Poka Yoke Inspection Retaining Ring (C-Clip)
superdry123
I want to find a poka yoke solution for checking if a C-Clip is properly sitting in its groove. The C-Clip is currently being checked by a gauge pin which has a 2.5 mm diameter. Is there any possibility to check this in another way which is 100% safe. The gap opening (inner diameter) from the C-Clip must be less than 2.5 mm, otherwise the C-Clip doesn't sits properly in its original shape. The tolerances are +-0.05 mm
Would be grateful for some ideas. Thanks.
superdry123
Assuming you want an automated system, a vision system can work. Can the part be oriented consistently for a camera?
Actually yes, but a vision system would be too expensive for this issue. Is there an option to use digital caliper which is connected to a PLC and gives feedback/ interlock with machine to prevent from continuing? tested already, CT would not even increase that much. Maybe by using RS232 cable, anybody experience with caliper connections?
Proud Liberal
You may want to investigate use of a ball gage to detect the opening. The benefit of a ball gage vs a pin gage is that orientation is less of an issue when evaluating a slot opening (two parallel planes) using a sphere (2 point contact). A pin gage (when aligned with the slot) would be 2 lines of contact.
I've setup one into a spring loaded mount that is setup with a proximity switch to detect whether the gage will pass through the opening being evaluated.
optomist1
A Sea of Statistics
Superdry123, a few words of caution re: (AOI) automatic optical inspection, a great time error reducing method however, one must ensure that the object code or AOI software program havs been properly validated and where necessary hack proofed....second at the beginning and end of each shift a "red rabbit" (known bad part) and Golden rabbit (known good part) must be used to verify proper operation...these known quantities must be kept under lock and key with access only to shift supervisor or similar person.
R Poka Yoke on Helicoils Manufacturing and Related Processes 3
F Ideas for brewery poka-yoke system - Labels that are glued to a bottle Manufacturing and Related Processes 0
D Ideas for Poka Yoke or Improvement - Aluminum FOD in Assembly Customer Complaints 3
M What is the link between Poka Yoke and Firewall? General Auditing Discussions 2
K Poka-Yoke for Quantity Shortage caused by Human Error Quality Tools, Improvement and Analysis 7
M Poka-yoke - Key Topics and Points Problem Solving, Root Cause Fault and Failure Analysis 11
C Poka Yoke and FMEA Detection Ranking FMEA and Control Plans 3
W Suggest a Poka Yoke (Mistake Proof) Method for my Product Manufacturing and Related Processes 24
T Error Proofing / Poka-Yoke Textbook by Productivity Inc Book, Video, Blog and Web Site Reviews and Recommendations 7
M Weld Stud Length Poka Yoke Nonconformance and Corrective Action 3
K Poka Yoke for Leaf Spring placement by Operator Misc. Quality Assurance and Business Systems Related Topics 2
B PFMEA Line Items for Poka-Yoke (Mistake Proofing) and Scans FMEA and Control Plans 2
L Method for Poka-Yoke (Mistake Proofing) Validation prior to SOP APQP and PPAP 6
V Is Poka Yoke only applicable for product related activities? Quality Tools, Improvement and Analysis 1
G Is Mistake Proofing (aka Poka Yoke) a Process Change? APQP and PPAP 12
S Mistake Proofing (Poka Yoke) in Offices and Services Service Industry Specific Topics 12
N DFM, DFA and POKA YOKE - Are these three related? Manufacturing and Related Processes 4
L Definition Poka Yoke, Process Mapping, MSA - What are these terms please? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
D Poka Yoke - Information and Input of Poke Yoke example Quality Tools, Improvement and Analysis 6
kedarg6500 Auditing Work Stations where Poka Yoke has been done - What to look for? Manufacturing and Related Processes 9
A Gage Reproducibility & Repeatability for POKA-YOKE (pass/fail) gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
W Definition Poka-Yoke - Definition - How do you define Poka-Yoke? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
F Want to know more on Methods and Tools for quality assurance (8d, TQM and Poka Yoke) Preventive Action and Continuous Improvement 3
A Example of application of Poka Yoke, 3M, Autonomous maintenance in office Lean in Manufacturing and Service Industries 4
P Poka Yoke For Breaking Screw Tap Manufacturing and Related Processes 26
B Occurence and Detection ratings - Will poka-yoke Prevention Control affect Detection? FMEA and Control Plans 8
J Poka-Yoke in Process FMEA (PFMEA) - Which column? FMEA and Control Plans 10
C Poka Yoke - Formed Wire - I need help with this part Quality Tools, Improvement and Analysis 2
Wes Bucey NASA ripe for Poka Yoke? Preventive Action and Continuous Improvement 12
T Is Poka-Yoke Old Hat? Is Poka-Yoke still a valid concept? Nonconformance and Corrective Action 28
A FMEA Poka-Yoke & DOE (Design of Experiements) Design and Development of Products and Processes 4
M SPC (minimizing defects) Vs Poka Yoke (zeroing out defects) Statistical Analysis Tools, Techniques and SPC 3
D Seeking Information on Poka Yoke - Error Proofing Nonconformance and Corrective Action 3
E Poka-Yoke applied to Administrative Processes - Sales, Accounts Payable, HR Misc. Quality Assurance and Business Systems Related Topics 12
D Defects and Systems - Zero Defects and its proponents, Poka Yoke, etc. Preventive Action and Continuous Improvement 14
Marc Mistake-Proofing, ZQC, & Failsafing - John Grout's Poka-Yoke Page Quality Tools, Improvement and Analysis 0
S Mistake Proofing and Poka Yoke - Looking for information Quality Tools, Improvement and Analysis 2
G About calibration gages and poka yokes General Measurement Device and Calibration Topics 1
A Using Arduino based sensors for Poke-Yoke Manufacturing and Related Processes 6
Q Actions Taken - Updating a FMEA for the addition of a downstream poke yoke FMEA and Control Plans 3
Antonio Vieira Labeling poke-yoke devices Quality Tools, Improvement and Analysis 5
L Attribute gage in stamping press as poke yoke Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
V Poke Yoke Gage Calibration - Do you have them in your calibration system? General Measurement Device and Calibration Topics 8
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
