Posting Non-Quality System instructions on the Production Floor
Medical Device industry. Thoughts on how to post instructions on the Production Floor that are for processes outside the Quality System. Processes such as how to scan a kanban card. Or instructions for using the Fastenal vending machine (gloves, masks, etc.)
we don’t want to make them controlled work instructions.
We are considering stamping the document but are unsure how to stamp… “For Reference Only” isn’t really applicable and “Uncontrolled” seems triggering in an audit situation.
thoughts? Suggestions?
Randy
Let me get this straight........You've gotta have written instructions on how to use a "vending machine"?
What are the "kanban " cards to be used for? Something tells me that without them you've an expectation of problems cropping up.
It’s not a snack machine. It’s a vending machine for shop supplies. And there are inputs into the machine to work the machine. The instructions are from Fastenal, the supplier who owns the machine (and fills it).
Kanban is an inventory control system. When the inventory hits a certain level, the kanban card is pulled and scanned notifying purchasing that they need to place an order.
Steve Prevette
Deming Disciple
In my line of work (not medical) we called those "operator aids" and there were specific requirements:
Operator aids should be viewed as a convenience to the individual using them, not a requirement. Although copies of procedures or portions of procedures can be used as operator aids, the requirement is to follow the procedure. The operator aid makes it easier for the operator to follow the procedure, because the procedure is conveniently posted, but there should be no requirement to use operator aids instead of the procedure in the manual. All personnel should be trained on the need for controlling posted information. This training should cover why it is important to use only approved operator aids, how to tell if an operator aid is approved, what to do if it is not approved, and how to verify that an operator aid is current. When an operator aid is used, the user should verify that it is approved. If the posted information is not approved, the person should not use it and should notify the supervisor. A decision should be made whether to submit the operator aid for approval or remove it. If the operator aid is unusable because of wear or dirt, the operator should obtain a new copy of the operator aid. When the need for an operator aid no longer exists, an operator or the developer/organization originating the operator aid should notify the appropriate supervisor and ensure that the operator aid is disposed of in accordance with facility policies and procedures.
Conduct of Operations Handbook (doe.gov)
Thank you! Very helpful! We do have a “Job Aid” Process and it is on the table as a potential solution. It is not our preferred path because while they live outside our Quality system, they are still controlled. Hoping to find a solution to prevent over complicating such a simple thing.
Steve Prevette
Deming Disciple
You are welcome. I would suggest that SOME degree of control is needed, been there done that. Warning signs of problems are
operator aids that may be valid, but override formal procedures that are in dire need of revision;
operator aids that "cut corners" intentionally or unintentionally;
operator aids that contain out of date guidance; or
operator aids that are a work-around for a safety or quality condition.
Randy
Then it's not a "for reference document" therefore control would be an expectation if I were doing your 3rd party audit (which is all I do)
No kidding, not a snack machine..........The process is essentially the same. The Fastenal instructions are documents of external origin that have been determined to be necessary and yep, pretty much not "for reference" as well if you deem them "necessary" to achieve a desired result.
Randy… thanks for the reply. 9 times out of 10 my kind of question arises because someone is trying find a path around the process. Shortcuts always become problems later on. Better to bite the bullet. But as Sidney’s cartoon reflected sometimes it’s just stupid! :cool:
Jim Wynne Strange Behavior in MS Edge Browser Affecting Posting Here Coffee Break and Water Cooler Discussions 4
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
Marc Posting Job Openings - Read Me Please - 27 January 2019 Job Openings, Consulting and Employment Opportunities 0
E Does posting your IFU on your website constitute elabelling? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Electronic Document Control - Posting a process at work station ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P What are you most concerned/afraid of when posting here? Coffee Break and Water Cooler Discussions 32
B Delay in Payment Posting - Customer would like to stop paying monthly amortization Customer Complaints 5
B Document Control - Document Location and Posting Only the Pages Needed Document Control Systems, Procedures, Forms and Templates 2
Marc UK Executive Forced Out of Job For Posting Resume On LinkedIn Career and Occupation Discussions 2
D QA Manual question - First time posting Quality Management System (QMS) Manuals 1
B Posting Section 206 of 10 CFR Part 21 though out our plants Various Other Specifications, Standards, and related Requirements 2
G Posting of Initials or Names on a Computer Document as Proof of Approval or Task Done Document Control Systems, Procedures, Forms and Templates 3
Scott Catron PLEASE READ before posting or viewing threads Funny Stuff - Jokes and Humour 0
Sidney Vianna UKAS is posting accreditation suspensions now Registrars and Notified Bodies 3
L Posting portion of standards internally? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V Memos - Nonconformance as illegal posting of work instruction Document Control Systems, Procedures, Forms and Templates 15
L Posting Of Work Instructions at Job Site Document Control Systems, Procedures, Forms and Templates 7
F Using non-randomized clinical study for change in existing 510(k) device? US Food and Drug Administration (FDA) 1
L Non Applicability of Clauses in ISO13485 for Medical Devices Medical Device and FDA Regulations and Standards News 4
B Transport Validation For Non-sterile Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
T Justification of use of non-harmonized standards for MDR conformity Other Medical Device Related Standards 12
L Saudi regulations for Japanese non sterile scopes Japan Medical Device Regulations 0
D Is a lost calibrated tool an non-conformance for an audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 58
B Leadership non-conformity, Top Management's involvement in Problem Solving IATF 16949 - Automotive Quality Systems Standard 10
malasuerte Performance of ISO 9001 certified vs. non-certified manufacturing companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
cgaro62 Does FDA apply to a non-medical 13485 certified custom manufacturing company? ISO 13485:2016 - Medical Device Quality Management Systems 11
K Non-Device MDDS Clarifications (FDA) US Food and Drug Administration (FDA) 7
S Non-approved supplier? Supplier Quality Assurance and other Supplier Issues 3
R FMEA's for non-manufacturing sites FMEA and Control Plans 4
D Shelf life of non sterile class IIb product. ISO 13485:2016 - Medical Device Quality Management Systems 1
ChrisM Class 1 non-sterile device, need certified QMS or not? EU Medical Device Regulations 2
N Non-dairy Creamer US Food and Drug Administration (FDA) 3
G Shipping Validation of Non-Sterile Parts? Other Medical Device and Orthopedic Related Topics 9
Edward Reesor Class I non-sterile "Shelf Life" labeling (EU/UK) CE Marking (Conformité Européene) / CB Scheme 4
E Comparing process parameters on non-normal batches Capability, Accuracy and Stability - Processes, Machines, etc. 11
A QMS inside a Non medical device firm ISO 13485:2016 - Medical Device Quality Management Systems 4
A Non-Conforming Work ISO 17025 related Discussions 1
JoCam Non CE marked device for customer review Other Medical Device Regulations World-Wide 0
D RESPONSE TO NON-CONFORMITIES IATF 16949 - Automotive Quality Systems Standard 6
B Software as a NON-medical device Medical Information Technology, Medical Software and Health Informatics 23
M Is this situation Non-Conformity??? General Auditing Discussions 8
D AS9100 Rev D - Clause 8.7 Control of Non conforming outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Non conformance/complaint and CAPA ISO 13485:2016 - Medical Device Quality Management Systems 6
F Product classification according to the 60601-2-57: Particular requirements [...] of non-laser light sources [...] IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Q API Spec Q1 9th Ed 4.4.2 Non-conformance Oil and Gas Industry Standards and Regulations 8
T Do I need to add non-product related service providers to my ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
J ISO 13485- 8.3.1 Non-conforming material high volume ISO 13485:2016 - Medical Device Quality Management Systems 4
F MSA for non-contact CMM - ISO10360 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M Using a Non Certified vendor Supplier Quality Assurance and other Supplier Issues 5
somashekar Justification for Non-applicable clause at Stage 2, in clause 4. ISO 13485:2016 - Medical Device Quality Management Systems 11
