Planning vs. Quality Buyoff - AS9100
paultyler
I need some help with an issue. Let me give some back ground first on our process.
In the company I work we use a work order system to control the process of making parts (aerospace industry). The work order has all the planning sequences included to provide traceability of the entire process of making the part. Once the planning is completed per the customer requirements and documented on the work order then someone approves the planning as documented.
However, the issue is that the same person that does the planning is approving the planning. Is this or will this be a concern during an AS 9100 audit?
howste
Thaumaturge
Re: Planning vs Quality Buyoff
There is nothing in AS9100 specifically prohibiting this. Although I believe it's always a good idea to have someone else doublecheck my work. You may expect to be questioned about it, so be prepared to show how you meet requirements if asked.
The relevant AS9100 requirements I see are these:
The requirement in 4.2.3 is that the organization must determine (and document in a procedure) the controls needed to "approve documents for adequacy prior to issue." It doesn't say who should approve them.
Clause 5.5.1 says that responsibilities and authorities must be defined and communicated. This includes who has authority to approve planning documents.
Clause 6.2.1 requires that personnel performing work affecting product quality must be competent based on education, training, skills, and/or experience. This includes personnel generating and approving planning. See also 6.2.2.
Clause 7.5.1.1 says that production operations have to be carried out in accordance with "approved data" but again it doesn't say who should approve it (see 5.5.1).
paultyler
Thanks for the help. I kinda figured that the standard didn't require some one else to check the planning. I read and read it and couldn't find anything. However, I was curious if an auditor might question it. If anyone has ever experience this, what was the outcome? Did an auditor note this as a non-conformance or observation?
I will be going through my first AS9100 audit as a quality manager in Sept. I have been through ISO type audits and HACCP audits before, but this my first AS9100.
Coury Ferguson
Moderator here to help
My :2cents:. Even though there is no specific requirement in AS9100, it is good business practice to have a Checker (QA) to make sure that all of the Customer's Quality Requirements are flowed down to the floor level.
Take for a example: Sikorsky Aircraft (Part of UTC) have hardware that is identified as "Flight Safety Hardware" and the planning once generated by the organization, needs to be approved by Sikorsky and then it is "Frozen." Any changes will have to be submitted to Sikorsky for approval.
Does the Planner really understand the meaning of Flight Safety (or any other quality requirement flow down), would be one question.
It has been a few years since I was involved with Sikorsky and maybe those requirements have changed.
This is just my opinion.
domingue
You should be ok. As long as your documentation states who has the authority to do the checking, and you have some objective evidence that that person has the knowledge/expertise/training to do it, then I don't see any problem with it. At my last job, I made it through an AS9100 audit with similar procedures (not with Work Orders specifically, but with other documents).
As howste mentioned though, having someone else check your work is usually a good policy, even if it's not required.
Stijloor
Does the Planner really understand the meaning of Flight Safety, would be one question.
Coury,
Are you referring to this document from UTC?
Stijloor.
Coury Ferguson
Coury,
Stijloor.
That is one of them. Basically I was using them as an example, nothing more. However, these will be flowed down to any supplier involved in UTC Corporation. This just supports my :2cents: in regards to having a checker (QA) review planning, even though AS9100 isn't specific about that.
Thanks for the Link Stijloor.
H Quality planning sign-off in AIAG APQP Manual IATF 16949 - Automotive Quality Systems Standard 5
Sidney Vianna Informational APQP4Wind - Advanced Product Quality Planning for the Wind Power Supply Chain APQP and PPAP 3
T 21 CFR 820.20 - Quality Planning Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
E Resources for Planning for top quality Business Continuity & Resiliency Planning (BCRP) 6
M Master Dot for quality planning/improvement Manufacturing and Related Processes 1
Sidney Vianna AS9100 News PPAP in the Aerospace Sector - What is it? AS9145 - Requirements for Advanced Product Quality Planning and Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S ISO 13485 Cl. 5.4.2 - Is Documented Quality Planning required? ISO 13485:2016 - Medical Device Quality Management Systems 2
Sidney Vianna SCMH Awareness Webinar Focused on the revised Advanced Product Quality Planning APQP AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Can you help me on manpower planning for Supplier Quality Engineers ? Misc. Quality Assurance and Business Systems Related Topics 4
A Risk Based Internal Quality Audit Scheduling and Planning Internal Auditing 2
M Product Quality Planning Resposibility Matrix (APQP manual page 2) APQP and PPAP 3
T Plant Start-Up - Planning and Implementing Quality Systems for a New Facility Manufacturing and Related Processes 3
K Global Quality Department Organizing and Planning Quality Manager and Management Related Issues 3
T How to Establish Internal Quality Control Planning APQP and PPAP 4
C Product Quality Planning Summary and Sign Off Sheet APQP and PPAP 3
J Annual Strategic Planning Session - How can a Quality Manager contribute? Quality Manager and Management Related Issues 4
T Our products are Security Cabinets - FMEA & Control Plan Quality Planning help FMEA and Control Plans 1
J ISO 9001 Clause 5.4 - Quality Planning requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Is Planning an AS9100 Quality Document? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
B Quality Planning process map - Struggling to define all the inputs and outputs Process Maps, Process Mapping and Turtle Diagrams 17
Y Definition Does "quality planning" include "establishment of quality objectives"? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 14
J Toyota's quality planning and quality management system documents Document Control Systems, Procedures, Forms and Templates 5
D Visible Planning & Barashi for Quality and Costs Design and Development of Products and Processes 2
F Strategic Planning and Quality Management System Integration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
R Quality Planning - What tools we need to use to perform quality planning? Quality Manager and Management Related Issues 2
G APQP (advanced product quality planning) for cable assemblies APQP and PPAP 1
A When do you start the Advanced Product Quality Planning (APQP) Process? APQP and PPAP 10
N FMEA Approach to Quality Planning - How can it be applied? FMEA and Control Plans 1
D Quality Planning Standard needed - ISO 10005:2005 - Guidelines for Quality Plans? Other ISO and International Standards and European Regulations 3
M Key characteristics in the Quality Planning Operational Procedure Document Control Systems, Procedures, Forms and Templates 3
H Planning of Product Realization (Quality Plans) - Clause 7.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
E Audit of Exclusions et.al. - Quality Policy, Planning (including objectives), Etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Why Quality Planning Fulfills Objectives, Quality Control Fulfills Requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R APQP Appendix F - Product Quality Planning Summary And Sign-off APQP and PPAP 9
J Auditing 5.4.2 Quality System Planning General Auditing Discussions 4
J ISO CL 5.4.2 Quality Management System Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Looking at 21 CFR 820.20 which calls out in section (d) for Quality Planning ISO 13485:2016 - Medical Device Quality Management Systems 2
D APQP (Advanced Product Quality Planning) - Seeking a simple, effective format Document Control Systems, Procedures, Forms and Templates 6
P 5.4 Quality objectives and planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M ISO 9001 - Quality Planning Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Planning of Realization Processes - Setting Quality Objectives - ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A 5.4.2 Quality Planning - What are they looking for here? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Different "levels" of quality planning and the related documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Seeking: Generic Template or Form for Quality Planning Document Control Systems, Procedures, Forms and Templates 2
Marc Definition Quality Planning: What is Quality Planning? Definition discussion Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
T PMCF Planning : Only Literature screening qualify? EU Medical Device Regulations 5
G IATF NC - Contingency Planning IATF 16949 - Automotive Quality Systems Standard 2
DuncanGibbons Process flow & PFMEA for production planning and simulation activities? Process Maps, Process Mapping and Turtle Diagrams 9
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V Clause 7.1.3.1 Plant, facility, and equipment planning Lean in Manufacturing and Service Industries 0
