Pp/Ppk & Cp/Cpk - Which is appropriate for Long/Short Term Study?
  • Thread starter Stefanus Simbolon R
  • Start date
Stefanus Simbolon R
Dear all,
when we have a new product, evaluate for short term study use Pp/Ppk or Cp/Cpk?
For evaluating at normal production (long term study), we use Pp/Ppk or Cp/Cpk?
regards
Barbara B
Re: using Pp/Ppk or Cp/Cpk when short term study?
This depends on the definitions used for Pp/Ppk and Cp/Cpk. If you describe a little bit more detailed which norm or customer requirements your question is based on, the answer could be more helpful.
Regards,
Barbara
In order to answer your question so that you understand why the answer we give is the correct one we must first understand the concepts of Cpk and Ppk.
The first concept is that Cpk and Ppk formulas were originally designed for ongoing processes and was conceived as an extension of SPC. Properly designed SPC charts are constructed using a series of small samples – or subgroups – taken over time. In general, when properly designed the parts within a subgroup are created under relatively the same conditions: same raw material, same operator, same equipment, same settings, same tool/fixture/equipment condition, same environmental conditions, etc. Each subgroup is taken far enough apart that some and eventually all of these conditions change so that all variation is captured.
Within subgroup variation therefore represents short term variation. Cpk uses the within subgroup standard deviation (the average of all of the subgroup Standard deviations)
The total variation (within subgroup plus subgroup to subgroup) is the long term variation. Ppk uses the standard deviation of all of the individual values.
(It is important to note that often people use the notation of Cpk as a generic term for a process capability index. They will specify Cpk when they really mean Ppk.)
When a product – or process – is new, there is often limited variation in the various inputs. So there is no way to determine the long term performance. Short term capability can be assessed. The units are all to be created using essentially the same conditions: same raw material, same operator, same equipment, same settings, same tool/fixture/equipment condition, same environmental conditions, etc. Only the sample size is much larger than one would take for an ongoing sampling of multiple subgroups. Typically, the sample size would be from 30-100 units. In this case since there aren’t multiple subgroups the standard deviation is just the single standard deviation on the individual values. The same standard deviation formula as for Ppk. So the short capability calculation for new products looks like the Ppk formula…
Hope this helps
Note: there are many complicating factors that can influence the sampling and interpretation depending on your actual situation…
Mr.Happy
Bev,
Good explanation, to make it complete you might explain what the short terms Pp/Ppk and Cp/Cpk stand for.
:agree1:
Stijloor
Bev,
:agree1:
Goede Middag!
Dr. Gordon Constable answers as follows:
What do the letters in Cp and Cpk stand for?
There is no authoritative answer. Cp has been around for a long time and many believe it stands for Capability of the Process. Others say Process Capability, but that would reverse the letters.
As for Cpk, in the literature that I first saw about Cpk, k was the amount of the difference in the target value and in standard deviations (the number of standard deviations that the process is off target). Before you ask, Pp generally is said to be Process Performance.
Gordon Constable Ph.D
Prettig weekend!
Stijloor.
Barbara B
Like it is written in the quotes Stiljoor provided: It depends.
If you are dealing with german companies, they more often use Ppk as potential process capability and Cpk as process capability index, the latter only being used if it has been proved that the process is in a state of statistical control and the first being applicable in case no SPC or other method has been used to evaluate the process. So Pp/Ppk is in Germany often the "short term" and Cp/Cpk the "long term" capability.
They're referring to a german norm, DIN ISO 21747 which was published in 2006 as a replacement for the DIN ISO 55319 (also a german speciality). And both norms have a lot of flaws concerning the statistical methods, so I wouldn't recommend neither of them, but this is a different topic. They define Pp/Ppk and Cp/Cpk exactly the other way round like they are used in most other countries.
Mr.Happy
Hello Barbara,
Because we do business with German customers I would like to thank you for this additional information.
Danke, :thanx:
M.f.G.
Mr.Happy
It is not the letters (C or P) that matter. It is the formula used to calculate the standard deviation and more importantly the time frame and structure of how much variation was included in the study.
In the end it is about gaining understanding of your process variation and no correct or incorrect definition in some 'standard' should affect that.
D Ford CSR Cpk/Ppk Requirements Statistical Analysis Tools, Techniques and SPC 8
C Capability in sewing processes CP,CPk,PP,PPk Capability, Accuracy and Stability - Processes, Machines, etc. 10
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Customer requires CpK 2 and PpK 1.5 Capability, Accuracy and Stability - Processes, Machines, etc. 2
R Which of the following indicators is important for Operations - Ppk, Cpk, or Cpm? Statistical Analysis Tools, Techniques and SPC 15
U Cpk and Ppk for different Countries/Standards Capability, Accuracy and Stability - Processes, Machines, etc. 7
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
F Please share an MS Excel sheet to calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 1
R Ppk vs Cpk: Big Differences - What conclusion can I reach about my process? Six Sigma 3
A How to interpret Minitab Results? What is difference in Cpk and Ppk values? Using Minitab Software 2
J Cpk & Ppk - Reviewing a PPAP Package - Some questions Statistical Analysis Tools, Techniques and SPC 8
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
V CNC Process Validation Cpk Ppk & In-Process Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
R Cpk & Ppk and Differences between Minitab and an Excel Spreadsheet Results Statistical Analysis Tools, Techniques and SPC 4
S How is Cpk /Ppk value calculated in Minitab since I have subgroup size of 1 Capability, Accuracy and Stability - Processes, Machines, etc. 1
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
A Deciding on when to go for Cp & Cpk or Pp & Ppk Study? Statistical Analysis Tools, Techniques and SPC 3
C Understanding the relationship of Pp, Ppk, Cp, Cpk Six Sigma 4
S Cpk and Ppk Differences and Questions Capability, Accuracy and Stability - Processes, Machines, etc. 5
E Cpk and Ppk template wanted Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q ASQ CSSBB Question on Cpk and PPk , can you solve it ? Capability, Accuracy and Stability - Processes, Machines, etc. 15
M Calculation of Cpk and Ppk for an unstable process Statistical Analysis Tools, Techniques and SPC 7
Q PPK, CPK of >= 1.67 Automotive Requirement and Auditing IATF 16949 - Automotive Quality Systems Standard 1
P Individual & MR chart - Ppk or Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 9
K Normality of distribution prior to Cpk and PpK Statistical Analysis Tools, Techniques and SPC 4
R Can Ppk value be greater than Cpk and if yes, under what conditions? Statistical Analysis Tools, Techniques and SPC 10
C Is it possible to get Pp,Ppk more than the within subgroup (Cp,Cpk's) indices? Statistical Analysis Tools, Techniques and SPC 7
S Are Pp and Ppk more useful than Cp and Cpk as a benchmark for further studies? Statistical Analysis Tools, Techniques and SPC 1
J Using Pin Gages as a Measurement Tool for Ppk/Cpk studies Capability, Accuracy and Stability - Processes, Machines, etc. 11
B Difference between Ppk (Preliminary), Cpk, Performance Capability Statistical Analysis Tools, Techniques and SPC 2
D Real life example of the difference between Cpk and Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 0
N Cpk vs Ppk - Which should you use and How to Calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 25
V Quality Control Index - We thought that Cpk or Ppk would be good choices Capability, Accuracy and Stability - Processes, Machines, etc. 6
Tim Folkerts Interpreting the common capability indices: Cp, Cpk, Pk, and Ppk. The Reading Room 5
J Machine issue in Cpk/Ppk and Control Plan - PPAP Submissions APQP and PPAP 5
D Use of an outlier in calculating Cpk/Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 8
N Analysis of non-normal stratified data for cpk/ppk? Rupture test Capability, Accuracy and Stability - Processes, Machines, etc. 6
F Ppk/Cpk value with 1-sided specification - Only given a lower specification Statistical Analysis Tools, Techniques and SPC 1
S Ppk/Cpk for geometrical true position of hole with MMC Capability, Accuracy and Stability - Processes, Machines, etc. 17
Howard Atkins Validation of Cpk and Ppk calculations - Sheet to check Cpk and Ppk values Statistical Analysis Tools, Techniques and SPC 4
S What is the meaning of "k" in Cpk and Ppk? And Cpk vs. Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 15
A Capability Indexes for ISO/TS16949 - Cpk & Ppk after PPAP Statistical Analysis Tools, Techniques and SPC 6
