Poke Yoke Gage Calibration - Do you have them in your calibration system?
V
VickiD
:frust: Does anyone deal with poke-a- yoke gauges. Do you have them in your calibration system? We have done both and I am to the point of just putting my masters in the calibration system. Some of our poke a yoke gages are not accessible, which in turn cannot be pulled into our lab to be calibrated. I don't want to get dinged by our QS auditor by not putting them in the system, so I'm thinking if I have the master calibrated and we put the master thru the poke -a- yoke then this should be good to go? Anyone with feedback would be greatly appreciated.
Jerry Eldred
I must admit I am not familiar with "Poka-A-Yoke" gauges. Using intuitive guessing, I'm assuming these may be installed reference items installed in-situ in your manufacturing process.
If you have a reference that is not calibrated, yet you indirectly verify it by running a gold standard through the process, as long as you can account for the derived accuracy (putting it very simply), you should be okay.
That said, what I mean is that the bottom line is that needed accuracy required for your product to meet its specs must be met. If your product has a given tolerance, and rather than pull out references, you compare them in-situ, you need to know that the combination of the uncertainty of your master reference, and the resolution/stability of the metering in the process must be adequate to verify that the in-situ reference meets adequate accuracy.
I've sounded a little redundant (probably because its Monday morning after a long holiday). But hopefully I have added some worthwhile input.
Bigfoot
Poka Yoke Gauges
Could you describe a little bit better the Gauges? What is it that your Poka Yoke is checking?
We use Poka Yoke techniques to monitor detection devices that are in place to prevent further processing of a part, by running a part of the known deficiency. The Poka Yoke "rabbit" is run through the process to verify the detection Poka Yoke is working as intended. If not we revert to the last good check and verify all product from that point forward. These parts are entered into our calibration system as "reference" parts that serve only to confirm the system check / verification as intended. They are not "Master" parts. Kind of similar to the difference between do you calibrate your gauges, or do you verify they are in calibration? Hope this helps a little.
V
VickiD
gauges
Our poke a yokes more are less are used to check for missing holes, missing grooves, to short, to long, missing threads. So we have a master part (which I'm guessing I need to change to reference only gage) to put through machine. So a reference part would be a part with say no hole that should have a hole. When that part is run through it has to go through a poke ayoke prior to being machined, if it detects no hole the machine is shut down.
Bigfoot
Reference parts
IMO: You are on the right track. To clarify my earlier post;
Reference part is a casting with the known defect that I am trying to detect for (ie: Good part has four machined scallops - Reference part has missing scallops). All it needs to do is verify the detection device is working by not allowing it to continue through the process.
Bill Ryan - 2007
Basically, that's what we do also. Now, however, we are getting into the "cosmetic" types - looking for sizeable porosity, nonfills, drags/shearing, etc. I'm not sure we are covering ourselves with these types of "master castings" though. I have contacted some of the manufacturers for their recommendations. I'll let everyone know what I hear.
Bill
Timmer
With our Poke-a-Yoke checking fixtures, mostly consisting of proximatey switches, we do the following. We build "Red Masters" each that have the item to be checked missing. Say our part has 3 studs protruding from a flange, and 3 proximately switches, one for each stud as well. Well 3 seperate parts are built each with a different stud missing. These Red Masters are run through the line at intervals on each shift to check to see if the Poke a Yoke fixture is working. We replace these Red Masters either every 3 months or when new ECL's are requested for the components. FYI we call tehm Red Masters becasuse they are spray painted red as to not ship them with good parts!
gpainter
We did at my old place of employment. We had them on our calibration schedule and verified what they were checking were still in line. Many times these took a lot of abuse and tended to get damaged and not be able to give that quick check.
L
lday38
Poke yoke record
My company has recently embarked on using a proximety switch that shuts down the machine when a defectis made. I am wondering shoud'nt there be an officical record on the machine. I have made a checklist where a sample fo a defective part is run thru the machine to make sure the poke yoke is still working.
In another poke yoke, cameras are checking the parts 100% for visual and several dimensional defects, again the defects are passed down the chute to make sure the cameras are still effective at the start of the shift. However, there are several diifernat parts with several differnat type of defects-it's beginning to get more complicated- I started with a table with the part number and defects list down the left side in a work instruction. I think this needs to be poke yoke. No one opens the book where the work instruction is, the defetcive samples are colored red and bag labeled for the partuicular part run.
L Attribute gage in stamping press as poke yoke Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Using Arduino based sensors for Poke-Yoke Manufacturing and Related Processes 6
Q Actions Taken - Updating a FMEA for the addition of a downstream poke yoke FMEA and Control Plans 3
D Poka Yoke - Information and Input of Poke Yoke example Quality Tools, Improvement and Analysis 6
Antonio Vieira Labeling poke-yoke devices Quality Tools, Improvement and Analysis 5
R Poka Yoke on Helicoils Manufacturing and Related Processes 3
F Ideas for brewery poka-yoke system - Labels that are glued to a bottle Manufacturing and Related Processes 0
S Poka Yoke Inspection Retaining Ring (C-Clip) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D Ideas for Poka Yoke or Improvement - Aluminum FOD in Assembly Customer Complaints 3
M What is the link between Poka Yoke and Firewall? General Auditing Discussions 2
K Poka-Yoke for Quantity Shortage caused by Human Error Quality Tools, Improvement and Analysis 7
M Poka-yoke - Key Topics and Points Problem Solving, Root Cause Fault and Failure Analysis 11
C Poka Yoke and FMEA Detection Ranking FMEA and Control Plans 3
W Suggest a Poka Yoke (Mistake Proof) Method for my Product Manufacturing and Related Processes 24
T Error Proofing / Poka-Yoke Textbook by Productivity Inc Book, Video, Blog and Web Site Reviews and Recommendations 7
M Weld Stud Length Poka Yoke Nonconformance and Corrective Action 3
K Poka Yoke for Leaf Spring placement by Operator Misc. Quality Assurance and Business Systems Related Topics 2
B PFMEA Line Items for Poka-Yoke (Mistake Proofing) and Scans FMEA and Control Plans 2
L Method for Poka-Yoke (Mistake Proofing) Validation prior to SOP APQP and PPAP 6
V Is Poka Yoke only applicable for product related activities? Quality Tools, Improvement and Analysis 1
G Is Mistake Proofing (aka Poka Yoke) a Process Change? APQP and PPAP 12
S Mistake Proofing (Poka Yoke) in Offices and Services Service Industry Specific Topics 12
N DFM, DFA and POKA YOKE - Are these three related? Manufacturing and Related Processes 4
L Definition Poka Yoke, Process Mapping, MSA - What are these terms please? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
kedarg6500 Auditing Work Stations where Poka Yoke has been done - What to look for? Manufacturing and Related Processes 9
A Gage Reproducibility & Repeatability for POKA-YOKE (pass/fail) gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
W Definition Poka-Yoke - Definition - How do you define Poka-Yoke? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
F Want to know more on Methods and Tools for quality assurance (8d, TQM and Poka Yoke) Preventive Action and Continuous Improvement 3
A Example of application of Poka Yoke, 3M, Autonomous maintenance in office Lean in Manufacturing and Service Industries 4
P Poka Yoke For Breaking Screw Tap Manufacturing and Related Processes 26
B Occurence and Detection ratings - Will poka-yoke Prevention Control affect Detection? FMEA and Control Plans 8
J Poka-Yoke in Process FMEA (PFMEA) - Which column? FMEA and Control Plans 10
C Poka Yoke - Formed Wire - I need help with this part Quality Tools, Improvement and Analysis 2
Wes Bucey NASA ripe for Poka Yoke? Preventive Action and Continuous Improvement 12
T Is Poka-Yoke Old Hat? Is Poka-Yoke still a valid concept? Nonconformance and Corrective Action 28
A FMEA Poka-Yoke & DOE (Design of Experiements) Design and Development of Products and Processes 4
M SPC (minimizing defects) Vs Poka Yoke (zeroing out defects) Statistical Analysis Tools, Techniques and SPC 3
D Seeking Information on Poka Yoke - Error Proofing Nonconformance and Corrective Action 3
E Poka-Yoke applied to Administrative Processes - Sales, Accounts Payable, HR Misc. Quality Assurance and Business Systems Related Topics 12
D Defects and Systems - Zero Defects and its proponents, Poka Yoke, etc. Preventive Action and Continuous Improvement 14
Marc Mistake-Proofing, ZQC, & Failsafing - John Grout's Poka-Yoke Page Quality Tools, Improvement and Analysis 0
S Mistake Proofing and Poka Yoke - Looking for information Quality Tools, Improvement and Analysis 2
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
