First, a friendly suggestion: dense blocks of text such as those above are difficult to read on normal computer monitor, and almost impossible on something smaller. If you break it up into paragraphs and use some white space, it'll be much easier to read.
Now. One thing I've noticed as absent from all of this is a cogent, rigorous definition of the process approach that we can use to contrast with the element-by-element thing. We also don't know much about the element-by-element thing except that you don't like it (I don't either, but for different reasons). In my experience, matching documentation to the clauses of the standard isn't necessarily antithetical to the process approach; it's just a way of classifying things.
Attempts have been made to draw you out on these issues but they've come to a halt via "let's agree to disagree," which leaves significant questions hanging in the air. You've made a somewhat radical proposition, so I don't think it's too much to ask you to support it with something other than plain assertions. As I suggested in an earlier post, you've reached your conclusion but won't support it with logical antecedents such that we can see that if
A is true and
B is true and
C is true, by logical progression
D (your thesis) must also be true. Your defense of
A,
B and
C has mostly consisted of "Let's agree to disagree," the result of which is to bring fruitful discussion to a sudden halt.
I'll make one more attempt to understand your reasoning, this time by way of a hypothetical situation. Suppose we have a company with a QMS that's been designed and documented in PA fashion, such that a competent auditor is satisfied with implementation of the PA. NOw suppose that the company decides, for their own reasons, to reclassify the documentation such that its numbering system aligns with the numbered clauses of the standard--nothing else changes. Now you are handed the company's documentation and are asked to determine--strictly from the documentation--whether or not the PA has been implemented.
Given that scenario, here are two questions:
- Has the company, by deciding to reclassify existing documentation, voided their implementation of the PA?
- Will you be able to tell, simply by looking at the reclassified documentation with no further history, whether the PA has been implemented or not?
