Plating standards - Where to find information
Michael_M
It looks like I might have to purchase the AMS 2417 Nickel plating standard. Currently this is at rev. J (09-2013). I have heard that standards get reviewed/revised every 5 years or so. I don't want to purchase if the standard is currently being revised or will be within the next few months.
Is there a website or information source that lists all the standards and when/if they are being updated/revised (and possibly when)?
Al Rosen
I got this information from the SAE website an d it looks like they recently started to review it for revision. It take some time for it to be revised or it may be reaffirmed without any change.
AMS2417K - Plating, Zinc-Nickel Alloy
Details
Not available for purchase at this time.
Document Number: AMS2417K
Project Initiation: 04-03-2018 Project Number:
Revision Number: K
Sponsor Name: Kevin Groeneveld
Title Plating, Zinc-Nickel Alloy Scope This specification covers the requirements for electrodeposition of a zinc-nickel alloy and the properties of the deposit. Rationale 5 year review
M Cosmetic defects on chrome plating - Chrome plating visual standards Manufacturing and Related Processes 6
K Silver Plating corroding possible during SMT Manufacturing and Related Processes 10
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
M Is Validation of Plating Processes required and who is responsible? Qualification and Validation (including 21 CFR Part 11) 11
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
T Corrosion in Bores after Zinc Plating machined Iron Castings in VCI Bags Manufacturing and Related Processes 1
R AS9100 DELTA FAI - Sub-supplier for plating changed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
V Plating Spec - Electro plating Manufacturing and Related Processes 3
C AS9102 Form 2 Information - Special Processes - Plating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R Outsourced Plating Supplier Responsibilities Service Industry Specific Topics 8
N Control of Metal Plating Baths - Contamination from base metals Service Industry Specific Topics 4
P Connector Tin Plating Peel-off during Soldering Manufacturing and Related Processes 7
J Clear Zinc Plating Corrosion issue...Need some education Manufacturing and Related Processes 4
D AS9100 FAI Form for Plating Document Control Systems, Procedures, Forms and Templates 7
B Plating Shop - Forums specifically related to the plating / metal finishing industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Determining if there is Tin Plating on an Aluminum Bar Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A SPC for Single Batch Nickel Plating Process Capability, Accuracy and Stability - Processes, Machines, etc. 5
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
J Zinc Plating Process NADCAP Certification Guidance please AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Galvanize and Chrome Plating Process FMEA wanted FMEA and Control Plans 2
M Developing a new Plating Vendor - What software to track certifications Software Quality Assurance 2
M Is That Plating Wave Washer will reduce its stiffness? Supplier Quality Assurance and other Supplier Issues 1
A Contact Resistance issue - Gold plating on PCB Manufacturing and Related Processes 3
V Interpreting Zinc Plating Specification GMW 3044 - 6K96/48 APQP and PPAP 2
M Copper Potassium Crystals forming on Switch Contact Silver Plating Manufacturing and Related Processes 2
P Tin Plating Issues - Yellowish Discoloration Manufacturing and Related Processes 7
I IMDS Warning - Chromate Filming of Zinc Plating RoHS, REACH, ELV, IMDS and Restricted Substances 4
M Plating - A quick, certifiable way to measure Plating Bath Temperature Manufacturing and Related Processes 3
V PPAP Requirements including GMW 3179 Zinc Plating Specification Requirements APQP and PPAP 3
V PPAP Requirements for Plating a "Family of Parts" APQP and PPAP 8
P Validation of Plating Process for Medical Devices Qualification and Validation (including 21 CFR Part 11) 8
M Pits on Plating of 440 Stainless Steel Manufacturing and Related Processes 6
P Metal Tape Plating Process - CQI-11 Required? IATF 16949 - Automotive Quality Systems Standard 2
V We put Old plating spec on supplier prints and need to PPAP to Customer. APQP and PPAP 1
V Supplier's First Run had Plating Problems - Can they Strip, Re-Plate and PPAP them? APQP and PPAP 14
V Plating Supplier PPAP Revalidation Requirements - A-Coat GM 9984132 Plating Process APQP and PPAP 1
C What is your point for the RoHS Control in Plastic Parts with Plating? IATF 16949 - Automotive Quality Systems Standard 1
T Plating and Metal Sheet Process Tour - What to focus on? Manufacturing and Related Processes 2
B Effect of Soldering on Tin Plating Manufacturing and Related Processes 5
R Special Process Checklists for Plating, Phosphate Coating, Welding and NDT AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Seeking CQI-11 (Special Process Plating Assessment) Training Training - Internal, External, Online and Distance Learning 4
L Outsourcing Special Processes such as Plating, Painting, NDT as related to AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
C What is the diff between 150a @ 12v and 150amp @ 6v rectifiers for plating? Manufacturing and Related Processes 1
S Silver Plating (Lots of questions) Manufacturing and Related Processes 8
T Tin Plating Issues - Oxidized and Rusty Terminals Manufacturing and Related Processes 8
R ASTM B633 Zinc Plating Specification - Transportation of parts by boat to China Manufacturing and Related Processes 1
C Calculating the Lead (Pb) ppm from the Plating Layer RoHS, REACH, ELV, IMDS and Restricted Substances 6
L Process controls on attribute data - Chrome plating manual buffing line Capability, Accuracy and Stability - Processes, Machines, etc. 10
