Position vs. Concentricity vs. Runout - Measurement of a Tube
mitchkerbs
I have a drawing from a customer that specifies the position of the outer diameter of a tube be 0.020 with the inner diameter of the tube being the datum. Customer has stated the the OD of the tube "needs to be concentric to the id of the tube with .010. Rest the tube on 2 “v” blocks near each end and indicate the id while rolling the tube."
I am puzzled by the drawing calling out position, the customer referencing concentrcity, and then telling me to measure runout.
Can someone help me understand why my indicator reading can only be half of the position callout?
Thanks a million!
Michael_M
This seems to me to be one of those call outs where the designer did/does not know exactly what they wanted. True position, concentric, and run-out can be used interchangeably in some cases depending on exactly what they want.
I believe the reason they are cutting your tolerance in 1/2 is based on the common rule for true position, Square root of (error in 'x' squared + error in 'y' squared). Then multiply by 2 since most of the time you are dealing in radius not diameter when working in this formula.
I would contact the customer or just reduce the run-out to .010.
Hullo Mitch,
Rest the tube on 2 ?v? blocks near each end and indicate the id while rolling the tube.
Which would mean using the OD as datum instead of vice versa... Just to be sure: Would it be possible to show us the drawing requirement? I feel a bit puzzled myself right now, but I agree with Michael about the tolerance cut in half. :)
/Claes
True Position
Your indicator will read a (otherwise perfect) difference of 0.010 absolute position somewhere at +0.010 and -0.010 rotated 180 degrees.
Reluctance
I agree with Michael_M on the customer possibly not understanding what they are looking for on the print.
The true position tolerance called out could possibly be done using a dial indicator but not with very good repeatability. First of all they have switched the datum as Claes has already pointed out. Second, the readings from the dial indicator using the setup the customer describes are telling you more about wall thickness which is more like a profile tolerance than true position tolerance. Profile tolerance can give you true position, but it is more restrictive. For example, in manufacturing your part could be made up of two ovals with their major axis at 90? to each other and still be within the true position tolerance. However they would fail at this measurement method that is giving you profile tolerance.
Using the indicator you could try to account for this by recording the indicator reading at set points around the circumference of the part and calculate true position with the addition of an outside diameter measurement of the part at the respective points measured using the indicator. Or you could just have this done automatically on a CMM.
Measuring runout requires keeping your part stable with respect to an axis of rotation. Rotating a cylinder on v-blocks does not keep the axis of rotation in the same position unless the cylinder is perfectly round. So you really are not measuring runout using the recommended setup either.
It is probably time to sit down with the customer and determine what it is they are really looking for from your product. If they want to ensure control of the size of the outside diameter with respect to the inside diameter they can continue to use the true position tolerance, but they need to find a more appropriate measurement method. Another alternative would be to change the tolerance to a concentricity tolerance, but again the measurement method would need to be changed to suit the tolerance. If they change to a profile tolerance the recommended measurement method could be potentially be kept but there is some cosine error that would need to be accounted for.
Isn't GD&T fun? :D
V Remote QMS Coordinator Position Job Openings, Consulting and Employment Opportunities 0
L GD&T Position for surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
J New Job Position - Achieving ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 5
T Question about Quality Department employee position titles Quality Manager and Management Related Issues 10
L Form-dependent position prevention control FMEA and Control Plans 1
M Informational EU – Official position on EUDAMED delay Medical Device and FDA Regulations and Standards News 6
F Position of Quality Manager - Can the organization's Quality Lead be shown as Quality Manager of the lab as well? ISO 17025 related Discussions 5
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
F Conversion of coordinate dimension holes to position dimension Design and Development of Products and Processes 3
B Design of fixture checking including Position of hole and slot General Measurement Device and Calibration Topics 5
CCaantley Stepping Down from my quality manager position soon After Work and Weekend Discussion Topics 18
was named killer AS9100 FAIR - True Position hole out by .0011" on 50 parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Informational COCIR Position Paper Harmonisation of Standards for Medical Devices Medical Device and FDA Regulations and Standards News 0
B True Position Measurement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Position paper Team NB Statement - Patient safety EU Medical Device Regulations 0
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
P True Position vs X and Y Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
Ron Rompen Ford Method - Position Capability with MMC Modifier Capability, Accuracy and Stability - Processes, Machines, etc. 14
M True Position / GD&T - I'm staring at this drawing and I'm lost Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
O How to deal with Multiple Datums - Position with respect to Multiple Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J New position and AS9100 audit is 1 month away- need advice AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
E Position of a milled hex - Print Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N True Position of slot Boundary with MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Position Tolerance Called to Datums with MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
N Procedure for determining pinhole position in condom Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Measuring the True Position of a Cylinder's Pierce Point Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Offered Management Position - Limited Experience - Any Concerns? Quality Manager and Management Related Issues 13
C Dose Mapping - How to relate back to Routine Monitoring Position ISO 13485:2016 - Medical Device Quality Management Systems 3
T Optical Comparator measuring of Position of a Threaded Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Shall I apply for this job position (Quality Manager)? Career and Occupation Discussions 5
E Composite Position Calculation on a 12 X 4 Hole Pattern Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
M Manager IMS (9001, 14001, 18001) Position in Organisation Chart ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
V GD&T Interpreting Datums in Two Single Segmented Position Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M True Position and MMC (Dilemma Between Engineers) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Just starting out looking to get into a quality engineer position Career and Occupation Discussions 2
P MDD position on Final Inspection/Release Employee Experience/Training EU Medical Device Regulations 1
S Tab to circle True Position? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S GD&T Callout for Diametrical True Position Manufacturing and Related Processes 6
S Moving to a New Company for a New Position Coffee Break and Water Cooler Discussions 3
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
L ASME Y14.5 Coaxial Feature Toleranced with Position w/o Reference Datum Design and Development of Products and Processes 2
M Surface Profile and True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D True Position with 1 hole (Datum B) at the Radius Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
L GD&T Bonus Tolerance - Checking True Position of a Pierced Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Using a Pin Gage to check True Position of Inline Holes, Design, Tolerance. Etc Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
