Plastic Injection Molding - Post Mold Labeling
Avogel
Post mold our part is still warm. During the next 24hrs (the cooling cycle), the part will shrink.
Does anyone know of a label product that will will either shrink with the plastic, or allow for that shrinkage and not pucker or wrinkle?
Currently we have to double handle our product after 24hrs to apply the label.
My goal is to find a label that will allow application right of the mold.
We use a number of different size labels.
Our product is returnable packaging, with kit trays, shipping containers. Mostly for automotive.
ScottK
Not out of the crisis
Re: Plastic Injection- Post mold Labeling
Google "in-mold labeling" or "in-mould labeling"
This was used just in blow molding when I was in the industry about 15 years ago, but it looks like it's expanded into injection molding.
kuyakut
If you want it labeled during molding process , try the in-mold labeling.
For most of automotive plastic parts that dont go for painting they use in-mold labeling.
Ronen E
Problem Solver
Moderator
In-mold labeling is an option, but it will require some investment in the equipment.
Looking at the process as it is:
Shrinkage due to cooling doesn't take 24 hours. It shouldn't take more than 15 minutes, unless the wall thickness is excessive (bad part design) or the ambient temp. is very high. Shrinkage over extended periods usually relates to post-molding crystallization of the polymer matrix - what sort of resin you use? In some cases (POM) it can continue shrinking for months, with an exponential decay rate. The best way to minimize this effect is to create favourable crystallization conditions in the mold. Usually this means a higher mold temperature (see resin manufacturer's recommendations) and longer cycle time, so there's a trade off. What usually happens is molders try to cut cost by using cooler molds to shorten cycle times, and end up having all sorts of dimensional stability / warpage issues.
Cheers,
Ronen.
D Measurables for Plastic Injection molding process Manufacturing and Related Processes 1
D Continuous Improvement Plan - Plastic injection molding IATF 16949 - Automotive Quality Systems Standard 1
J Looking for FMEA plastic injection molding FMEA and Control Plans 8
A Plastic Injection Molding Process Troubleshooting Guide Manufacturing and Related Processes 1
A Determining Critical Tests for my Injection Plastic Molding Supplier Reliability Analysis - Predictions, Testing and Standards 4
A Molding Release for Medical Plastic Injection Molded Parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Plastic Injection Tooling - Understanding Plastic Injection Molding Terms Manufacturing and Related Processes 4
S Machine Capability (Cm) for Plastic Injection Molding Capability, Accuracy and Stability - Processes, Machines, etc. 1
D Plastic Injection Molding: ISO9001 or ISO13485? Manufacturing and Related Processes 10
triathlonx13 Plastic Injection Molding Specification (Purchasing, Qualifying, validation) examples Document Control Systems, Procedures, Forms and Templates 2
Q Validation Guidance - Plastic Injection Molding Process Qualification and Validation (including 21 CFR Part 11) 42
T Value of Regression Analysis in a plastic injection molding atmosphere Statistical Analysis Tools, Techniques and SPC 4
O Sample RoHS Compliance Procedure for plastic injection molding needed RoHS, REACH, ELV, IMDS and Restricted Substances 2
P Short Molding Issue - Plastic Injection Molding from a Multi Cavity Mold Quality Manager and Management Related Issues 13
H Upgrading ISO 9001 to TS 16949 - Plastic injection molding company IATF 16949 - Automotive Quality Systems Standard 13
J Plastic Injection Molding Mold Change - PPAP Process Question APQP and PPAP 8
K Process FMEA (PFMEA) For Plastic Injection Molding - Seeking Example FMEA and Control Plans 17
V Six Sigma Project on Reducing Plastic Injection Molding Rejects Six Sigma 10
S What to manage after Plastic Injection Molding - Plastic Parts Manufacturing and Related Processes 15
G Plastic Injection Molding - Medical Devices - How to Clean Parts Please Manufacturing and Related Processes 7
H Benchmarks for Plastic Injection Molding - Let's Share! Benchmarking 18
M Plastic Injection Molding Process FMEA - Not sure how to start FMEA and Control Plans 14
K DFMEA (Design FMEA) - Plastic Injection Molding FMEA and Control Plans 2
M SPC from Each Cavity? Small Plastic Parts using Injection Molding Machine Statistical Analysis Tools, Techniques and SPC 5
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
S What is appropriate PPM level for a Plastic Injection Moulding Supplier Quality Tools, Improvement and Analysis 4
F Plastic Injection Moulder - Design exemption from AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
P Cosmetic Inspection of Plastic Injection Molded Parts Manufacturing and Related Processes 5
J SPC for Plastic Injection Molded parts Capability, Accuracy and Stability - Processes, Machines, etc. 8
somashekar How to technically describe a Plastic Injection Moulding Tool Manufacturing and Related Processes 3
B Multi Cavity Plastic Injection Mould SPC Statistical Analysis Tools, Techniques and SPC 4
B SPC on Weight of Plastic Injection Molded Parts - What variables affect my process Statistical Analysis Tools, Techniques and SPC 2
H How to integrate ISO/TS 16949 & ISO9001 Quality Systems - Plastic Injection Mold IATF 16949 - Automotive Quality Systems Standard 7
M Raw Material Handling & Mixing in Plastic Injection Moulding Manufacturing and Related Processes 5
F Making a REACH statement - Plastic Injection Moulding RoHS, REACH, ELV, IMDS and Restricted Substances 9
E Quality Manual needed (Plastic Injection Moulding) Quality Management System (QMS) Manuals 15
B PPAP for Class "A" Injection Molded Plastic Parts needed APQP and PPAP 5
L Injection moulding supplier control and data - Plastic head band Nonconformance and Corrective Action 2
R Shelf life of injection molded plastic components Reliability Analysis - Predictions, Testing and Standards 3
W Automotive Lot Traceability - Plastic injection molded part sub-components Records and Data - Quality, Legal and Other Evidence 5
P FMEA and Control Plan for Plastic Injection Moulding/Painting Process FMEA and Control Plans 13
M How to define Dimensional Tolerances for Plastic Injection Molded Parts Service Industry Specific Topics 11
K Costing work sheet for Plastic Injection Manufacturing and Related Processes 2
S Draft Angles (aka Draft Allowance) - Plastic Injection Molded Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
R Shelf Life for Injection Molded Plastic Parts RoHS, REACH, ELV, IMDS and Restricted Substances 5
S What is the shelf life of injection molded plastic parts? Manufacturing and Related Processes 2
S Color Management - Confirming Color for Injection Molded Plastic Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M How do I Calculate a Weight Tolerance? Plastic Injection Moulding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
N Machine tonnage required for plastic injection moulding process Manufacturing and Related Processes 4
P DOE sample on plastic injection moulding process needed Manufacturing and Related Processes 5
