Plastic Dip for Low Use Gages - Does it work?
alspread
#11
Re: Calibration experience - Plastic dip for low-use gages
I thought the discussion was about rigid metal gages like plug gages, thread gages, ring gages, etc. I wouldn't think you'd use a plastic dip for micrometers, calipers, multimeters, or sphygmomanometers...
Now there's a twenty dollar word!
howste
Thaumaturge
#12
It was either that or thermohygrometer. What can I say, my wife's a nurse... :lol:
MIREGMGR
#13
I apologize if I got things off track...I was just envisioning someone dipping something in Plastidip that wasn't at all suitable, based on a misunderstanding.
I think it is worth being clear that the suggested approach, whichever coating material one chooses to use, should be limited to metals.
smryan
Perspective.
#14
A picture is worth a thousand words - but only if others can see it. If only the picture in my mind's eye could be as easily transferred as text.:biglaugh:
Caster
An Early Cover
#15
Our calibration software has a check in - check out feature. If the gage is not in use (locked up in a cabinet), it stops the calibration tracking.
Very simple and could be done in a spreadsheet I would imagine.
We also used to use wax on our plug gages, and I kind of thought it smelled nice.
thallecnc
#17
Not affiliated with this company... only as a user of their products...
dipseal dot com (can't post links yet)
we use DS-300G
this is a 'hot' melting product approximately 350°F.
The coating has a protective oil in suspension. It does protect from damage (depending on applied thickness) and corrosion .
another source is
peelcoat dot com
brobinson
#20
The use of dipseal on gauges is very effective. We use this on primarily thread gauges, but have found use for other gauges. (i.e. OD micrometers, calipers) We currently have around 6,000 gauges we are calibrating at least once a year. The dip-seal has saved us time and money. After a calibration, most gauges are dipped (calibration-preserved). When the gauges time interval is due, if the integrity of the dip seal is intact, a note is made in the calibration that the results are "same as last calibration". Using the DS-300B type wax from dipseal dot com. We purchased a tank as well from them. We have been using this method for 1+ year and have not experienced any odor, or fires. The tank is used just outside the calibration lab in a well ventilated area as the supplier recommends.
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
D Measurables for Plastic Injection molding process Manufacturing and Related Processes 1
D Continuous Improvement Plan - Plastic injection molding IATF 16949 - Automotive Quality Systems Standard 1
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
D IMDS for Like Components (Interior Plastic, Leather/vinyl Armrest, etc.)other than Color APQP and PPAP 1
A Help establishing regulatory requirements - Plastic dental cartridge syringe US Food and Drug Administration (FDA) 0
C ABS plastic : which IEC 60601-1 tests to redo? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
A Glass and brittle plastic Policy - Required per FSSC 220002-4? Food Safety - ISO 22000, HACCP (21 CFR 120) 0
Nicole Desouza Plastic Extrusion of Medical Device Components - No ISO or AS 9100 Certifications Other Medical Device and Orthopedic Related Topics 7
Nicole Desouza AS9100D - Calibration of Dies & Tooling - Plastic Extrusion AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Fernando Drumond Calibration and Control of Plastic Volumetric Measurement Instruments General Measurement Device and Calibration Topics 1
erozas2003 Color test on molded plastic parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
M Informational 2019 Meeting Materials of the General and Plastic Surgery Devices Panel Medical Device and FDA Regulations and Standards News 0
M Informational The USFDA Announces General and Plastic Surgery Devices Panel of the Medical Devices Advisory Committee Meeting on March 25-26, 2019 Medical Device and FDA Regulations and Standards News 0
J Looking for FMEA plastic injection molding FMEA and Control Plans 8
John Broomfield Cleaning plastic from our oceans - The Ocean Cleanup Venture Sustainability, Green Initiatives and Ecology 33
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
A Cleaning plastic parts for sterilized medical devices ISO 13485:2016 - Medical Device Quality Management Systems 15
smryan Chemistry and physics of plastic behavior - Any plastics experts in the house? Coffee Break and Water Cooler Discussions 1
K Sampling Plan for transparent tubular plastic parts from 32 different cavities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
J Finishes on Plastic Molded Parts Manufacturing and Related Processes 9
D Hot Plate Welded Plastic Strength Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Testing Large Plastic Pipe Imported Legacy Blogs 0
L Product Requalification for Plastic Injected Parts APQP and PPAP 3
A Plastic Injection Molding Process Troubleshooting Guide Manufacturing and Related Processes 1
T Customer Requirement for Sorting - Visual Defect on Plastic Part IATF 16949 - Automotive Quality Systems Standard 9
M How to fix a plastic bag on leg with a bandage to take a shower Coffee Break and Water Cooler Discussions 15
M Kinds of plastic for molded parts in a main frame as structure Manufacturing and Related Processes 7
M Best Type of Grease for Vex Plastic Gears Manufacturing and Related Processes 5
M Lot Numbers of Plastic Disposables in an LDT (laboratory developed test) ISO 13485:2016 - Medical Device Quality Management Systems 6
S What is appropriate PPM level for a Plastic Injection Moulding Supplier Quality Tools, Improvement and Analysis 4
P Cross Section Issue - Dissecting a plastic part for measurement Manufacturing and Related Processes 4
N What Can I Do With Plastic Pellet Scrap? Manufacturing and Related Processes 17
K Plastic Resin designated as Significant Characteristic Manufacturing and Related Processes 7
S ECH (ethylene chlorohydrin) residues - Plastic catheter packed in a sterile bag Other Medical Device Related Standards 5
J Plastic Compatibility tests with the contact of mucous membranes Other Medical Device Regulations World-Wide 3
E Cosmetic Standard for Sheets of Extruded Plastic Manufacturing and Related Processes 1
F Plastic Injection Moulder - Design exemption from AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
Q Kraft Paper / Core Paper MSDS - Plastic Specs IATF 16949 - Automotive Quality Systems Standard 4
A Plastic Injection Molding - Post Mold Labeling Manufacturing and Related Processes 3
J Relative Humidity and Plastic Raw Material Moisture Manufacturing and Related Processes 4
T Plastic of an infusion pump enclosure and ISO 10993 ISO 13485:2016 - Medical Device Quality Management Systems 2
P Cosmetic Inspection of Plastic Injection Molded Parts Manufacturing and Related Processes 5
O Metrology Devices to Measure the Basic Dimensions of Plastic Specimens General Measurement Device and Calibration Topics 6
0 GMP Guideline for Recycled Plastic Flakes used in Food Applications Quality Manager and Management Related Issues 4
A Quality Plan for Plastic Industry for ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J SPC for Plastic Injection Molded parts Capability, Accuracy and Stability - Processes, Machines, etc. 8
J Weighing Balance Accuracy for Plastic Moulded Parts variation study Manufacturing and Related Processes 3
