Plan-Do-Check-Act-Anticipate Cycle
Marc
#11
That says you do not have to go through the life cycle if you only have the PDCA. The extra A in part comes from feedback during the life cycle of the part/device/whatever.
Yes, one can say Prediction is only a part of planning, but in that case I hope that planning isn't a one time thing.
Rob Nix
#14
Juran refers to the continuity of the PDCA 'cycle' in his handbook (pg. 4.8), taken from Deming's 'Out of the Crisis' (pg. 88). Juran also depicts it - I think in 'Quality Planning and Analysis - as a spiral.
I've found that every 'problem solving' process invented follows this repeating spiral no matter whether it is called PDCA, PDSA, DMAIC, 8D, or whatever.
I don't ANTICIPATE anybody disagreeing with this.... RATS! :rolleyes:
P
Polly Pure Bread
#15
Why don't you just tell Toyota, Honda, Sony, Mitsubishi and every other major Japanese manufacturer that they were wrong to listen to Deming in the 1st place?
Anticipate is defeatist. It tells me that you have not trust in your own process because you're expecting failure. Why not stick to what has been proven historically and financially?
I would prefer to look at it as a proactive action. It doesn’t connote a negative impression on me. This means it is now part of the process to be more proactive to ensure no problems will occur because we’ve already anticipated that there is potential problem and we’ve already done something about it to “prevent” it from happening.
#16
I don't think "spiral" is appropriate. A spiral starts at a central point and moves progressively away from it (or in reverse, moves towards the central point, where it terminates) but in any case the ends don't meet, and it proceeds (theoretically at least) infinitely. I think Juran's usage was an attempt to differentiate his point from that of Shewart just for the sake of differentiation.
Rob Nix
#17
Jim Wynne: A spiral starts at a central point and moves progressively away from it
Yeah, Yeah. Blah Blah. I wasn't doing a lesson in geometry. Actually, Webster's (Spiral - 1b) does allow for a helical definition also. ;)
Q
QCAce
#19
I've found in the past this can cause things to get messy. Many people begin 'anticipate' things that will likely never happen in which case we end up building an overly complicated and unnecessarily costly quality system that we have to put up with.
The premise of your original question seems to ask if PDCA can be improved, and there appears to be an emphasis on trying to make it more preventive focused?
In an earlier reply, Marc emphasized the importance of facts and data analysis. I think this is the key but I will expand on that thought...
I think the others are correct that said Anticipate can be rolled into Plan, and it is a continuous cycle...PDCAPDCAPDCA....
But most of the time as new quality professionals we come into a process that is already in existence when we try to implement PDCA. So I would recommend starting with a focus on the data collection and reporting, rather than the Planning phase. Make the data easy to collect and the reporting as easy to understand as possible. This will then help focus the planning efforts on improvement of the processes to yield the desired improvement in the metrics.
Practice PDCA........but implement CAPD..
V Internal Audit using Plan, Do, Check, Act - Way to go? Internal Auditing 11
M How do other companies institutionalize the Plan Do Check Act process? IATF 16949 - Automotive Quality Systems Standard 4
Y Training Video/ video clips for PDCA (Plan - Do - Check - Act) Training - Internal, External, Online and Distance Learning 11
A PDCA (Plan Do Check Act) vs. DMAIC (Define Measure Analyze Improve Control) Quality Tools, Improvement and Analysis 24
K PDCA - Plan Do Check Act Cycle - What is PDCA? Quality Tools, Improvement and Analysis 3
Q Chrysler required FMEA and Control Plan Document Audit Forms and Process Audit Check FMEA and Control Plans 7
F Generic control plan - Check Part to Print FMEA and Control Plans 15
Jimmy123 IATF16949 Control Plan FMEA and Control Plans 1
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 3
D Quality plan for moving locations ISO 13485:2016 - Medical Device Quality Management Systems 3
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
A Prototype control plan FMEA and Control Plans 2
S ISO9001:2015 Implementation / update plan template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Do I need a "State of the art" plan? CE Marking (Conformité Européene) / CB Scheme 1
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
L Sampling Plan Risks AQL - Acceptable Quality Level 6
Felony Melony Project Milestone Plan-Development to Mass Production APQP and PPAP 2
Q Contingency plan - IATF Sanctioned Interpretation 17 IATF 16949 - Automotive Quality Systems Standard 4
D Continuous Improvement Plan - Plastic injection molding IATF 16949 - Automotive Quality Systems Standard 1
M IVDR and Performance Evaluation Plan CE Marking (Conformité Européene) / CB Scheme 2
A The requirement of the PMS plan--suitable indicators and threshold values EU Medical Device Regulations 0
E BCP (Business Continuity Plan) Call Tree Business Continuity & Resiliency Planning (BCRP) 13
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
B Biological evaluation plan and report Other Medical Device Related Standards 5
B Sterilization Validation Plan Other Medical Device Related Standards 3
R Electrical contractor Project Quality Management Plan Quality Manager and Management Related Issues 1
M Clinical Development Plan - Advice Requested EU Medical Device Regulations 11
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
D All Dimensions listed on control plan FMEA and Control Plans 10
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Q Internal audit plan template Internal Auditing 12
C Gobys for operations documentation plan Oil and Gas Industry Standards and Regulations 4
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
K %GRR was between 10-30% so we have to have a "backup plan" per auditor IATF 16949 - Automotive Quality Systems Standard 15
R Reduced sampling plan for sterial products APQP and PPAP 0
S PMS (Premarket Submission) and PMCF Plan EU Medical Device Regulations 5
M Clinical Evaluation Plan vs. PMCF Plan EU Medical Device Regulations 29
qualprod Corona virus Contingency plan - What have you done in your company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
J Requested Validation plan and reports Manufacturing and Related Processes 4
