Plotting capability study data - I have a bimodular data distribution
G
Plotting capability study data, and I have a bimodular distribution of the data which about six data points are .01 larger than the other points.
The dimension is the thickness of a gear molded from 15% glass filled polypropylene in a single cavity mold. The average of all 30 points is .652, and the range of the 6 points is .660 - .664 Wondering if these outlying data points could be parts produced from before the mold raised to its normal run temperature, therefore did not shrink as much? Any insight would be greatly appreciated.
You should have collected your data in time sequence and plotted it on a control chart to determine whether your process was stable prior to calculating the capability. If these data were as you speculate then you would see them as the initial points on the control chart and presumably out of control.
Miner is correct. unfortunately no amount of statistical manipulation or scientific guessing or rationalization can save a poorly designed study.
If you are really interested in an informative capability study, let's talk about study design before you 'collect some data'...
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
AnaMariaVR2 Guide to Microsoft Excel for Calculations, Statistics, and Plotting Data Excel .xls Spreadsheet Templates and Tools 11
V Plotting MTBF for More Systems in a Single Chart using Meridium 3.4.2 Software Reliability Analysis - Predictions, Testing and Standards 2
S Minitab closes/crashes when plotting Response optimization Using Minitab Software 2
B Plotting Probability Exceedance using the Probability Plot Graph in Minitab Using Minitab Software 4
G Control Charts - Plotting Unwanted Data Excel .xls Spreadsheet Templates and Tools 5
W Plotting Cpk as Function of Measurement Event Capability, Accuracy and Stability - Processes, Machines, etc. 8
C Plotting identified Competencies, Education & Training Needs into the Training Plan Training - Internal, External, Online and Distance Learning 1
M ISO13485 Special Requirement - Paper used for plotting charts ISO 13485:2016 - Medical Device Quality Management Systems 1
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
H Capability Data for Paint Thickness on Painted Parts Statistical Analysis Tools, Techniques and SPC 10
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
A Statistic Tools to Know Capability of Sealing Machine for Seal Width Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
J Initial capability for injection molding part Capability, Accuracy and Stability - Processes, Machines, etc. 6
Ron Rompen Ford Method - Position Capability with MMC Modifier Capability, Accuracy and Stability - Processes, Machines, etc. 14
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
B Short term vs Long term Capability - We ship millions of parts in a year Capability, Accuracy and Stability - Processes, Machines, etc. 7
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
J Are Capability Requirement(s) Valid for All Characteristics? Capability, Accuracy and Stability - Processes, Machines, etc. 6
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
M CAAC-145 Manuals - Looking for examples of MOM's, MMM's Capability Lists, etc. Federal Aviation Administration (FAA) Standards and Requirements 13
J Powdercoating Capability Employing a Robotic Arm Manufacturing and Related Processes 1
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
V Capability for Correlated Charteristics Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
