Plane measurement with a 3D touch machine like a CMM.
Dear all,
about planes measurements, usually is used the best-fit algorithm to consider the plane constructed, but especially for coupling functions, the plane that have to be considered is the figure created with the 3 points higher founds and not on the same side and too closed, so, how can be calculated such type of plane?
Is there a method, already normed maybe, to construct that such of plane?
Is it normed? Is the method how to get it described somewhere?
Is that algorithm normally diffused on 3D measurement software?
Proud can you help to go on with the issue? Or someone else?
Thank you, I need to give information to my Renishaw CMM service, with Modus software it seems to be not implemented, so only approximated plane or max and min. point to point calculation can be made, unfortunately.
Please, can someone help to clarify how is the outer tangent plane calculation method?
How can be implemented as DMIS programming code to get it, if the CMM software in use has not the function to calculate at his own it?
It would be very appreciated for an help from someone, I'm not able to find anything in Google about it.
Thank you for the support.
Hi Marco,
this is described in ISO 5459:2011 (worldwideweb .(dot) iso.org/standard/40358.html). After fitting plane with Chebyshev algorithm, you move outwards material for the amount of half form error.
Do you have a specific callout on a drawing to discuss?
Hi Marco,
Wow, thank you so much Cristiano, this is the information I wanted to get for a long time!
About the drawing requests, no I haven't, because the drawings from R&D of my Company are still missing the latest GD&T descriptors, related to the ISO 14405-1.
However, the distances quoted in the drawing, if related to particular requirements like the one I'm on about ATEX certification of a specific product group, need strict quality rules, to avoid portion surfaces out of specs.
However, in general for distances, highness measurements, the outer plane is always the real situation we need to evaluate the plane, coupling something there, only the outer plane is the real end coupling surface that the other part finds.
Isn't it?
The formula to get it then, could be schematically represented by: Chebyshev plane + 1/2 flatness error?
J Drawing Example Request: Inspection Section Plane of Aluminum Casting Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Flatness measured to locations of a plane Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ajit Basrur Malaysia Airlines Plane May Have Crashed - March 2014 Travel - Hotels, Motels, Planes and Trains 47
V CMM plane construction method types and accuracy differences for measuring Pos Tol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B Any suggestion on creating the best paper plane that can hit a target perfectly? Coffee Break and Water Cooler Discussions 2
F Besides using the CMM - Checking perpendicularity between a plane and an OD Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
K 100 years war aviation - A plane is used for bombing World News 3
F Reason a plane would have a runout applied and not a flatness callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Perpendicularity-Axis and Plane - Perpendicularity call-out on the print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J IPC-A-610 E Thermal Plane Acceptance Criteria for D-Pak Component Other ISO and International Standards and European Regulations 2
Jim Wynne Breaking News: FAA Announces Ban on Plane Crashes Funny Stuff - Jokes and Humour 7
K Measurements - Sphere in contact with a plane General Measurement Device and Calibration Topics 3
Marc Florida Professor Arrested for Having a "Suspicious" Bagel on a Plane Travel - Hotels, Motels, Planes and Trains 14
Marc Tour of Manhattan from a Radio Controlled (RC) Plane Coffee Break and Water Cooler Discussions 4
J True Position with only 1 Datum - Referenced datum is the plane the hole is on Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
K Never been this close to a plane crash... Coffee Break and Water Cooler Discussions 38
Marc Plane Delay Leaves Hundreds Whiney Travel - Hotels, Motels, Planes and Trains 0
B Building my own measurement equipment General Measurement Device and Calibration Topics 3
P Test Method Validation (TMV) for all Measurement Methods in Rec/Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
J Keyence Measurement Systems General Measurement Device and Calibration Topics 3
Q Measurement Equipment Revocation - Looking for a Disposal Form with Risk Assessment IATF 16949 - Automotive Quality Systems Standard 10
C IVD Metrological traceability without a reference measurement procedure General Measurement Device and Calibration Topics 11
E Any template/ form of Monitoring and Measurement of Processes and product to ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 1
A Flexible "Ring" Roundness Measurement General Measurement Device and Calibration Topics 2
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
F Physical Part Measurement General Measurement Device and Calibration Topics 6
B ISO 6508 and portable hardness measurement instruments General Measurement Device and Calibration Topics 0
Ron Rompen Measurement of residual magnetism General Measurement Device and Calibration Topics 2
M Surgical angle measurement guide device with an application software Medical Device and FDA Regulations and Standards News 4
M Disabling measurement data during fault conditions IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
J Most versatile measurement device General Measurement Device and Calibration Topics 2
P Surface scratch measurement General Measurement Device and Calibration Topics 1
P Thermo-Hygrometer - Measurement of 10DegC @10%RH ISO 17025 related Discussions 4
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
K Best Measurement Systems Demos in California? General Measurement Device and Calibration Topics 1
K Process Mapping - Inputs/Outputs/Detail Activities/Control points/Measurement? Process Maps, Process Mapping and Turtle Diagrams 4
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
M Defining frequency of measurement tools callibration Calibration and Metrology Software and Hardware 3
T How to “validate/qualify” a new measurement equipment? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Bev D Verification and Validation of Measurement Systems Misc. Quality Assurance and Business Systems Related Topics 0
F How do you add accuracies for tools with different measurement devices? General Measurement Device and Calibration Topics 1
M Viable count Measurement ISO Standard Other Medical Device Related Standards 1
