Poka Yoke For Breaking Screw Tap
P
Przemek
Hello . I have a big problem with breaking screws tap during rifling the rods. This rods after this are cutting and we produce inserts and screw locks. Maybe somebody had this problem in past and have any POKA YOKE? Regards
Two suggestions that come to mind would be:
- an optical or proximity sensor on the tap itself near the tip that could check between cycles to verify that the tip was present.
- a sensor on the torque or power of the tapping power supply. A broken tap would not generate torque or draw power because it would not be cutting threads.
I am sure that there are other possibilities also.
P
Przemek
Thanks for help, maybe do you have andy drawing for these solutions?:thanx:
CarolX
Could you provide some additional info on your process - is this a hand tap operation, or a CNC process?
Al Rosen
Could the tap need sharpening? If so, a little preventive maintenance is all you need.
apestate
Do you have a machinist you can ask?
Cheap taps will cause it. Worn taps will cause it. Damaged taps will cause it. Poor hole quality will cause it. Incorrect speed and feed settings will cause it. Incorrect travel settings will cause it. Misalignment of tooling will cause it. Trying to rigid tap without a rigid tapping machine will cause it. Inadequate cooling/lubrication will cause it. Inadequate chip evacuation will cause it. Hard or work hardening material will cause it.
Let's find the root cause of the problem before trying to error-proof the operation.
P
Przemek
Hi. I spoke with operators and analyze raports form production. OUR Root cause problems is a moment when screw tap is wort our ,but not breaks and start produce parts with narrow thread ( tap diameter is below tollerance). We cant found this moment. We received taps from one supplier and have the same hardness and material class. Regards
ChuckHughes
"Cheap taps will cause it. Worn taps will cause it. Damaged taps will cause it. Poor hole quality will cause it. Incorrect speed and feed settings will cause it. Incorrect travel settings will cause it. Misalignment of tooling will cause it. Trying to rigid tap without a rigid tapping machine will cause it. Inadequate cooling/lubrication will cause it. Inadequate chip evacuation will cause it. Hard or work hardening material will cause it." :thanx: atetsade
I agree with the above...too many potential causes to begin Poke Yoke or other mistakeproofing. You will need to identify the root cause first.
P
Przemek
Sorry but i cant agree with you: Iwrote in previous post about problem with narrow thread. Root cause :during production process tap is losed correct diameter dimension, worn out. Its normal worn out. Question is: How find this moment when tap start produce incorrect thread ( with diameter below tollerance)? All causes about you wrote was eliminated.
R Poka Yoke on Helicoils Manufacturing and Related Processes 3
F Ideas for brewery poka-yoke system - Labels that are glued to a bottle Manufacturing and Related Processes 0
S Poka Yoke Inspection Retaining Ring (C-Clip) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D Ideas for Poka Yoke or Improvement - Aluminum FOD in Assembly Customer Complaints 3
M What is the link between Poka Yoke and Firewall? General Auditing Discussions 2
K Poka-Yoke for Quantity Shortage caused by Human Error Quality Tools, Improvement and Analysis 7
M Poka-yoke - Key Topics and Points Problem Solving, Root Cause Fault and Failure Analysis 11
C Poka Yoke and FMEA Detection Ranking FMEA and Control Plans 3
W Suggest a Poka Yoke (Mistake Proof) Method for my Product Manufacturing and Related Processes 24
T Error Proofing / Poka-Yoke Textbook by Productivity Inc Book, Video, Blog and Web Site Reviews and Recommendations 7
M Weld Stud Length Poka Yoke Nonconformance and Corrective Action 3
K Poka Yoke for Leaf Spring placement by Operator Misc. Quality Assurance and Business Systems Related Topics 2
B PFMEA Line Items for Poka-Yoke (Mistake Proofing) and Scans FMEA and Control Plans 2
L Method for Poka-Yoke (Mistake Proofing) Validation prior to SOP APQP and PPAP 6
V Is Poka Yoke only applicable for product related activities? Quality Tools, Improvement and Analysis 1
G Is Mistake Proofing (aka Poka Yoke) a Process Change? APQP and PPAP 12
S Mistake Proofing (Poka Yoke) in Offices and Services Service Industry Specific Topics 12
N DFM, DFA and POKA YOKE - Are these three related? Manufacturing and Related Processes 4
L Definition Poka Yoke, Process Mapping, MSA - What are these terms please? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
D Poka Yoke - Information and Input of Poke Yoke example Quality Tools, Improvement and Analysis 6
kedarg6500 Auditing Work Stations where Poka Yoke has been done - What to look for? Manufacturing and Related Processes 9
A Gage Reproducibility & Repeatability for POKA-YOKE (pass/fail) gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
W Definition Poka-Yoke - Definition - How do you define Poka-Yoke? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
F Want to know more on Methods and Tools for quality assurance (8d, TQM and Poka Yoke) Preventive Action and Continuous Improvement 3
A Example of application of Poka Yoke, 3M, Autonomous maintenance in office Lean in Manufacturing and Service Industries 4
B Occurence and Detection ratings - Will poka-yoke Prevention Control affect Detection? FMEA and Control Plans 8
J Poka-Yoke in Process FMEA (PFMEA) - Which column? FMEA and Control Plans 10
C Poka Yoke - Formed Wire - I need help with this part Quality Tools, Improvement and Analysis 2
Wes Bucey NASA ripe for Poka Yoke? Preventive Action and Continuous Improvement 12
T Is Poka-Yoke Old Hat? Is Poka-Yoke still a valid concept? Nonconformance and Corrective Action 28
A FMEA Poka-Yoke & DOE (Design of Experiements) Design and Development of Products and Processes 4
M SPC (minimizing defects) Vs Poka Yoke (zeroing out defects) Statistical Analysis Tools, Techniques and SPC 3
D Seeking Information on Poka Yoke - Error Proofing Nonconformance and Corrective Action 3
E Poka-Yoke applied to Administrative Processes - Sales, Accounts Payable, HR Misc. Quality Assurance and Business Systems Related Topics 12
D Defects and Systems - Zero Defects and its proponents, Poka Yoke, etc. Preventive Action and Continuous Improvement 14
Marc Mistake-Proofing, ZQC, & Failsafing - John Grout's Poka-Yoke Page Quality Tools, Improvement and Analysis 0
S Mistake Proofing and Poka Yoke - Looking for information Quality Tools, Improvement and Analysis 2
N Validity of gauges use as poka-yokes Manufacturing and Related Processes 14
G About calibration gages and poka yokes General Measurement Device and Calibration Topics 1
K Poke Yoke for straightness? Lean in Manufacturing and Service Industries 10
M Attempting to Poke Yoke a wire crimping process...need help Design and Development of Products and Processes 3
A Using Arduino based sensors for Poke-Yoke Manufacturing and Related Processes 6
Q Actions Taken - Updating a FMEA for the addition of a downstream poke yoke FMEA and Control Plans 3
Antonio Vieira Labeling poke-yoke devices Quality Tools, Improvement and Analysis 5
L Attribute gage in stamping press as poke yoke Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
V Poke Yoke Gage Calibration - Do you have them in your calibration system? General Measurement Device and Calibration Topics 8
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
T Attribute (Check Fixtures) - Breaking the Ice with Potential Customers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Jim Wynne Breaking News: FAA Announces Ban on Plane Crashes Funny Stuff - Jokes and Humour 7
Ajit Basrur Breaking Silos within the Organization - Presentation wanted Quality Manager and Management Related Issues 6
