Position of a milled hex - Print Callout
E
echoone
I am wondering if my interpretation on this call out is correct. Please see attachment. Is it stating that the milled hex surfaces are to be between two parallel planes that are .010 apart relative to datums B and A?
N
ncwalker
Yes. And don't forget position has a built in perpendicularity. Which means this is true at any depth of the hex pocket.
Also, it is a crappy tolerance.
1 - the "width" callout of the tolerance zone of .010 is redundant with the true position.
2 - the diameter is totally wrong, it's not a diameter.
E
echoone
Thank you, for your help. Should it have been called out with a .371 basic? Secondly I was engaged in a debate with production floor. They stated that because of the diameter symbol the .010 position only applied to the hex that is tangent point to a constructed diameter.
N
ncwalker
The problem is that position, while a valid control, may confuse people because they can't grasp how to apply it. It actually defines a cylindrical tolerance shell AT the diameter. But the simplest way to interpret it is is as a cylinder on the center with a diameter of the true position callout. This makes people think "round." But true position can be applied to any shape.
If it were me, I would have either gone from the center of the hex to the midpoint of the side OR the width across the flats and controlled it with symmetry. Then marked it 3X to cover the other flats (or 6X if I chose the radius method).
To your shop floor guys - ask them this ..... If the control only controls the tangent points of the flats, then what, exactly, controls the corners?
(In other words, they are wrong. The entire shape is controlled. But again, the callout is just implemented poorly).
V Remote QMS Coordinator Position Job Openings, Consulting and Employment Opportunities 0
L GD&T Position for surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
J New Job Position - Achieving ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 5
T Question about Quality Department employee position titles Quality Manager and Management Related Issues 10
L Form-dependent position prevention control FMEA and Control Plans 1
M Informational EU – Official position on EUDAMED delay Medical Device and FDA Regulations and Standards News 6
F Position of Quality Manager - Can the organization's Quality Lead be shown as Quality Manager of the lab as well? ISO 17025 related Discussions 5
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
F Conversion of coordinate dimension holes to position dimension Design and Development of Products and Processes 3
B Design of fixture checking including Position of hole and slot General Measurement Device and Calibration Topics 5
CCaantley Stepping Down from my quality manager position soon After Work and Weekend Discussion Topics 18
was named killer AS9100 FAIR - True Position hole out by .0011" on 50 parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Informational COCIR Position Paper Harmonisation of Standards for Medical Devices Medical Device and FDA Regulations and Standards News 0
B True Position Measurement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Position paper Team NB Statement - Patient safety EU Medical Device Regulations 0
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
P True Position vs X and Y Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
Ron Rompen Ford Method - Position Capability with MMC Modifier Capability, Accuracy and Stability - Processes, Machines, etc. 14
M True Position / GD&T - I'm staring at this drawing and I'm lost Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
O How to deal with Multiple Datums - Position with respect to Multiple Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J New position and AS9100 audit is 1 month away- need advice AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
N True Position of slot Boundary with MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Position Tolerance Called to Datums with MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
N Procedure for determining pinhole position in condom Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Measuring the True Position of a Cylinder's Pierce Point Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Offered Management Position - Limited Experience - Any Concerns? Quality Manager and Management Related Issues 13
C Dose Mapping - How to relate back to Routine Monitoring Position ISO 13485:2016 - Medical Device Quality Management Systems 3
T Optical Comparator measuring of Position of a Threaded Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Shall I apply for this job position (Quality Manager)? Career and Occupation Discussions 5
E Composite Position Calculation on a 12 X 4 Hole Pattern Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
M Manager IMS (9001, 14001, 18001) Position in Organisation Chart ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
V GD&T Interpreting Datums in Two Single Segmented Position Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M True Position and MMC (Dilemma Between Engineers) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Just starting out looking to get into a quality engineer position Career and Occupation Discussions 2
P MDD position on Final Inspection/Release Employee Experience/Training EU Medical Device Regulations 1
S Tab to circle True Position? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S GD&T Callout for Diametrical True Position Manufacturing and Related Processes 6
S Moving to a New Company for a New Position Coffee Break and Water Cooler Discussions 3
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
L ASME Y14.5 Coaxial Feature Toleranced with Position w/o Reference Datum Design and Development of Products and Processes 2
M Surface Profile and True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D True Position with 1 hole (Datum B) at the Radius Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Position vs. Concentricity vs. Runout - Measurement of a Tube Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L GD&T Bonus Tolerance - Checking True Position of a Pierced Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Using a Pin Gage to check True Position of Inline Holes, Design, Tolerance. Etc Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
