Mill be used as a CMM? General Measurement Device and Calibration Topics 2
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
B Zeiss CMM Calypso output to Excel or CSV file Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
J CMM Probe Certification General Measurement Device and Calibration Topics 1
S Opinions on the "Best" CMM for High Accuracy Machining General Measurement Device and Calibration Topics 9
P Getting ready for Boeing's AC7130 requirement for suppliers using a CMM AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J CMM Uncertainty Calculation Question - Deviations Measurement Uncertainty (MU) 9
K "Verification of Calibration" - CMM arm General Measurement Device and Calibration Topics 6
P CMM Equipment Validation and Qualification Approach ISO 13485:2016 - Medical Device Quality Management Systems 11
J Outsourced CMM Measurement Inspection Service and ISO 17025 ISO 17025 related Discussions 14
M Gage R&R with CMM 1X1X10 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
