Please clarify the Rule of 10 to 1 - AND - What is the ndc number?
Allattar
#61
I would have to think a lot on that one, and afraid I may not be clever enough to come up with such a test :).
We do have a number the NDC, we have a goal > 10, we also have a number of samples, and operators. Hence we have values for degrees of freedom. Some kind of one sided test comes to mind.
I am aware the last comment was not aimed at me directly though :)
bobdoering
Stop X-bar/R Madness!!
#62
True. Those that use Wheeler's approach to gage decision also need to consider that they are achieving 10 statististically discreet categories within the control limits. So, yes...any way you get there, you need to get there! :tg:
jee2006
#63
The "10:1 rule" is a guideline in metrology. Broadly speaking, your measuring instrument chosen should be accurate (not just discriminate) to 1/10th of the tolerance.
In other words, if you have a feature with a tolerance of 0.010", your measuring instrument should be accurate to no less than 0.001".
Unfortunately, I have no idea what 'ndc' is, out of context. What book are you using? There may be some of us here who have the same one, or by the same author, and can extrapolate the meaning from that information.
:applause:
I liked the good answer you gave on the question. But to make it further clear, will you explain it with a numeric example. Say the measurement equipment has the least count of 10 and the specification is ±50. In this case what would be the P/T calculation?
Thanks, Regards
jee2006
DonDowns
#64
I ran into this debate in my shop not only between manufacturing and inspection, but also with customer source inspectors. I resolved it by using ASTM E 29, which ended the debate. I hope this helps.
ASTM E 29 Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications.
Hershal
Metrologist-Auditor
#66
Actually, the 10:1 rule has changed since its original debut, just like the 4:1 rule. Now, one needs to know whether the discussion is TAR or TUR, and they are different.
The original, going back to the old MIL-STD-45662 and 45662A, uses a TAR, or test accuracy ratio. That is, the standard would be ten times more accurate than the item it is used to calibrate.
However, the TUR, test uncertainty ratio, uses the uncertainty of the standard and compares it to the tolerance of the item being calibrated. So, for the 10:1, the standard's uncertainty is only 1/10 of the tolerance for that measurement of the item being calibrated.
That can be a challenge at times as a standard may be able to deliver the 10:1 or 4:1 TUR on most points, but maybe not all.
N 7.5.2.1 Validation of the Application of the Computer Software - PLEASE CLARIFY ISO 13485:2016 - Medical Device Quality Management Systems 9
Crusader 4.2.4 Control of Records - Can someone please clarify "...and disposition of records" Records and Data - Quality, Legal and Other Evidence 7
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
Ronen E Can anyone please explain this? (510k submission requirement) Other US Medical Device Regulations 14
A Please explain MDR Rule 11 to me EU Medical Device Regulations 67
R Please share your method used for PEMS Validation IEC 62304 - Medical Device Software Life Cycle Processes 5
Sidney Vianna Interesting Discussion Hello IAF. Are you listening? Please explain the inconsistency in your IAF Mandatory Documents (2019) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
optomist1 Share a DFMEA template please Document Control Systems, Procedures, Forms and Templates 2
alonFAI Please share a medical device company NCMR procedure Other Medical Device Related Standards 4
B Will you please help me with my academic project? Repair & calibration service for test equipment ISO 17025 related Discussions 0
J Medical Device Vigilance decision tree FORM - Please share yours EU Medical Device Regulations 14
Marc Posting Job Openings - Read Me Please - 27 January 2019 Job Openings, Consulting and Employment Opportunities 0
L Please help me with the process of getting ISO 9001 certified Quality Management System (QMS) Manuals 15
K Please help identify appropriate statistical treatment Statistical Analysis Tools, Techniques and SPC 13
L Please review my ISO 9001:2015 Internal Audit Plan Process Audits and Layered Process Audits 6
C Will anyone please share training material for ISO:13485:2016 for best practices Training - Internal, External, Online and Distance Learning 0
LeonelAguilar352 ISO 9001 - 2015, is the Quality Manual needed? Please advise ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Please Help! what is ARL for the range and standard deviation Statistical Analysis Tools, Techniques and SPC 0
E Best GD&T training - Your suggestions and recommendations please Training - Internal, External, Online and Distance Learning 3
R Please help me with attached copy of AS 9100D internal audit check sheet AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
S Supplier Classifications - Please give me a good definition of the following terms ISO 13485:2016 - Medical Device Quality Management Systems 5
L Please help my division with quality [long] Service Industry Specific Topics 1
J Please help me understand what a process is ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T From 21 CFR to IEC 60601 - Please explain IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Please share your IATF 16949 Internal Audit Plan and Schedule Internal Auditing 13
M MDSAP Audit Plan - Please share an Audit Plan/Schedule/Agenda ISO 13485:2016 - Medical Device Quality Management Systems 7
J Please Recommend books that explain how to understand IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
S New Interaction of Processes ISO 9001:2015 - Please Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M New Quality Policy for ISO 9001:2015 - Please Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Please share a Product Audit Checklist for a Wafer Fab Document Control Systems, Procedures, Forms and Templates 3
Moncia Complaint / Non-Conforming Product / CAPA Procedures - Please share your experience ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Please explain the following Automotive Acronyms IATF 16949 - Automotive Quality Systems Standard 3
V Revised ISO std vs ISO13485:2003 - Help Please!!! ISO 13485:2016 - Medical Device Quality Management Systems 4
S Please recommend any good training courses for Medical Device Regulations Training - Internal, External, Online and Distance Learning 8
E Supplier Evaluation Form - Example to evaluation suppliers (criteria) please Document Control Systems, Procedures, Forms and Templates 4
S Please review my Risk Analysis Table ISO 14971 - Medical Device Risk Management 13
somashekar MDSAP (Medical Device Single Audit Program) Pilot: Please share your feedback ISO 13485:2016 - Medical Device Quality Management Systems 35
L Canadian Users of ISO 14001 please contact me ISO 14001:2015 Specific Discussions 4
L Newly API Q1 9th Edition applicant HELP please =) Oil and Gas Industry Standards and Regulations 3
3 K1 K2 K3 constant of Gage R&R - Please advice Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Informational Please help this newbie understand ISO 9001 Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
Y Please help me solve a DOE problem - New Minitab User Using Minitab Software 36
R Please help with the construction of OC curves Using Minitab Software 7
M Please help to analyze Response Surface Methodology by using Minitab 16 Using Minitab Software 6
A Please suggest analysis for identifying the warranty Reliability Analysis - Predictions, Testing and Standards 1
Q Please suggest how to improve Cosmetic Visual Inspections Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
S Please Review my APQP Training Material APQP and PPAP 4
E Empty Test Tube Storage - Suggestions Please Manufacturing and Related Processes 8
