Informational Please help this newbie understand ISO 9001 Work Instructions
Ninja
Looking for Reality
#41
Seconding Andy (though I was never a machine operator)...
Functional: Any person competent to train can be a trainer.
For the QMS documentation...you have a choice: keep a running list of who is formally determined as "competent trainer" and use them to train or...formally allow anyone who is trained to the document to act as trainer.
You also get to determine if formal, specific training record is needed at all or if you meet the requirement some other way (blanket "machinists know how to machine stuff, that's why we hired them").
We did the latter...anyone trained to a document could act as trainer for the document, as long as the training date for the trainer preceded them signing off on training someone else.
That worked for the auditor...but didn't work perfectly in real life (poor training as a result, not everyone is a great teacher).
We ended up leaving the "if you are trained, you may be trainer", but then had a separate, informal list of "preferred trainers".
If I had it to do over again, I would likely do the same thing.
Establishing a list of "competent trainers" also establishes a list of "incompetent to train" by omission...and we ended up with disgruntled employees and angst. It was far easier to manage when it was 'known but undocumented'.
When I gave a new employee a list of processes/tests/WI to be trained to, I also wrote next to each one the initials of who I would allow to be the trainer. It worked well without causing significant angst...and met the requirement both functionally and to the letter.
HTH
Big Jim
#42
What matters is that those doing the work are competent. Other than they may gain competency from education, training, and experience the standard is silent on how they gain competency. It is up to you to determine how and to keep a record of how the competency was gained.
In other words, do what works for you.
Don't forget though that the organization needs to determine what competencies are needed. That is often shown on a job description but could also be from a job posting, skill list, or some other means.
It isn't rocket science.
tony s
Information Seeker
#43
Who is responsible (required) to train machine operators on the WI’s? QM, QT or can a floor supervisor or the operator who has a Technician/Leader Role?
IMHO, employees should not be trained on the WIs. What they need is knowledge specific to their job. WIs are just part of the materials to support the training of employees.
Big Jim
#44
Keep in mind that in the 2008 version work instructions were not required, but if you had them they needed to be readily available at the point of use. The wording changed in the 2015 version but the intent seems to be the same.
8.5.1a1-2 The organization shall implement production and service provision under controlled conditions . . . controlled conditions shall include, as applicable . . . the availability of documented information that defines . . . the characteristics of the products to be produced, the services to be provided, or the activities to be performed . . . the results to be achieved . . .
#45
And...don't forget that section 4 has to do with determining a number of things about your QMS which might drive the need for documentation. If you consider needs and expectations of interested parties, for example. Or internal issues...
N I have 2 groups to compare - Minitab and stats newbie - Please help Using Minitab Software 18
G Newbie in IMDS - Please help me understand what I have to do RoHS, REACH, ELV, IMDS and Restricted Substances 4
L VDA Product Submission Form - Please help a Cove newbie answer a VDA question VDA Standards - Germany's Automotive Standards 12
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
B Will you please help me with my academic project? Repair & calibration service for test equipment ISO 17025 related Discussions 0
L Please help me with the process of getting ISO 9001 certified Quality Management System (QMS) Manuals 15
K Please help identify appropriate statistical treatment Statistical Analysis Tools, Techniques and SPC 13
K Please Help! what is ARL for the range and standard deviation Statistical Analysis Tools, Techniques and SPC 0
R Please help me with attached copy of AS 9100D internal audit check sheet AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Please help my division with quality [long] Service Industry Specific Topics 1
J Please help me understand what a process is ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Revised ISO std vs ISO13485:2003 - Help Please!!! ISO 13485:2016 - Medical Device Quality Management Systems 4
L Newly API Q1 9th Edition applicant HELP please =) Oil and Gas Industry Standards and Regulations 3
Y Please help me solve a DOE problem - New Minitab User Using Minitab Software 36
R Please help with the construction of OC curves Using Minitab Software 7
M Please help to analyze Response Surface Methodology by using Minitab 16 Using Minitab Software 6
M Please help to change the numbering in level 3 of structure Document Control Systems, Procedures, Forms and Templates 1
D Please help for the CISSP (Certified Information Systems Security Professional) Exam Professional Certifications and Degrees 2
S Please help on ISO 13485 medical device related services Other Medical Device Related Standards 1
K Please help me to generate a Production Chart Manufacturing and Related Processes 4
R Please help me with Welding Symbols Manufacturing and Related Processes 5
I Please help me with some Templates Document Control Systems, Procedures, Forms and Templates 2
S Please help me define training requirements for a Career in Regulatory Affairs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B Help with NDC (Number of Distinct Categories) Please Six Sigma 2
N If ew(t)=2339, how do I find T? Please help on Maths Problem Brain Teasers and Puzzles 3
C Clarification On Internal Auditor Requirements - Please help Internal Auditing 10
P ISO 9001:2008 Gap Analysis Template - Please help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Product Realisation Process Map - Need some help, please review and comment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Please help me interpret my GR&R results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Can anybody help me with Management Review scenario please? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
V Help needed with ISO 14001 Procedures please ISO 14001:2015 Specific Discussions 7
C I'm from Malaysia, just graduate 1 year - Looking for a job...Please help me. Career and Occupation Discussions 3
K Please help Calculate Audit Man Days Process Audits and Layered Process Audits 8
B 5 Why help needed Please kindly review Problem Solving, Root Cause Fault and Failure Analysis 15
D Please help to set Weighing Indicator SI4010R General Measurement Device and Calibration Topics 1
B Green Initiative - Please help me in preparing Go Green Steps.... Sustainability, Green Initiatives and Ecology 6
Ron Rompen Shiftwork Scheduling - An unusual problem - Need help please Human Factors and Ergonomics in Engineering 13
S Opening Up Tolerances - We have over 6000 live drawings - help please Design and Development of Products and Processes 6
N Help please - Mechanical Latch Design Principles? Design and Development of Products and Processes 2
K Scoring Scale for Internal Audits - Please help finding the right terms Internal Auditing 44
D Need some help with a formula in Excel Please! Excel .xls Spreadsheet Templates and Tools 11
T Help With GR&R (Gage R&R) on JMP ***JMP people please help*** Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M 'Searched' virus? Cannot delete folder - HELP please After Work and Weekend Discussion Topics 33
G Hazardous Waste Consignment Note - Please Help Miscellaneous Environmental Standards and EMS Related Discussions 2
R Please help us to understand clause 5.5.2 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Please help me to convert from ISO9001 to ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
J Contract Review - Please help me define the requirement 7.2.2 Info needed Contract Review Process 9
C Help me out please - Trig diameter question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
M Implementing TS 16949 in a new stamping plant - Help please IATF 16949 - Automotive Quality Systems Standard 4
