Possible Actions for Nonconforming Product besides issuing NC
ryuqina
hi.. Im am new in QA/QC. Recently my company received product from our supplier.however the product is out of spec.what can i do beside writing non conformance report to our supplier. If we decide to reject the product that's mean i just returned back the items and ask the supplier to compensate us or replace with improved design of the product?
Any suggestion?
thank you.
amit_rd
Any suggestion?
thank you.
Welcome & congratulations on winning half the battle by thinking beyond writing a NC report.
As you depend on the supplier for the quality of this part - I recommend a join exercise with the supplier (Off course depending on the criticality of this part) to understand
1st - Why it was not checked and identified at supplier location - This safeguards your organization as an interim measure
2nd - Why was it produced - More focus is to be given on that as it resolves the exact issue.
In today’s environment its important to work hands in hands with suppliers to improve their capabilities as it in turn saves you a lot of money.
harry
................. If we decide to reject the product that's mean i just returned back the items and ask the supplier to compensate us or replace ........................
Unless your organization is new, chances are you should have an existing procedure to take care of this situation somewhere.
1. If you have a QMS, look for it in the 'disposition of NC goods' section.
2. If you don't, someone in your organization may know about it. Check/ask and bear in mind a procedure can exist in unwritten form.
3. Check with Account/finance. Most will have goods return note or similar type of document with instructions on what to do and the necessary credit/debit.
ssz102
first, separating and identify the NG parts
second, if your company have a procedure that deal with the NG part, you can follow it;
if have not, you see if the defects are affect the function or using of product, or the defects is cosmetic, then decide the method of conduct; including return to supplier or sorting?
somashekar
Along with amit's points, find out if there were any gaps in the inputs that you provided to supplier, which might have also been a cause for the NC products.
Deval
If you are sure that the products are nonconform, ask you finance department to block the invoice payment for this supplier. After, of course, try to solve together with supplier the problem and to avoid this problem for the future.:agree:
Deval
TRshepherd
You didn't mention if your are in the Automotive, Medical, or other supply chain.
Reactions are very different from one field to another and take for instance within the Automotive supply chain of GM the reactions will vary from location to location and whithin the supply chain it self from Tier to Tier.
The systems are more difficult the closer you are to the OEM.
For example here is a real life occurance this month with GM for a service part which they must have considered us a Tier 1.
We recieved a PRR (Problem Reporting and Resolution) from GM Plant X for missing components on an assembly.
We mold a Thermoset component that is assembled at another supplier then sent to GM service Plant.
The supplier that did the assembly went out of business and we were notified to send the part to GM Service.
GM uses a system call Covisint which has evolved over time from a materials management system to let's beat up the supplier system in some cases.
In fact it is difficult to follow the system without taking liability even before the investigation is complete. Guilty until proven innocent.
Of course their system was trying to order a component thinking it was an assembly - the aggravating fact is that this PRR is given to us every few years for an error in their system.
They eventually take the parts and say they will fix the error.
Taking time and money in wasteful manner over and over.
Sometimes a little common sense should prevail.
Sorry getting off track...
The common sense approach in my opinion is to confirm the non-conformance, contain the suspect product, perform the investigation with the suppliers help to reveal the root cause, develop counter measures with the supplier to reduce or eliminate the root cause - if the liability falls to the supplier work with the supplier to impliment cost effect methods to reduce the probabilty of a repeat.
Then write the ticket for liability.
Tom:2cents:
S Remaining compliant while not all possible service actions are recorded. Internal Auditing 3
K Is it possible to avoid the OQ? ISO 13485:2016 - Medical Device Quality Management Systems 8
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
supadrai Possible to Submit a 510(k) if you have never, do not and cannot produce the device for which you're submitting the application? US Food and Drug Administration (FDA) 4
J Possible to get ISO 13485 certified with only OEM Product? ISO 13485:2016 - Medical Device Quality Management Systems 4
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
M Informational EU – Possible EUDAMED delay Medical Device and FDA Regulations and Standards News 3
M Is it possible to get iso 13485:2016 certified as a one man band ISO 13485:2016 - Medical Device Quality Management Systems 1
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
dhuot1990 USP 41 Hanging Scale - Is it possible to make a hang scale adhere to USP41 Standards? ISO 17025 related Discussions 3
F Apple Watch is not a medical device. How can this be possible? CE Marking (Conformité Européene) / CB Scheme 1
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
B Integrated management system - ISO 9001 and ISO 14001 - Is possible to have a joint certificate covering both standards? ISO 14001:2015 Specific Discussions 6
E Is it possible to start an ISO 9001 QMS from scratch (Really) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Some possible misunderstandings on the application of ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
P Is it possible to make an educated decision using a very very small sample size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
a_bardi Is it possible to exclude internal audit from qms scope? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G ISO 9001:2015 - Is control possible with Excel adaptable measurement sheets? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
S Indications for Use - Is it possible to have a different indication for use EU Medical Device Regulations 1
C %GRR <10% not possible. How to get approval by auditor? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
I Is risk acceptability really needed if all risks must be reduced as far as possible? ISO 14971 - Medical Device Risk Management 6
M Is Automated Internal Auditing Possible? Internal Auditing 13
A Integrated Management Systems - ISO 50001 and ISO 9001 possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Is it possible to receive EASA STC within 48 hours after modification? EASA and JAA Aviation Standards and Requirements 1
3 Israel: 1 Medical Device, Multiple Registrations = Possible? Other Medical Device Regulations World-Wide 3
Marc Yahoo probes possible huge data breach - BBC News - 2016 World News 1
Marc Yahoo probes possible huge data breach World News 0
S Preparing a Root Cause Report - Possible Root Causes Document Control Systems, Procedures, Forms and Templates 11
M Future of ISO 14971 - Possible revision? ISO 14971 - Medical Device Risk Management 9
M Is IEC 60601 compliance possible when only generic power-supply is specified? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Is it possible to have more than one authorized representative in Saudi Arabia? Other Medical Device Regulations World-Wide 6
Y Is it possible to check the authenticity of a CFDA registration certificate? China Medical Device Regulations 7
T Reduced Audit days when UPGRADING from AS9100 to TS16949 - Is it possible? IATF 16949 - Automotive Quality Systems Standard 2
Ajit Basrur Is Biocompatibility study performed on medical devices for possible contaminants? Other Medical Device Related Standards 4
B Subsidiary - No Managing Director - Is ISO 9001 Certification Possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Is it possible to randomly select samples from 1 column to many column Using Minitab Software 2
Marc Google Fiber chooses nine metro areas for possible expansion After Work and Weekend Discussion Topics 1
Hershal ILAC is preparing to start the possible revision to ISO/IEC 17025 ISO 17025 related Discussions 2
0 Is it possible to use a threaded ring gage to calibrate the M8 gage? Calibration and Metrology Software and Hardware 4
A Is it possible for STC application before issue of TC ? EASA and JAA Aviation Standards and Requirements 4
B Is it possible that a virus sends spam on Facebook? After Work and Weekend Discussion Topics 6
Ronen E Incretin Mimetic Drugs for Type 2 Diabetes: Possible Increased Risk Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
R Is it possible for medical power supply to declare CE based on MDD? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Is it possible to have a General Change Control SOP and Form? Document Control Systems, Procedures, Forms and Templates 6
J Quality Management Process Model Possible Interactions and Effects ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Is it possible to have two QMSs? One for each or our two products EU Medical Device Regulations 9
T Is "World Class" Quality possible by Accident? Coffee Break and Water Cooler Discussions 18
J Two Quality Management Systems - ISO 13485 in one company possible? Quality Manager and Management Related Issues 4
Marc Great Lakes - 24 foot waves possible! October 2012 Coffee Break and Water Cooler Discussions 1
