Pp and Ppk indices - Is it statistically possible to have a Ppk greater than Pp?
The Taz!
#11
Darius said:
I don't really understand
How can you have Pp if you have a unilateral tolerance?
The equation is: pp = (USL - LSL) / (6 Sigma)
If a software make calculations of pp without one of the specs, IMO is wrong.
:bonk:
My point to start with. . . I'm out of here
Darius
#12
Taz, I readed your first poll in this and found that it wasn't necessary to say anything else.
:agree1:
But this topic goes on and on, it's a nonesense, Bev D, sorry Donald Wheeler said that Cp is greater than pp but one exception (bad sampling), nothing about pp being bigger than ppk.
I agree with Taz,
To answer your question, "Not on this planet" . . not even with New Math. . .
As for the ASQ guy, look for another Guru.
:bonk:
Darius
#13
FYI
I readed an article where it commented that in their example cpk being bigger than the cp, I still don't tink it to be possible but..., I checked on the formulas (because only variances, and indicators appear, no limit, no target, and no original data), and I found that the example was unilateral spec LSL and cp was calculated with te next formula:
cp = (Target - LSL)/(3 Sigma)
I tink that cp MUST NOT BE CALCULATED FOR UNILATERAL SPECS, but the formula in escence looked OK.
and cpk in the traditional sort for unilateral LSL spec
cpk= (Mean - LSL)/(3 Sigma)
I started to tink how to obtain cpk > cp (with that calculations, THAT I AM NOT AGREE), and is clear that is possible if the target is nearer than the mean from the spec limit. So some guys can tink it to be posible.
:bonk:
The Taz!
#14
Thanx
Darius,
My point was for Unilateral tolerances only and that there is no Cp or Pp for unilateral tolerances. If it does not exist, how can another index be compared to it.
Thanx for the follow-up.
Darius
#15
:thanx: Tanks Taz, I tried to show why some guys can tink it posible, as I said in the lasts posts, I agree with you in every point of this topic.
Cp or pp CAN NOT BE CALCULATED FOR UNILATERAL, because the Cp, Cpk, pp, ppk take in account that the specs are centered on the target, so, if you calculate it with
cp = (Target - LSL)/(3 Sigma) or cp = (USL - Target)/(3 Sigma)
you implicate that the other spec limit exists, and there is two possible ways:
1- that the tolerance is just from the target to the limit, desto, the other spec limit is on the target (the target not centered on specs, and so violate the consideration that the target is centered on specs).
2- That the other limit is at the same distance from the "official spec", so it's wrong to calculate the cpk/ppk with only the "official spec".
:lmao:
Dave Dunn
#16
I think a lot of confusion comes into play when describing unilateral/bilateral tolerances, and describing a dimension that due to its nature is "unilateral/bilateral". Tolerance describes what is "permitted", the physical actuality of the dimension describes what is "possible".
For example:
Widget A is specified at 1.000±.005" This is a dimension that I would consider to be "bilateral", and the tolerance also is bilateral.
Widget B is specified at 1.002+.003/-.007" this is a "bilateral" dimension with an unequally distributed bilateral tolerance.
Widget C is specified at 1.005+0/-.010" This is a bilateral dimension, but a unilateral tolerance. Note however that the resulting tolerance permitted is the same as the first example. Tolerance might be shifted to the lower side due to design intent.
Widget D is specified at 1.000" max. This is a unilateral dimension. It is not "permitted" to be larger than 1" in length, however it is not physically possible for something to be of a size smaller than zero. This type of dimension does not have Cp or Pp calculated, but can have Cpk and Ppk calculated from the maximum tolerance.
What it boils down to is, if it's possible for your measurement to exceed your upper and lower limit, you can calculate Cp/Pp. If one or the other is not possible, then your dimension is one-sided and only Cpk/Ppk apply.
Paul F. Jackson
#17
Pp and Cp make little or no sense for examining the potential capability of a unilateral tolerance specification where one limit of the tolerance can only be approached but never exceeded (zero-perfection or infinity). The target for the distribution of a unilateral geometric tolerance (flatness, position, profile, parallelism, perpendicularity) that has a maximum value specified is zero.
There can however be a difference between the potential capability and the current capability of distributions of unilateral geometric tolerances. The measurement data for many of these specifications is a reflection of the size of the tolerance zone required to contain the deviation. Therefore if a tolerance zone for surface profile was given as 1.0 and a point above the basic (or theoretically exact) profile measured +0.25 then it would take a tolerance zone of 0.5 equally displaced from the basic profile + & - 0.25 to contain it.
The data that we analyze for Cpu reflects the value 0.5 as it relates to the specification 1.0. If 30 of the measured points ranged from +.15 to +.35 the capability to the specification would be figured from a distribution with a range of 0.3 to 0.7. The potential capability for that distribution however lies in examining the distribution as if it was centered on the basic profile. A mean shift for the distribution of these points might yield a range of -.1 to +.1 then none of the resultant zones would exceed 0.2 as compared to the specification 1.0.
This "Potential Cpu" an examination of the potential capability can be accomplished with position specifications by monitoring the individual cartesian coordinates and re-figuring the position deviations with candidate mean shifts for X,Y,& Z.
So I say that Cp and Pp make no sense for these types of distributions but you can predict a potential capability for them. Naturally as the distribution approaches the boundary its shape becomes less-normal and one must use the appropriate statistical analysis or transformation to make the prediction.
B Sample Size based on Process Capability Indices (Pp/Ppk)? Capability, Accuracy and Stability - Processes, Machines, etc. 20
C Is it possible to get Pp,Ppk more than the within subgroup (Cp,Cpk's) indices? Statistical Analysis Tools, Techniques and SPC 7
Tim Folkerts Interpreting the common capability indices: Cp, Cpk, Pk, and Ppk. The Reading Room 5
B Attribute capability indices - Cpk and/or Ppk value for an attribute type of feature Capability, Accuracy and Stability - Processes, Machines, etc. 7
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
D Signal Detection-If Ppk>1, compare measurement system to process. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
S Is there a minimum industry standard for PpK ? Statistical Analysis Tools, Techniques and SPC 8
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Customer requires CpK 2 and PpK 1.5 Capability, Accuracy and Stability - Processes, Machines, etc. 2
R Which of the following indicators is important for Operations - Ppk, Cpk, or Cpm? Statistical Analysis Tools, Techniques and SPC 15
R When Pp>2, and Ppk<1.33, can we approve a new process? IATF 16949 - Automotive Quality Systems Standard 3
U Cpk and Ppk for different Countries/Standards Capability, Accuracy and Stability - Processes, Machines, etc. 7
M Advise on R Chart with Ppk of 17.85 for Ford Capability, Accuracy and Stability - Processes, Machines, etc. 37
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Ppk for Combined Data Sets Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
N How to make a MSA for an Attribute Gauge if the Pp=Ppk=1.33 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Ppk Issue - Some Products have Unilateral Tolerances Capability, Accuracy and Stability - Processes, Machines, etc. 24
F Please share an MS Excel sheet to calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 1
R Ppk vs Cpk: Big Differences - What conclusion can I reach about my process? Six Sigma 3
A How to interpret Minitab Results? What is difference in Cpk and Ppk values? Using Minitab Software 2
J Cpk & Ppk - Reviewing a PPAP Package - Some questions Statistical Analysis Tools, Techniques and SPC 8
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M When a moving range is 0, is it acceptable to have a PP/PPK of 0 also? Statistical Analysis Tools, Techniques and SPC 8
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
V CNC Process Validation Cpk Ppk & In-Process Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Pp/Ppk & Cp/Cpk - Which is appropriate for Long/Short Term Study? Statistical Analysis Tools, Techniques and SPC 20
R Cpk & Ppk and Differences between Minitab and an Excel Spreadsheet Results Statistical Analysis Tools, Techniques and SPC 4
S How is Cpk /Ppk value calculated in Minitab since I have subgroup size of 1 Capability, Accuracy and Stability - Processes, Machines, etc. 1
R Customer Rquest for Real Ppk? Get Real... APQP and PPAP 2
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
A Deciding on when to go for Cp & Cpk or Pp & Ppk Study? Statistical Analysis Tools, Techniques and SPC 3
M Minimum number of samples to inspected for Pp & Ppk study ? Any statistical proof?? Capability, Accuracy and Stability - Processes, Machines, etc. 4
M How to Do Ppk on Non-Normal Data Capability, Accuracy and Stability - Processes, Machines, etc. 10
C Understanding the relationship of Pp, Ppk, Cp, Cpk Six Sigma 4
A Ppk Reporting - Ideas to make it more meaningful for Management Statistical Analysis Tools, Techniques and SPC 3
S Cpk and Ppk Differences and Questions Capability, Accuracy and Stability - Processes, Machines, etc. 5
E Cpk and Ppk template wanted Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q ASQ CSSBB Question on Cpk and PPk , can you solve it ? Capability, Accuracy and Stability - Processes, Machines, etc. 15
J Using Ppk to set up Control Plans - Injection molding Capability, Accuracy and Stability - Processes, Machines, etc. 7
M Calculation of Cpk and Ppk for an unstable process Statistical Analysis Tools, Techniques and SPC 7
Q PPK, CPK of >= 1.67 Automotive Requirement and Auditing IATF 16949 - Automotive Quality Systems Standard 1
