Plan-Do-Check-Act-Anticipate Cycle
P
Polly Pure Bread
#21
I don't think "spiral" is appropriate. A spiral starts at a central point and moves progressively away from it (or in reverse, moves towards the central point, where it terminates) but in any case the ends don't meet, and it proceeds (theoretically at least) infinitely. I think Juran's usage was an attempt to differentiate his point from that of Shewart just for the sake of differentiation.
I think “spiral” is possible if there would be a linked from 1 complete cycle to other cycles. Let say cycle 1 (operational management step 1, 2, 3… etc.) to cycle 2 (tactical management 1,2,3… etc.) to cycle 3 (strategic management 1,2,3… etc.).
#22
The idea behind PDCA is that there is no such thing as a "complete cycle" in that once you're done with "Act" you start over again at "Plan." In your examples there are several concurrent PDCA cycles occurring, none of which can be appropriately depicted as spirals or helixes.
This is all beyond the point, however, which is that the additional "A" doesn't serve a useful purpose.
P
Polly Pure Bread
#23
I mean continuous cycle, not complete cycle. But where is the preventive action in plan stage?
This is how I understand the cycle:
Plan – setting quality objectives
Do – Execution of plan, monitoring,
Check –Audit/review to verify effectiveness of plan and execution
Act – address lapses or re-plan
howste
Thaumaturge
#25
That's a pretty limited definition for plan. How do you "execute" objectives? If all you have is objectives established, with no anticipation of how to successfully achieve them, you are doomed to fail.
Example:
Plan: I want to catch fish at the lake (objective).
Do: I head toward the lake. Unfortunately I haven't anticipated the need for equipment such as a fishing rod, hooks, bait/lures, etc. I also ran out of gas on the way there because I didn't anticipate this failure mode. When I eventually got to the lake, I was given a ticket for fishing without a license.
Check: I checked and found that I caught no fish.
Act: I decide I'd better do a real plan next time, including anticipating how I would achieve the objective.
Don't you think that methods, controls, resources, etc. are part of the plan as well?
Y
Yarik
#26
According to a friend if we are going to consider the potential problem analysis (I guess he is referring to 8.5.3 Preventive action), E.W. Deming PDCA (Plan-Do-Check-Act) cycle’s methodology is lacking. It should be PDCAA (Plan-Do-Check-Act-Anticipate) cycle. Do you agree with the proposed methodology? I’ll appreciate your thoughts on this.
I don't think that PDCA cycle is lacking anything. IMHO, analysis of potential problems is just a part of the "Plan" step - the step when you are supposed to find/pick a problem to be solved and implement a solution that appears to be most appropriate. Whatever your friend means by "anticipation", it does not look like a true "peer" to the four existing steps - it looks more like one of the ways to discover a problem (hence, a part of the "Plan" step).
E
Ehsan Heidari
#27
I don`t get your meaning about "anticipation". would you explain it & it`s correlation with PDCA?:confused:
I think in Plan you must think about your goals, so anticipation the results of goals that you set the first time it`s important part of PLAN stage.On the other hand in the ACT you must to comparison goals and their result!
Totally I believe in "anticipation" is a part of plan.
P
Pankaj Kumar
#28
Do you think Shewart & Dr.Deming did not anticipate your suggestion to include extra 'A' for anticipation?!! IMHO it is trying to find fault where none exist.
Pankaj :nope:
P
Polly Pure Bread
#29
Ok I’m with you that ‘anticipate’ is part of the plan. However, there is no emphasis on ANTICIPATION given the definition below, thus it’s a good idea for the additional ‘A’.;)
PLAN
Establish the objectives and processes necessary to deliver results in accordance with the expected output. By making the expected output the focus, it differs from other techniques in that the completeness and accuracy of the specification is also part of the improvement.
DO
Implement the new processes. Often on a small scale if possible.
CHECK
Measure the new processes and compare the results against the expected results to ascertain any differences.
ACT
Analyze the differences to determine their cause. Each will be part of either one or more of the P-D-C-A steps. Determine where to apply changes that will include improvement. When a pass through these four steps does not result in the need to improve, refine the scope to which PDCA is applied until there is a plan that involves improvement.
#30
There is a great deal of information that's not emphasized or explicitly stated in PDCA. This is the essential folly of DMAIC, which takes a simple concept, assumes that people are too blind to see the bloody obvious and adds needless complication (as if, for example, we're not perceptive enough to know that some form of measurement might be necessary). If a plan is made without anticipating things that might go wrong with it, you have a poor plan and probably a poor planner. You can tack on all 26 letters of the alphabet and it won't change the fact that some things are (or should be) self-evident. If people don't know how to plan, teach them.
V Internal Audit using Plan, Do, Check, Act - Way to go? Internal Auditing 11
M How do other companies institutionalize the Plan Do Check Act process? IATF 16949 - Automotive Quality Systems Standard 4
Y Training Video/ video clips for PDCA (Plan - Do - Check - Act) Training - Internal, External, Online and Distance Learning 11
A PDCA (Plan Do Check Act) vs. DMAIC (Define Measure Analyze Improve Control) Quality Tools, Improvement and Analysis 24
K PDCA - Plan Do Check Act Cycle - What is PDCA? Quality Tools, Improvement and Analysis 3
Q Chrysler required FMEA and Control Plan Document Audit Forms and Process Audit Check FMEA and Control Plans 7
F Generic control plan - Check Part to Print FMEA and Control Plans 15
Jimmy123 IATF16949 Control Plan FMEA and Control Plans 1
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 3
D Quality plan for moving locations ISO 13485:2016 - Medical Device Quality Management Systems 3
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
A Prototype control plan FMEA and Control Plans 2
S ISO9001:2015 Implementation / update plan template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Do I need a "State of the art" plan? CE Marking (Conformité Européene) / CB Scheme 1
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
L Sampling Plan Risks AQL - Acceptable Quality Level 6
Felony Melony Project Milestone Plan-Development to Mass Production APQP and PPAP 2
Q Contingency plan - IATF Sanctioned Interpretation 17 IATF 16949 - Automotive Quality Systems Standard 4
D Continuous Improvement Plan - Plastic injection molding IATF 16949 - Automotive Quality Systems Standard 1
M IVDR and Performance Evaluation Plan CE Marking (Conformité Européene) / CB Scheme 2
A The requirement of the PMS plan--suitable indicators and threshold values EU Medical Device Regulations 0
E BCP (Business Continuity Plan) Call Tree Business Continuity & Resiliency Planning (BCRP) 13
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
B Biological evaluation plan and report Other Medical Device Related Standards 5
B Sterilization Validation Plan Other Medical Device Related Standards 3
R Electrical contractor Project Quality Management Plan Quality Manager and Management Related Issues 1
M Clinical Development Plan - Advice Requested EU Medical Device Regulations 11
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
D All Dimensions listed on control plan FMEA and Control Plans 10
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Q Internal audit plan template Internal Auditing 12
C Gobys for operations documentation plan Oil and Gas Industry Standards and Regulations 4
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
K %GRR was between 10-30% so we have to have a "backup plan" per auditor IATF 16949 - Automotive Quality Systems Standard 15
R Reduced sampling plan for sterial products APQP and PPAP 0
S PMS (Premarket Submission) and PMCF Plan EU Medical Device Regulations 5
M Clinical Evaluation Plan vs. PMCF Plan EU Medical Device Regulations 29
qualprod Corona virus Contingency plan - What have you done in your company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
J Requested Validation plan and reports Manufacturing and Related Processes 4
