Poll: Should auditors promote the process approach?
  • Total voters
    31
  • Poll closed .
Status
Not open for further replies.
DrM2u
BTW you mentioned 6 sigma. IMHO six sigma is a management systems approach - merely pulling together a range of quality tools in a systematic approach.
:topic:IMHO, 6-Sigma is a systematic approach of aplying statistics to identify problems and/or opportunities for improvement (Define), assist with root cause analysis (Measure & Analyze), evaluate effectiveness of actions taken (Implement) and control the new process (Control). In best case, 6-Sigma is a statistical method for problem solving and improvement, nowhere near a business or quality management system. Don't confound 'system' with 'systematic'. If I am wrong, please explain why.
DrM2u
A question requiring an honest answer is, "Does management see value in ISO 9001 audits?" Really? Or is the value in retaining a certificate? (A similar question: does management really see value in a standard-based QMS beyond the certificate?)
Now here's another good idea for a poll! You should start it.
Jen Kirley
Quality and Auditing Expert
Agreed regarding clause 4.1.a; it is simple, direct and limited in scope. On the other hand, how is going clause by clause different that the time-proven ineffective 'element' approach promoted and used pre-ISO 9001:2000?!? Unfortunately life is complicated by things not being black and white (or whatever color combination you prefer). There is a lot of a grey area otehrwise we would not be having these debates. Perfect example: take the Bible. There is only one book called The Bible yet there are many religions that interpret it in their own way. Which is right and which is wrong? The one you subscribe to is right, the others are wrong until convinced otherwise. Why else would I have people knocking at my door trying to convince me that their version is the one to folow?!?
One of the things that QA professionals have done to limit our own progress is to infer that a clearly worded clause has implicit, deeper meaning than its words communicate. We are not alchemists.
The ISO standards were developed and worded to provide a framework for management system development, maintenance and growth. They are not the Bible, however. They are not mystical, and they are not worded in a way that requires a sage to interpret. Their directness is their strength, as it is on the organization's advantage to be able to understand and apply them based on their intelligence and pragmatism.
Organizations need to understand the difference between should and shall, and most do. It is confusing and damaging for auditors, both internal (me) and external, to impose deeper meaning than the standards' clause words convey, and muddle the shoulds and shalls based on guidance.
Now mind you I am all for the process approach. And as I said long ago, the standard is built to help establish that by simple virtue of including all the parts. It even has a nice picture in the Introduction to show how it all ties together.
But auditors are charged to assess and verify that an organization meets the standards' requirements. That limits our ability to enforce what is only mentioned as a "should" in the introduction. As client organizations' systems grow and mature, the element approach can be expected to evolve into a process approach to thinking; for the sake of this discussion I will define that as consideration of stakeholder needs and provisions.
An auditor can express approval when they get it right, or point out that effectiveness is being compromised by failure to consider the input/outputs of, and interactions with, related processes. But beyond that the auditor's role is understandably limited. In my view, if a QA professional wants to go farther, he/she should do so outside the role of auditor.
DrM2u
Now this I agree with! An auditor should not impose or demand anything beyond the requirements of the standard. The most an auditor can do is to suggest for consideration certain topics. It is up to the organization to decide if the suggestion is worth a dime or not. Also, there is nothing that prevents an organization from politely asking an imposing/demanding/off-base auditor from ending the audit and leaving the facilities then asking the CB for another auditor.
Just like you said, organizations' ignorance or lack of knowledge often results in following the directions of ... what's a nice word ... wanna-be auditors. So, should you realy blame only the auditor or should the organization share in the blame also?!? Like you said, 'organizations need to understand the difference between should and shall (...)'. it is not auditor's responsibility to ensure that. That responsibilitiy starts with the MR and should trickle through the organization. At least IMO.
I
ISO 9001 Guy
I hope we can see the ANAB-approved? distinction between consulting and "educating" as previously discussed.
Attending clients' certification audits for years, I became accustomed to hearing auditors offering advice without knowing it. (A lot of it awful advice at that.) "I like to see it this way . . ." "Or you should do it that way. . ."
Although perhaps less common now, the continuing problem is this: organizations (still) follow routines that were adopted to comply with advice given years ago, errant advice that never should have been tendered. But now it seems we're concerned that we can't provide uniform education to correct the error. So organizations are stuck with dysfunctional QMSs because we can't tell them? IAF seems to formally be not only giving permission, it seems ISO/IAF is clearly directing CBs to do so.
Also, to underscore the distinction between consulting and education, in "promoting" the process approach as prescribed by the guidance, it would not be the personal opinion of an auditor that the process approach should be promoted, it's the official opinion of the appropriate authority.
I
ISO 9001 Guy
All that is fine, but it's not being asked for in 4.1a; IMO that clause is simple, direct and limited in scope.
Do you think it is the intention of 4.1a for organizations to determine their processes according to the elements of the standard (and write procedures accordingly, element-by-element)?
I
ISO 9001 Guy
That's up to the organization. Whatever works for them.
(And I am a process approach guy...;) )
Stijloor.
Have you seen lots of companies for whom the element-by-element procedures are useful and helpful to personnel managing or performing processes? Can you give examples? ;)
Stijloor
The (quality systems) world did not come to an end when the clause-by-clause approach was more prevalent. I have seen excellent- and pi$$-poor examples of both. If processes deliver the expected results in a safe, effective and efficient manner, and the customer is very happy, I really am not too worried what approach is being used.
One of my Clients (a chemical company) has their system still modeled in a traditional manner and they show outstanding results in the areas or safety, quality, delivery, customer satisfaction and financial performance.
Stijloor.
Status
S Poll result difference : how do you read it? Statistical Analysis Tools, Techniques and SPC 4
S Management Responsibility - Is Top Management Committed poll Quality Manager and Management Related Issues 59
smryan Vacation Package Poll Coffee Break and Water Cooler Discussions 17
D Interesting graphic of BCS (college football coaches' ballots) Poll Coffee Break and Water Cooler Discussions 5
T Internal Audit Yield %'s (Poll included) Internal Auditing 16
R Poll for six sigma project leaders: What are the difficulties and failure factors? Six Sigma 1
Claes Gefvenberg Let's do age! How 'Old' will you be in 2007? A poll - Version 3 Coffee Break and Water Cooler Discussions 91
Wes Bucey Super Bowl poll - Closes 3 February 2007 Coffee Break and Water Cooler Discussions 54
R The "I only want the paper" poll Coffee Break and Water Cooler Discussions 45
Icy Mountain Statistical Puzzle with Poll Coffee Break and Water Cooler Discussions 17
Tim Folkerts NCAA football polls, BCS, etc - Specifically the USA Today Coaches Poll Coffee Break and Water Cooler Discussions 8
Miner Poll: How do you comply with the ISO 9001 requirement for Mapping Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Research paper poll - Has ISO9001 helped your company improve / be more competitive? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Customer Poll (Satisfaction Measurement) - Meeting Requirements but Negative Replies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Poll : Inspection for Conformity - Proportion of man hours spent? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Hershal MU course in Spanish - poll Training - Internal, External, Online and Distance Learning 1
Marc Registered User Article Poll - February 2005 Registered Visitor Articles Archive 5
Marc Registered User Article Poll - January 2005 Registered Visitor Articles Archive 0
Marc Registered User Article Poll - December 2004 Registered Visitor Articles Archive 2
Marc Registered User Article Poll - November 2004 Registered Visitor Articles Archive 2
Marc Registered User Article Poll - October 2004 Registered Visitor Articles Archive 7
I ISO registered companies, and our poll: ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc Registered User Article Poll - September 2004 Registered Visitor Articles Archive 1
C Seeking APQP project plan done in Microsoft Project / Poll on Web Data Collection APQP and PPAP 14
Marc Registered User Article Poll - August 2004 Registered Visitor Articles Archive 1
Marc Registered User Articles Poll - July 2004 Registered Visitor Articles Archive 8
Marc Registered User Articles Poll - June 2004 Registered Visitor Articles Archive 5
Marc May 2004 Articles Poll (Vote) Thread Registered Visitor Articles Archive 12
Marc Poll Types: Blind vs. Open - Article Vote/Poll Thread Registered Visitor Articles Archive 7
Marc Is Your Company Registered to ISO9001:2000? Poll Starting 15 May 2004 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
Marc Quality Digest 2004 Salary Survey - Yearly Elsmar Cove Poll - Where do YOU stand? Career and Occupation Discussions 17
Q Poll: Does TS 16969 have more CSR (Customer Specific Requirements) than QS-9000? IATF 16949 - Automotive Quality Systems Standard 10
RoxaneB ISO 9001:2000 Transition Poll Discrepancy? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
RoxaneB Coffee Break Forum Poll - Take II Coffee Break and Water Cooler Discussions 20
M ISO 9001 Certification - Successful First Registration Audit? (Poll) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 76
T How Much Time Do You Spend Training A New Internal Auditor? (Poll) Internal Auditing 56
T Do You Consider Your Quality Policy Valuable to your Organization? (Poll) Other ISO and International Standards and European Regulations 44
G What Is Your Company's Head Honchos Background - Poll Misc. Quality Assurance and Business Systems Related Topics 28
Q Passing CQA Exam - Passed on first attempt? Second? A Poll General Auditing Discussions 22
E Hunting and Fishing Thread - With Poll Coffee Break and Water Cooler Discussions 646
Claes Gefvenberg A poll for those of you with more than one management system or std: Other ISO and International Standards and European Regulations 2
E Let's do age! How 'Old' are you? A poll - Version 2 Coffee Break and Water Cooler Discussions 223
A How the wording of a poll affects the outcome Misc. Quality Assurance and Business Systems Related Topics 5
Marc The ASQ Salary Poll - 2001 through 2003 Career and Occupation Discussions 42
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
