Paul F. Jackson
Position deviations in 2d or 3d are computed from the difference between the basic and actual X, Y, Z position of the feature. Therefore the radius or diameter of deviation is dependent on the independent X, Y, & Z variables.
Isn't the position deviation itself also an independent variable with respect to its magnitude from part to part.
Couldn't the deviation in X be a dependent variable with respect to the feature's form, orientation, and the chosen method of finding its center (least squares, Max inscribed, etc.)
