Please help to analyze Response Surface Methodology by using Minitab 16
Minhanh
Hi everyone,
I am doing an optimization experiments with 3 factors at 3 levels of each variables, and I used Box-Benken design to design my experimental works. Total 15 runs was done and unfortunately, I do not know how to fit my data to the second-order popolynomial equation.
I did some preliminary analysis by Minitab 16, however I get so confusing that the model is fit or not best fit may data based on R-square, adjusted R-square and Lack of fit.
Please help me to explain more for me these issues. Many thanks for your kind helps:thanx:
Re: Please help to analysis response surface methodology by using MInitab 16
You will either need to provide more information or attach your Minitab project file for assistance.
Minhanh
Thanks so much for your kind helps.
I would like to attach a Minitab project file for you have a look.
I did this experiment with expectation to observe how 3 factors effect to my measurements and their interactions if any. In addition, I would like to fit my data to a full quadratic model. It seems like that my data does not fit well. So if does not fit, should I plot contour/surface plot and do optimization? Please give me advice for this.
Thank you very much:thanks:
I reviewed your experiment. The reason that you are unable to fit a model is that none of the model terms are statistically significant. The pure error term is very large compared to the factors. This is evidenced by the high p-values and low R^2(adj) and R^2(pred) even after simplifying the model.
There are a number of possibilities for this:
  1. The levels selected for each factor might not be sufficient. While I do not know the units used for each factor the relative magnitude of the number seem to make this possibility unlikely.
  2. The measurement system used to evaluate the response is inadequate. That is the measurement variation swamps any potential effect.
  3. The factors have no effect on the response.
Minhanh
Hi Miner,
Thank so much for taking your time and patient to explain to me my data analysis. Much appreciate your kindness:)
I still have little thing to wonder. Please help me get understand on it. As you explained, when we fit data to a model, we should consider to Lack of fit, R-square and adjusted R-square.
1. If R-square and adjusted R-square values are close together and exceed 90%, the model is adequate?
2. If only R-square is over 90% but adjusted-R square is small, the model is adequate to explain the response?
3. Is it right that if Lack of fit is bigger than 5%, the data is statistically significant? What is main meaning of Lack-of-fit value?
Thank you very much for many helps:thanx:.
This would typically be considered very good. However, much depends upon the use to which you intend to put the model. If you only need relationships and identification of significant factors values much lower would be adequate. Approximate predictions may be made with values above 70%. If you need precise predictions, values above 85% are recommended. These are only general guidelines. The final determinant is whether the model will suit your needs.
No. This is an indication that the model has been overfitted. That is, you have too many terms in the model that are either not significant, or add little value.
No. Lack of fit is an indication that you have insufficient terms in your model. For example, if you have a linear model, but your data is a quadratic curve, your lack of fit test will show significance until you add a quadratic term to your model.
Minhanh
Hi Miner,
Heaps of thanks to your helps.
I get more understanding on statistical aspects. Thanks to Elsmar Cove Forum:magic:
A Please Help With EOQ Calculation Manufacturing and Related Processes 2
S NC and Deviation approach - please help Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 12
B Can someone help me explain P-Value with a simple word please? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
B Will you please help me with my academic project? Repair & calibration service for test equipment ISO 17025 related Discussions 0
L Please help me with the process of getting ISO 9001 certified Quality Management System (QMS) Manuals 15
K Please help identify appropriate statistical treatment Statistical Analysis Tools, Techniques and SPC 13
K Please Help! what is ARL for the range and standard deviation Statistical Analysis Tools, Techniques and SPC 0
R Please help me with attached copy of AS 9100D internal audit check sheet AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Please help my division with quality [long] Service Industry Specific Topics 1
J Please help me understand what a process is ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Revised ISO std vs ISO13485:2003 - Help Please!!! ISO 13485:2016 - Medical Device Quality Management Systems 4
L Newly API Q1 9th Edition applicant HELP please =) Oil and Gas Industry Standards and Regulations 3
S Informational Please help this newbie understand ISO 9001 Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
Y Please help me solve a DOE problem - New Minitab User Using Minitab Software 36
R Please help with the construction of OC curves Using Minitab Software 7
M Please help to change the numbering in level 3 of structure Document Control Systems, Procedures, Forms and Templates 1
D Please help for the CISSP (Certified Information Systems Security Professional) Exam Professional Certifications and Degrees 2
S Please help on ISO 13485 medical device related services Other Medical Device Related Standards 1
K Please help me to generate a Production Chart Manufacturing and Related Processes 4
R Please help me with Welding Symbols Manufacturing and Related Processes 5
I Please help me with some Templates Document Control Systems, Procedures, Forms and Templates 2
S Please help me define training requirements for a Career in Regulatory Affairs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B Help with NDC (Number of Distinct Categories) Please Six Sigma 2
N If ew(t)=2339, how do I find T? Please help on Maths Problem Brain Teasers and Puzzles 3
C Clarification On Internal Auditor Requirements - Please help Internal Auditing 10
P ISO 9001:2008 Gap Analysis Template - Please help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Product Realisation Process Map - Need some help, please review and comment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Please help me interpret my GR&R results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Can anybody help me with Management Review scenario please? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
V Help needed with ISO 14001 Procedures please ISO 14001:2015 Specific Discussions 7
C I'm from Malaysia, just graduate 1 year - Looking for a job...Please help me. Career and Occupation Discussions 3
N I have 2 groups to compare - Minitab and stats newbie - Please help Using Minitab Software 18
K Please help Calculate Audit Man Days Process Audits and Layered Process Audits 8
B 5 Why help needed Please kindly review Problem Solving, Root Cause Fault and Failure Analysis 15
D Please help to set Weighing Indicator SI4010R General Measurement Device and Calibration Topics 1
G Newbie in IMDS - Please help me understand what I have to do RoHS, REACH, ELV, IMDS and Restricted Substances 4
B Green Initiative - Please help me in preparing Go Green Steps.... Sustainability, Green Initiatives and Ecology 6
Ron Rompen Shiftwork Scheduling - An unusual problem - Need help please Human Factors and Ergonomics in Engineering 13
S Opening Up Tolerances - We have over 6000 live drawings - help please Design and Development of Products and Processes 6
N Help please - Mechanical Latch Design Principles? Design and Development of Products and Processes 2
K Scoring Scale for Internal Audits - Please help finding the right terms Internal Auditing 44
D Need some help with a formula in Excel Please! Excel .xls Spreadsheet Templates and Tools 11
T Help With GR&R (Gage R&R) on JMP ***JMP people please help*** Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M 'Searched' virus? Cannot delete folder - HELP please After Work and Weekend Discussion Topics 33
G Hazardous Waste Consignment Note - Please Help Miscellaneous Environmental Standards and EMS Related Discussions 2
R Please help us to understand clause 5.5.2 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Please help me to convert from ISO9001 to ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
J Contract Review - Please help me define the requirement 7.2.2 Info needed Contract Review Process 9
