Plug Gage Calibration Report does not include actual data - ISO 9001:2000 section 7.6
phxsun2001
Involved - Posts
A company sent their plug gage set for calibration. The calibration certification/report doesn't show the actual calibration measurements. It shows the tools used for the calibration and certified that all the gages are fine. This calibration house charges $100 more if calibration data are recorded on the report. The company certified that the plug gage set had been calibrated and certified.
Does it meet the requirement of section 7.6 which states,"Record of the results of calibration shall be maintained"? How do you interpret "Record of results of calibration"?
For in-house calibration, I expect the calibration technician to record calibration data on calibration reports.
TY
Re: Plug Gage Calibration Report does not include actual data - ISO 9001:2000 section
Your question is almost like mine I posted a few days ago:
http://elsmar.com/Forums/showthread.php?t=20922
Some vendors & mfg's charge extra for the as found data, while others like the one I mentioned in the link above simply states it was within tolerance or out of tolerance by x.x%. I even had one company performing calibrations that would always simply give you a single sheet stating it was within tolerance. If it was found OOT, then they would supply you the actual data.
It's hard for me to determine which is the best method, while trying to save some money on calibrations sent out. Internally, all of our techs record the as found data. Curious to see what others say on this subject.
F
fireonce
In my opinions,it's ok but not strict enough,if certified, it may be a proposal.
Any other views?
Rational determination of calibration intervals can't be done without the as-found data. In the case of something like cylindrical plugs, there's no "adjustment" to be done; it's just a matter of wear, and perhaps cleaning up some edges.
G Gage Recall Analysis - Threaded Plug Gage has failed Calibration General Measurement Device and Calibration Topics 10
M Thread Plug Gage - Calibration Frequency ISO 13485:2016 - Medical Device Quality Management Systems 1
L Calibration Procedure for Internal Spline Plug Gage Needed General Measurement Device and Calibration Topics 4
R Setting Calibration Tolerance on Gauges - Oven Calibration and Stepped Plug Gage General Measurement Device and Calibration Topics 10
T Threaded plug and ring gage calibration procedures General Measurement Device and Calibration Topics 4
D Plug Gage Calibration - Manufacturer's Certification vs. Calibration Laboratory General Measurement Device and Calibration Topics 2
T Inspecting Full Thread Depth with a Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Use of ANSI Standard for Metric Thread Plug Gage? General Measurement Device and Calibration Topics 1
M ASME B1.13M Standard - Specification of a Plug Gage of Minor Diamateter Various Other Specifications, Standards, and related Requirements 3
B Plug Gauge (Gage) Design Design and Development of Products and Processes 7
L UN Class 5 Tolerances - Thread Setting Plug Gage 7/8-9 UNC 5 General Measurement Device and Calibration Topics 23
C Functional Gages give different results - Thread Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
C NO-Go Plug Gage Force General Measurement Device and Calibration Topics 3
M Calibrating 1/2-20 UNF 2B STI Threaded Plug Gage General Measurement Device and Calibration Topics 3
T Johnson Thread View System - Measures many characteristics on a thread plug gage General Measurement Device and Calibration Topics 13
C Allowance for Slip Fit - Additional Allowance applied to GO NO GO Plug Gage General Measurement Device and Calibration Topics 26
Q 'GO' & 'NO GO' Thread Plug Gage Standard Various Other Specifications, Standards, and related Requirements 17
R PPAP on plug gages with Gage R & R APQP and PPAP 5
P Can anyone suggest a GRR procedure for a Multi step plug gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Conducting Gage R&R - 300 plug gauges - Different diameters - One for each plug gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Why Does a Thread Plug No Go Gage Mean Fail? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
A Is GR&R (Gage R&R) required for simple attribute gauges like plug gauges? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Measuring ID's: Which is the most accurate? CMM / Sunnen Gage / Plug Gage? General Measurement Device and Calibration Topics 3
D Simplified Attribute MSA Gauge (Gage) R&R for Plug Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
R NRTL - Scope Question - Off-the-Shelf Plug In IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
L Calibration of Plug Gauges - Tolerancing General Measurement Device and Calibration Topics 1
B IEC 60601 Cl. 8.4.3 - ME EQUIPMENT intended to be connected to a power source by a plug / Plug discharge IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Thread plug chip groove - Thread plugs without the chip groove General Measurement Device and Calibration Topics 0
M Calculating MTBF for plug-in PCI cards Reliability Analysis - Predictions, Testing and Standards 2
C Calibration of Master Thread Plug Gages General Measurement Device and Calibration Topics 2
C Measurements of Major Diameters of plug thread gages General Measurement Device and Calibration Topics 12
D Indysoft Calibration Software Thread Plug Template Help General Measurement Device and Calibration Topics 2
D Incomplete DHF: Re-do or plug gaps? Design and Development of Products and Processes 6
M How to make Plug Gauge No & NoGo Sizes Calibration and Metrology Software and Hardware 3
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
SATHYABALARAMAN Thread Plug Gauge - NO-GO Rejection Criteria General Measurement Device and Calibration Topics 4
S Plug Discharge Test Calculations IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Hospital Grade Mains Plug US (NEMA 5-15) and Japan IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Should be Hospital Grade Plug be used in Class II Medical Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
CycleMike 7.6.1 - ".....type of measurements system" and Plug Go/NoGo gages IATF 16949 - Automotive Quality Systems Standard 4
L TiN Coated Thread Plug Gauges General Measurement Device and Calibration Topics 12
T Constant for a M3x.35 Set Plug using the "Three-Wire Method" Calibration and Metrology Software and Hardware 2
F Standard regarding the wear of Thread and Plug Gages. General Measurement Device and Calibration Topics 10
D What is the difference between Pin and Plug Gages General Measurement Device and Calibration Topics 13
