Poll: Should auditors promote the process approach?
  • Total voters
    31
  • Poll closed .
Status
Not open for further replies.
Big Jim
Re: What criterial do you use to identify a company using the "process approach"?
Sorry, I was paraphrasing the standard, but I do not feel I was adding additional requirements.
I was emphasizing the criteria for effectiveness in cl 4.1.c is a vital link that many companies overlook. It is the shadow to the process approach, just like the misunderstandings about Preventive Actions.
I do not believe in overdocumenting a QMS or over defining the processes in a company.
A company with 250 defined processes is an example of what I have been saying. The clearly did not understand the intent of the process approach, and I am sorry they went to that mauch effort. Just about any system with more than a couple dozen processes has probably elevated a lot of subprocesses to the level of a full process, and that rarely adds clarity. It usually bogs things down.
As to your specific example of resources, obviously "resources must be determined," before the company can make available the "resources and information necessary to support the operation of these processes." I was really not adding requirements to the standard. I don't do that.
It appears that you and I agree much more than we disagree.
W
Wayne G.
Re: Should auditors promote the process approach?
I have been auditing TS16949 for many years using the process approach and have just began a new position with a company registered to AS9100. What shocked me is that the company is auditing using the element method. What's worse, the checklist used is merely a copy of all the "shalls" in the standard. I don't think there is any value to this and it amounts to a remedial desk audit.
Question:
1. Is the process approach not used in the aerospace industry?
2. Is it required to cover the "shalls" at least once within a registration cycle?
Big Jim
Question:
Thankfully, the checklist will not be part of the CB audit program for AS9100C. Even thought CB auditors still use the checklist for AS9100B, they are required to use the process approach. Sometimes there isn't much evidence of that approach other than a process based audit plan.
Until a company transitions to AS9100C the checklist (which is part of a standard dedicated to performing aerospace CB audits) is still required. Companies will not be able to register to AS9100C for a few more months (the actual timeframe is still unclear).
AS9100B also requires internal audits to use detailed tools and techniques, such as checksheets and charts. As a result, many companies use the same checklist for internal audits. This requirement goes away with AS9100C.
W
Wayne G.
Thank you.
Where could I find the requirement to use the process approach? If I want to sell this to management, I'll need evidence of a requirement or prefered method. There is more value in using the process approach, as I want processes measured against specific targets.
Thanks again.
Helmut Jilling
Auditor / Consultant
Thank you.
Thanks again.
The best evidence is in ISO 9004, and advanced version of the ISO 9001 standard. It is a very good book to show management. Many of my ISO clients use it instead of ISO 9001.
In the 2005 version, check clauses 4.1, and 7.0-7.1.3.3. An excellent case made for the process approach.
In ISO 9001, you have the intro sections, and cl 4.1, and 8.2.3.
Also, ANAB and APG have written some supportive documents for the process approach. ANAB supposedly requires their CB's to do it. IATF/IAOB for TS have actually written a section into the TS Rules.
Wish they just wrote it as a shall in the standard. Don't know why they don't.
Sidney Vianna
Post Responsibly
Just to clarify. As part of the conformity assessment protocol for AS9100C, the AS9101D document will mandate the completion of several forms, one of them being the Objective Evidence Record (OER). This OER table will be used so the auditors provide a record of the objective evidence assessed, during the audits. As this matrix contains (if I am not mistaken) 463 rows of evidence to filled, one can see that it will be a time consuming exercise.
The inclusion of the OER in 9101D was a contentious issue, but, as it was felt that the audit reports must provide evidence of what has been assessed during the course of the audit, the OER was kept as part of the mandatory forms.
<snip>
Read through this thread and you'll see why a "shall" would be a terrible idea in the absence of a much more rigorous definition than what ISO currently offers. No one knows exactly what "process approach" means, and unless a bullet-proof auditable definition is forthcoming, there won't be a "shall."
dknox4
Thank you.
Thanks again.
Related to TS, some customer specific requirements require auditor training to include the "process approach".
IMHO there should not be an issue with how you audit to the standard. You should be able to audit using the process approach against the standard without getting buy-in or agreement from anyone.
snappy
While the "Process Approach" makes a lot of sense, it is a recommendation and not a requirement. If an organization decides to audit based on the clause-by-clause approach, that is their choice. If the process approach is not well understood or not well implemented, it may be a better choice for such an organization.
Stijloor.
IMHO,the requirement to use the process approach resides in 4.1.
Status
S Poll result difference : how do you read it? Statistical Analysis Tools, Techniques and SPC 4
S Management Responsibility - Is Top Management Committed poll Quality Manager and Management Related Issues 59
smryan Vacation Package Poll Coffee Break and Water Cooler Discussions 17
D Interesting graphic of BCS (college football coaches' ballots) Poll Coffee Break and Water Cooler Discussions 5
T Internal Audit Yield %'s (Poll included) Internal Auditing 16
R Poll for six sigma project leaders: What are the difficulties and failure factors? Six Sigma 1
Claes Gefvenberg Let's do age! How 'Old' will you be in 2007? A poll - Version 3 Coffee Break and Water Cooler Discussions 91
Wes Bucey Super Bowl poll - Closes 3 February 2007 Coffee Break and Water Cooler Discussions 54
R The "I only want the paper" poll Coffee Break and Water Cooler Discussions 45
Icy Mountain Statistical Puzzle with Poll Coffee Break and Water Cooler Discussions 17
Tim Folkerts NCAA football polls, BCS, etc - Specifically the USA Today Coaches Poll Coffee Break and Water Cooler Discussions 8
Miner Poll: How do you comply with the ISO 9001 requirement for Mapping Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Research paper poll - Has ISO9001 helped your company improve / be more competitive? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Customer Poll (Satisfaction Measurement) - Meeting Requirements but Negative Replies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Poll : Inspection for Conformity - Proportion of man hours spent? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Hershal MU course in Spanish - poll Training - Internal, External, Online and Distance Learning 1
Marc Registered User Article Poll - February 2005 Registered Visitor Articles Archive 5
Marc Registered User Article Poll - January 2005 Registered Visitor Articles Archive 0
Marc Registered User Article Poll - December 2004 Registered Visitor Articles Archive 2
Marc Registered User Article Poll - November 2004 Registered Visitor Articles Archive 2
Marc Registered User Article Poll - October 2004 Registered Visitor Articles Archive 7
I ISO registered companies, and our poll: ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc Registered User Article Poll - September 2004 Registered Visitor Articles Archive 1
C Seeking APQP project plan done in Microsoft Project / Poll on Web Data Collection APQP and PPAP 14
Marc Registered User Article Poll - August 2004 Registered Visitor Articles Archive 1
Marc Registered User Articles Poll - July 2004 Registered Visitor Articles Archive 8
Marc Registered User Articles Poll - June 2004 Registered Visitor Articles Archive 5
Marc May 2004 Articles Poll (Vote) Thread Registered Visitor Articles Archive 12
Marc Poll Types: Blind vs. Open - Article Vote/Poll Thread Registered Visitor Articles Archive 7
Marc Is Your Company Registered to ISO9001:2000? Poll Starting 15 May 2004 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
Marc Quality Digest 2004 Salary Survey - Yearly Elsmar Cove Poll - Where do YOU stand? Career and Occupation Discussions 17
Q Poll: Does TS 16969 have more CSR (Customer Specific Requirements) than QS-9000? IATF 16949 - Automotive Quality Systems Standard 10
RoxaneB ISO 9001:2000 Transition Poll Discrepancy? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
RoxaneB Coffee Break Forum Poll - Take II Coffee Break and Water Cooler Discussions 20
M ISO 9001 Certification - Successful First Registration Audit? (Poll) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 76
T How Much Time Do You Spend Training A New Internal Auditor? (Poll) Internal Auditing 56
T Do You Consider Your Quality Policy Valuable to your Organization? (Poll) Other ISO and International Standards and European Regulations 44
G What Is Your Company's Head Honchos Background - Poll Misc. Quality Assurance and Business Systems Related Topics 28
Q Passing CQA Exam - Passed on first attempt? Second? A Poll General Auditing Discussions 22
E Hunting and Fishing Thread - With Poll Coffee Break and Water Cooler Discussions 646
Claes Gefvenberg A poll for those of you with more than one management system or std: Other ISO and International Standards and European Regulations 2
E Let's do age! How 'Old' are you? A poll - Version 2 Coffee Break and Water Cooler Discussions 223
A How the wording of a poll affects the outcome Misc. Quality Assurance and Business Systems Related Topics 5
Marc The ASQ Salary Poll - 2001 through 2003 Career and Occupation Discussions 42
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
