Portable Magnetic Hardness Testers - Aerospace
Marc
Fully vaccinated are you?
A quick "Bump". My Thanks in advance to anyone who can help with this one.
Michael_M
Is anyone using - or do you know of anyone using this type of portable hardness tester? - see link below - model Qualimag DR
https://www.worldoftest.com/portable-hardness-tester-magnetic-type-qualimag-series
We would like to buy/use but the issue is that I am not finding anyone using it- so that I can have some feedback - manufacturer is quite difficult to obtain information.
Thank you in advance.
I have not used that specific model, I have used something like this and had to return it. I found out it was designed for large, non-portable material. At the time, I did not know hardness testing required that 'massive' of parts. Our parts are too small for portable hardness testing.
phoenix2368
What kind of hardness tester you are using right now. I am looking for a hardness tester and our products are also small , general surgical instruments like forceps and scissors , clamps, rongeurs etc.
JeantheBigone
phoenix, if your parts are too small for Rockwell hardness, the only reliable way to get a hardness reading will be by sectioning, mounting and polishing and measuring using Vickers microhardness.
Depending on the geometry of your parts, you may be able to get a Vickers hardness reading on the surface; my experience has been that surface measurements often differ from measurements done on cross sections.
Hope this helps.
