Plating Supplier Audit Checklist
K
Ken Stage
#12
I think you can access the Nadcap checklist for chemical processing (AC7108) and plating at the SAE, PRI or Eauditnet website. This is the aerospace checklist. You may have to register to get access, but I do not think there is a cost. Very detailed checklists.
Good Luck!:)
mhoggard
#13
Hello all,
We are a NADCAP certified company and have recently picked up some automotive work. The customer is asking to have a CQI-12 completed. The process is tin electroplating. The way I am reading it, CQI-12 is for coating assessment and CQI-11 is for plating assessment. Also, CQI-11 specifies zinc and zinc-alloy (galvanizing I assume). Is that all the assessment is concerned with (process tables B, C, D, E do not apply to us)? Thanks for helping clear the confusion.
F
fcardillo
#14
HI,
I'm sorry I can't help you. I am not that familiar with the AIG checklist and the Automotive plating requirements.
Frank
#15
Hello all,
I'm not familiar with the requirements you're referring to, but it's best to ask your customer what's expected because you might find that it's something other than what you can determine from the standards alone.
jasonb067
#16
CQI11 and or the intent of CQI11 should give you the information which you need to understand the problems you are facing.
Good Luck!
E Supplier audit checklists for special processes - Plating Process audit Checklist Process Audits and Layered Process Audits 2
R AS9100 DELTA FAI - Sub-supplier for plating changed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R Outsourced Plating Supplier Responsibilities Service Industry Specific Topics 8
V We put Old plating spec on supplier prints and need to PPAP to Customer. APQP and PPAP 1
V Supplier's First Run had Plating Problems - Can they Strip, Re-Plate and PPAP them? APQP and PPAP 14
V Plating Supplier PPAP Revalidation Requirements - A-Coat GM 9984132 Plating Process APQP and PPAP 1
K Silver Plating corroding possible during SMT Manufacturing and Related Processes 10
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
M Is Validation of Plating Processes required and who is responsible? Qualification and Validation (including 21 CFR Part 11) 11
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
T Corrosion in Bores after Zinc Plating machined Iron Castings in VCI Bags Manufacturing and Related Processes 1
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
M Plating standards - Where to find information AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
V Plating Spec - Electro plating Manufacturing and Related Processes 3
C AS9102 Form 2 Information - Special Processes - Plating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
N Control of Metal Plating Baths - Contamination from base metals Service Industry Specific Topics 4
P Connector Tin Plating Peel-off during Soldering Manufacturing and Related Processes 7
J Clear Zinc Plating Corrosion issue...Need some education Manufacturing and Related Processes 4
D AS9100 FAI Form for Plating Document Control Systems, Procedures, Forms and Templates 7
B Plating Shop - Forums specifically related to the plating / metal finishing industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Determining if there is Tin Plating on an Aluminum Bar Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A SPC for Single Batch Nickel Plating Process Capability, Accuracy and Stability - Processes, Machines, etc. 5
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
J Zinc Plating Process NADCAP Certification Guidance please AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Galvanize and Chrome Plating Process FMEA wanted FMEA and Control Plans 2
M Developing a new Plating Vendor - What software to track certifications Software Quality Assurance 2
M Is That Plating Wave Washer will reduce its stiffness? Supplier Quality Assurance and other Supplier Issues 1
A Contact Resistance issue - Gold plating on PCB Manufacturing and Related Processes 3
V Interpreting Zinc Plating Specification GMW 3044 - 6K96/48 APQP and PPAP 2
M Copper Potassium Crystals forming on Switch Contact Silver Plating Manufacturing and Related Processes 2
P Tin Plating Issues - Yellowish Discoloration Manufacturing and Related Processes 4
I IMDS Warning - Chromate Filming of Zinc Plating RoHS, REACH, ELV, IMDS and Restricted Substances 4
M Plating - A quick, certifiable way to measure Plating Bath Temperature Manufacturing and Related Processes 3
V PPAP Requirements including GMW 3179 Zinc Plating Specification Requirements APQP and PPAP 3
V PPAP Requirements for Plating a "Family of Parts" APQP and PPAP 8
P Validation of Plating Process for Medical Devices Qualification and Validation (including 21 CFR Part 11) 8
M Pits on Plating of 440 Stainless Steel Manufacturing and Related Processes 6
P Metal Tape Plating Process - CQI-11 Required? IATF 16949 - Automotive Quality Systems Standard 2
C What is your point for the RoHS Control in Plastic Parts with Plating? IATF 16949 - Automotive Quality Systems Standard 1
T Plating and Metal Sheet Process Tour - What to focus on? Manufacturing and Related Processes 2
B Effect of Soldering on Tin Plating Manufacturing and Related Processes 5
R Special Process Checklists for Plating, Phosphate Coating, Welding and NDT AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Seeking CQI-11 (Special Process Plating Assessment) Training Training - Internal, External, Online and Distance Learning 4
L Outsourcing Special Processes such as Plating, Painting, NDT as related to AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
C What is the diff between 150a @ 12v and 150amp @ 6v rectifiers for plating? Manufacturing and Related Processes 1
S Silver Plating (Lots of questions) Manufacturing and Related Processes 8
T Tin Plating Issues - Oxidized and Rusty Terminals Manufacturing and Related Processes 8
R ASTM B633 Zinc Plating Specification - Transportation of parts by boat to China Manufacturing and Related Processes 1
C Calculating the Lead (Pb) ppm from the Plating Layer RoHS, REACH, ELV, IMDS and Restricted Substances 6
