Plastic of an infusion pump enclosure and ISO 10993
Dear Sirs.
I would like to help me to understand about the plastic material that we must use for the enclosure of our devices which are infusion pumps.
1) Should I take into account the standard ISO 10993 for the selection of plastic material of the enclosure. (The infusion pump could be in touch with the skin during handling but there no touch with the skin during infusion).
2) As the infusion pump is portable device , the power consumption is much less than 15W .
The temperature which mesured on the critical components is up to 40 C max. Should I take into account the flammability of the plastic of the enclosure.
Ronen E
Problem Solver
Moderator
Dear Sirs.
To answer your specific questions:
1) I wouldn't worry too much about ISO 10993 in this context. At most, the 3 basic tests will be required: Cytotoxicity, Irritation & Sensitization, which are not too expensive or lengthy. If you are intending to market in the USA, try to identify a predicate (similar device already legally on the USA market) and it's enclosure material, and go from there. Another thing to do is ask the raw material suppliers whether the offered materials are in use in similar applications and/or have been tested for the above.
2) Based on the characteristics of your pump, try to determine the FDA classification (even if you don't target the USA market). Then go to the applicable ProCode page and consult the guidance documents and standards. For example: http://www.accessdata.fda.gov/scripts/cdrh/cfdocs/cfPCD/classification.cfm?ID=2377
I expect that anyway you will have to address falmmability at some level, regardless of power source.
Guidance will also alert you to other issues you have to consider.
From a more general perspective, I suggest that if you are in the development stage, you try to follow an orderly design control process starting with a design plan and then capturing the design requirements (design inputs). materials selection is already a part of the actual design effort, that should follow after you have a clear and consistent requirements set. If you don't do that you risk ending up missing important aspects and/or selecting based on contradicting requirements (worse still, not even being aware of those contradictions). Here again FDA specific guidance may help you identify and properly address most of the relevant topics and requirements. The web also abounds with generic guidance and training materials on Design Control / best design & development practices.
Cheers,
Ronen.
D IMDS for Like Components (Interior Plastic, Leather/vinyl Armrest, etc.)other than Color APQP and PPAP 1
A Help establishing regulatory requirements - Plastic dental cartridge syringe US Food and Drug Administration (FDA) 0
C ABS plastic : which IEC 60601-1 tests to redo? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
A Glass and brittle plastic Policy - Required per FSSC 220002-4? Food Safety - ISO 22000, HACCP (21 CFR 120) 0
Nicole Desouza Plastic Extrusion of Medical Device Components - No ISO or AS 9100 Certifications Other Medical Device and Orthopedic Related Topics 7
Nicole Desouza AS9100D - Calibration of Dies & Tooling - Plastic Extrusion AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Fernando Drumond Calibration and Control of Plastic Volumetric Measurement Instruments General Measurement Device and Calibration Topics 1
erozas2003 Color test on molded plastic parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
M Informational 2019 Meeting Materials of the General and Plastic Surgery Devices Panel Medical Device and FDA Regulations and Standards News 0
M Informational The USFDA Announces General and Plastic Surgery Devices Panel of the Medical Devices Advisory Committee Meeting on March 25-26, 2019 Medical Device and FDA Regulations and Standards News 0
JT3M Looking for FMEA plastic injection molding FMEA and Control Plans 8
John Broomfield Cleaning plastic from our oceans - The Ocean Cleanup Venture Sustainability, Green Initiatives and Ecology 30
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
A Cleaning plastic parts for sterilized medical devices ISO 13485:2016 - Medical Device Quality Management Systems 15
smryan Chemistry and physics of plastic behavior - Any plastics experts in the house? Coffee Break and Water Cooler Discussions 1
K Sampling Plan for transparent tubular plastic parts from 32 different cavities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
J Finishes on Plastic Molded Parts Manufacturing and Related Processes 9
D Hot Plate Welded Plastic Strength Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Testing Large Plastic Pipe Imported Legacy Blogs 0
L Product Requalification for Plastic Injected Parts APQP and PPAP 3
A Plastic Injection Molding Process Troubleshooting Guide Manufacturing and Related Processes 1
T Customer Requirement for Sorting - Visual Defect on Plastic Part IATF 16949 - Automotive Quality Systems Standard 9
M How to fix a plastic bag on leg with a bandage to take a shower Coffee Break and Water Cooler Discussions 15
M Kinds of plastic for molded parts in a main frame as structure Manufacturing and Related Processes 7
M Best Type of Grease for Vex Plastic Gears Manufacturing and Related Processes 5
M Lot Numbers of Plastic Disposables in an LDT (laboratory developed test) ISO 13485:2016 - Medical Device Quality Management Systems 6
S What is appropriate PPM level for a Plastic Injection Moulding Supplier Quality Tools, Improvement and Analysis 4
P Cross Section Issue - Dissecting a plastic part for measurement Manufacturing and Related Processes 4
N What Can I Do With Plastic Pellet Scrap? Manufacturing and Related Processes 17
K Plastic Resin designated as Significant Characteristic Manufacturing and Related Processes 7
S ECH (ethylene chlorohydrin) residues - Plastic catheter packed in a sterile bag Other Medical Device Related Standards 5
J Plastic Compatibility tests with the contact of mucous membranes Other Medical Device Regulations World-Wide 3
E Cosmetic Standard for Sheets of Extruded Plastic Manufacturing and Related Processes 1
F Plastic Injection Moulder - Design exemption from AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
Q Kraft Paper / Core Paper MSDS - Plastic Specs IATF 16949 - Automotive Quality Systems Standard 4
A Plastic Injection Molding - Post Mold Labeling Manufacturing and Related Processes 3
J Relative Humidity and Plastic Raw Material Moisture Manufacturing and Related Processes 4
P Cosmetic Inspection of Plastic Injection Molded Parts Manufacturing and Related Processes 5
O Metrology Devices to Measure the Basic Dimensions of Plastic Specimens General Measurement Device and Calibration Topics 6
0 GMP Guideline for Recycled Plastic Flakes used in Food Applications Quality Manager and Management Related Issues 4
A Quality Plan for Plastic Industry for ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J SPC for Plastic Injection Molded parts Capability, Accuracy and Stability - Processes, Machines, etc. 8
J Weighing Balance Accuracy for Plastic Moulded Parts variation study Manufacturing and Related Processes 3
J Moisture Detection and Measurement in Vacuum Oven (Plastic Dryness) General Measurement Device and Calibration Topics 2
DanteCaspian Plastic Card Printer: Looking for recommendations Coffee Break and Water Cooler Discussions 3
A Determining Critical Tests for my Injection Plastic Molding Supplier Reliability Analysis - Predictions, Testing and Standards 4
N How can you tell if Flame Retardant "kicks off" in plastic? Manufacturing and Related Processes 4
N What is the best way to check Plastic for Contamination? Manufacturing and Related Processes 8
