Please suggest how to improve Cosmetic Visual Inspections
Q
qahardlife
I find it very often that our production operators are not very efficient in doing visual cosmetic inspection. The usual CA done is by showing the rejected part to them and alerting them to the defect and I find it rather reactive response. Of course we have put up photos of common reject to help them but is there a more effective way of helping the operators to do a better job?
Mikishots
Re: Pls suggest how to improve cosmetic visual inspections
A method to consider:
1. Meet with them formally in a classroom setting and go through the key characteristics of the parts they inspect. You will need to provide any drawings or other documentation that defines what the minimum acceptable appearance needs to be.
2. Be clear in stating WHY these cosmetic standards are to be met (Customer? Design? Just because?). If you can't describe this to them, they cannot be expected to inspect to them.
3. Have some hands-on examples of defects and be prepared to explain why they are not acceptable.
Since you are dealing with cosmetic inspections, there will always be a degree of interpretation because you're dealing with a degree of aesthetics - it's a quantitative exercise. Your job is to provide a solid baseline for them to follow. If they decide they want to reject a part, have it passed through a second person (chargehand, a QC inspector, MRB).
It's obvious from your post that someone is catching these after production and before shipping/integration. In your organization, who has been made responsible for identifying the defects? Are you planning on doing away with inspectors? Having someone inspect their own work is inherently risky, and can typically result in what you're seeing; no one likes to reject their own work.
W
Wilderness Woody
Mikishots boiled it down to the necessary steps, including the essential buy-in by the operators themselves. In order to improve effectiveness and efficiency, you need to put some time into evaluating the process, product and staff. Depending upon the actual product, you may have very different cosmetic defect potentials that need to be addressed.
Defining what constitutes a defect and the range or extent that is still acceptable is very important. There is nothing worse than an "opinion" that varies from day to day.
As a process of inspection, look at breaking the steps down and documenting the requirements for orientation of the product, lighting, operator... standardizing where possible. Use of reference style sheets, photo flash cards sets, clear film overlays and directional lighting are tools that can aid inspection.
Welcome here qahardlife and a very good opening question ~~~
Cosmetic visual inspection is a challenge.
To effectively make your operators perform well and consistently, you need to plan it well.
Visual defects consists of point defects, line defects and area defects
Define them with examples
Define acceptance limits. Like how many point defects, line defects, area defects are permissible per inspection zone.
Define the inspection zones like most visible zone, less visible zone, Inner zone, hidden zones., etc based on your product features and requirements.
Define the inspection lighting
Define the inspection distance
Define the inspection time per zone
Define the viewing angle
With all these train your operators
Select operators having good and consistent vision quality perhaps based on eye tests
Get your requirement and consistency.
Establish baseline across operators.
Cultivate and maintain.
Improve when customer requirement or complaints demand change of criteria.
Mike S.
Happy to be Alive
Also, frequently reiterate that you are always available to answer questions and interpret grey areas. Then, ALWAYS do what you say and be available, without delay, without being grumpy, when they call.
And just pass through their area once or twice a day to make yourself more easily available for questions.
Q
qahardlife
I have basic requirement establish and these operators have gone through training before but it just that some operators doesn't seem to be able to pick up the problem which could be due to that these defects do not happen frequently.
some interesting pointers highlighted below.
training - How often should such training be conducted as we find that
operators awareness tend to decrease over time.
lighting environment - is there a standard lighting requirement?
inspection distance & time - these have been determine by customer
usage.
DRAMMAN
Training frequency is up to you and should be base don what is needed.
I am sure there are studies that indicate the best light conditions for visual inspections. Not uncommon for industries to have special rooms for visual inspection. Very common in automotive. There may be industry standards but I am not sure.
Any opinions on using attribute R&R methods ot evaluate inspectors?
I use this approach on all critical visual inspections. I've found it to be very useful. I treat it like calibrating any measurement equipment. I will have the test done once or twice a year depending on the criticality. Not only does this keep teh operators sharp, it points weak areas for the inspectors and together we can determine how to improve the effectiveness.
in addition to what others have said, when I supervised inspectors I met daily with them to review the defect rates (on a control chart of course), review any new defects or increases in known defect types, review any 'misses' and sought their direct input and engagement in making continual improvements. I also ensured that they were team members on problem solving teams for the defects they caught so they could directly contribute to improvemtns in quality and understand the importance of their daily work. I also helped keep them from beign policeman or disgruntled because 'nothing ever got better'...
A Please suggest analysis for identifying the warranty Reliability Analysis - Predictions, Testing and Standards 1
M Please Suggest Valuable Technical or ?motivational? Training Seminars, etc. Career and Occupation Discussions 4
M Please suggest Registrar in Emeryville, CA - Software development company Registrars and Notified Bodies 5
A ISO 9001- any advise please with transitioning from a paper based system to eQMS and multi site scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R Please advise what to do next feeling stuck Career and Occupation Discussions 7
Moncia ISO 9001 calibration question please ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J PFMEA/control plan question- PLEASE HELP ! IATF 16949 - Automotive Quality Systems Standard 8
A Please Help With EOQ Calculation Manufacturing and Related Processes 2
S NC and Deviation approach - please help Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 12
MSeibert47 Daily Quality Topics - Need Ideas Please! Food Safety - ISO 22000, HACCP (21 CFR 120) 18
B Can someone help me explain P-Value with a simple word please? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 3
H MDD Article 12 Labeling for Class IIa Medical Device - Please Advise EU Medical Device Regulations 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
Ronen E Can anyone please explain this? (510k submission requirement) Other US Medical Device Regulations 14
A Please explain MDR Rule 11 to me EU Medical Device Regulations 67
R Please share your method used for PEMS Validation IEC 62304 - Medical Device Software Life Cycle Processes 5
Sidney Vianna Interesting Discussion Hello IAF. Are you listening? Please explain the inconsistency in your IAF Mandatory Documents ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 7
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
optomist1 Share a DFMEA template please Document Control Systems, Procedures, Forms and Templates 2
alonFAI Please share a medical device company NCMR procedure Other Medical Device Related Standards 5
B Will you please help me with my academic project? Repair & calibration service for test equipment ISO 17025 related Discussions 0
J Medical Device Vigilance decision tree FORM - Please share yours EU Medical Device Regulations 15
Marc Posting Job Openings - Read Me Please - 27 January 2019 Job Openings, Consulting and Employment Opportunities 0
L Please help me with the process of getting ISO 9001 certified Quality Management System (QMS) Manuals 15
K Please help identify appropriate statistical treatment Statistical Analysis Tools, Techniques and SPC 13
L Please review my ISO 9001:2015 Internal Audit Plan Process Audits and Layered Process Audits 7
C Will anyone please share training material for ISO:13485:2016 for best practices Training - Internal, External, Online and Distance Learning 0
L ISO 9001 - 2015, is the Quality Manual needed? Please advise ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Please Help! what is ARL for the range and standard deviation Statistical Analysis Tools, Techniques and SPC 0
E Best GD&T training - Your suggestions and recommendations please Training - Internal, External, Online and Distance Learning 3
R Please help me with attached copy of AS 9100D internal audit check sheet AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Supplier Classifications - Please give me a good definition of the following terms ISO 13485:2016 - Medical Device Quality Management Systems 5
L Please help my division with quality [long] Service Industry Specific Topics 1
J Please help me understand what a process is ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T From 21 CFR to IEC 60601 - Please explain IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Please share your IATF 16949 Internal Audit Plan and Schedule Internal Auditing 13
M MDSAP Audit Plan - Please share an Audit Plan/Schedule/Agenda ISO 13485:2016 - Medical Device Quality Management Systems 7
J Please Recommend books that explain how to understand IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
S New Interaction of Processes ISO 9001:2015 - Please Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M New Quality Policy for ISO 9001:2015 - Please Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Please share a Product Audit Checklist for a Wafer Fab Document Control Systems, Procedures, Forms and Templates 3
Moncia Complaint / Non-Conforming Product / CAPA Procedures - Please share your experience ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Please explain the following Automotive Acronyms IATF 16949 - Automotive Quality Systems Standard 3
V Revised ISO std vs ISO13485:2003 - Help Please!!! ISO 13485:2016 - Medical Device Quality Management Systems 4
S Please recommend any good training courses for Medical Device Regulations Training - Internal, External, Online and Distance Learning 8
E Supplier Evaluation Form - Example to evaluation suppliers (criteria) please Document Control Systems, Procedures, Forms and Templates 4
S Please review my Risk Analysis Table ISO 14971 - Medical Device Risk Management 13
