PPAP 7 of 8 Cavities after an injection mold die repair?
V
vardar3
Our plastics supplier has an injection mold die that has 8 cavities. They closed off cavity 7 to send it out to repair due to some flash that was occurring. The problem is that they need to PPAP to us, and we need to PPAP to our customer.
Our sales guy mentioned that we can PPAP approve the supplier for 7 of 8 of their cavities. I did not like that idea because running 7 of 8 cavities is not representative of the process, and by signing the PPAP I would be saying that their tool, process and parts meet design intent, which is not true.
I wanted to ask if you guys have been through any PPAP cavity issues similar to this and see how you handled it. Can I PPAP 7 of eight cavities or could that lead to some major problems down the road?
Re: PPAP 7 of 8 cavities???
Our plastics supplier has an extrusion mold die that has 8 cavities. They closed off cavity 7 to send it out to repair due to some flash that was occurring. The problem is that they need to PPAP to us, and we need to PPAP to our customer.
This sort of thing isn't uncommon, although most frequently it comes up when cavities are added. If you have good reason to believe that closing one cavity will have a negative effect on the other seven, you should wait until all eight are functioning, if waiting is an option.
On the other hand, you can consider interim approval for the seven cavities, and then resubmission and full approval only after all eight are running.
DrM2u
Re: PPAP 7 of 8 Cavities after an extrusion mold die repair?
To add to Jim's reply:
This is a touch situation and depends no how you look at the tool and at the product. I have been in situations where the customer looked at each cavity individually as a 'tool', or looked at the whole mold as a tool regardless if there were 1 or 8 cavities. In general the second approach is most common. One of it's drawbacks is that you can have an instance where 3 cavities are targeted high, 3 targeted low and 2 targeted in middle of the tolerance range. In such a case your distribution and process capability will look horible, even if each cavity in part might have a very high process capability.
My suggestion is to talk with your customer also, if they are going to see the PPAP data. Otherwise, you can PPAP the whole tool with 7 cavities, taking in consideration the capability of each cavity in part and the mold overall. You can do another full PPAP when the 8th cavity is fixed, or just add the capability of the 8th cavity to the existing PPAP data, depending on how much tool wear you expect on the other cavities up to the new PPAP. The main point is for you to build a high degree of confidence that the parts you receive and ship to your customer meet customer's requirements. How you do that, is your decision. Best wishes!
The chances are that the customer owns the tooling and is aware of the number of cavities. Adding a cavity after PPAP approval triggers a requirement for notification to the customer, and the customer will decide whether a new PPAP is required.
You mentioned that this was an extrusion die. Typically, blocking a die opening will affect the flow in the other dies, thus dimensions also. Did you really mean an injection mold?
V
vardar3
yes, I did mean injection mold die thank you.
Golfman25
You might be making more out of this than there really is. I would PPAP it as is -- 7 cavities. That is the current process. When and if the 8th cavity is repaired or replaced, then I would re-PPAP as a tool and/or process change. Your molder will need to adjust the process to account for the 7 vs. 8 cavities. The re-PPAP would reflect the new process. Good luck.
K Documentation of Dimensional Results for Different Cavities and/or Molds - PPAP APQP and PPAP 12
J Supplier not responding to PPAP request APQP and PPAP 5
J Part submission warrant for Level 1 PPAP APQP and PPAP 1
B Toyota PPAP Process - Three Questions APQP and PPAP 3
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
F How to submit a PPAP when a subcontractor is the sole manufacturer IATF 16949 - Automotive Quality Systems Standard 2
P PPAP samples retention time IATF 16949 - Automotive Quality Systems Standard 5
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
E Annual PPAP+ deviation request ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K OEM specific requirements - PPAP was rejected by STA Customer and Company Specific Requirements 5
T PPAP for distributors? APQP and PPAP 1
A PPAP for Fire extinguisher APQP and PPAP 2
S PPAP Progress - Visual Status Board APQP and PPAP 0
C AS9145 Appendix D PPAP Approval Form APQP and PPAP 2
Pau Calvo PPAP customer requirements in the APQP APQP and PPAP 25
V 3 PQ lots mentioned as requirement in PPAP. Is this necessary? APQP and PPAP 2
B What is the role of Quality Engineer in APQP and PPAP APQP and PPAP 3
F How to submit PPAP without IMDS APQP and PPAP 10
GreatNate Excel PPAP Tracking templates or tool wanted APQP and PPAP 1
M Where can I find examples of PPAP? APQP and PPAP 6
R Process Specification - What is the name of this PPAP form? APQP and PPAP 15
I PPAP Assembly and Components Manufacturing and Related Processes 3
F PPAP Documentation Control APQP and PPAP 8
K PPAP Phases Vs PPAP Levels APQP and PPAP 2
R Plan to Volvo Cars for capacity verification in Phase 3 of PPAP Customer and Company Specific Requirements 3
G Job interview - So I have to do a presentation on PPAP APQP and PPAP 16
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
M Level 3 PPAP submission of intentional defective parts APQP and PPAP 4
L Reasons to submit a new PPAP or notify the customer APQP and PPAP 3
eule del ayre List of Level 3 PPAP requirements for automotive suppliers APQP and PPAP 20
A New Supplier implementation - PPAP vs APQP APQP and PPAP 9
E Nissan (Renault) PPAP Acronyms (DNote , KFD, IR) APQP and PPAP 2
N How to deal with catalog parts suppliers who refuse to submit PPAP documents? APQP and PPAP 0
N PPAP material certificate date IATF 16949 - Automotive Quality Systems Standard 4
P Paint shop vs PPAP requirements IATF 16949 - Automotive Quality Systems Standard 5
N How to resolve discrepancies in Level 3 PPAP supplier dimensional reports? APQP and PPAP 11
Sidney Vianna AS9100 News PPAP in the Aerospace Sector - What is it? AS9145 - Requirements for Advanced Product Quality Planning and Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
D PPAP a Rebranded Purchased Product (we don't manufacture) IATF 16949 - Automotive Quality Systems Standard 6
E Solder thermal profiles for PPAP - Automotive IATF 16949 - Automotive Quality Systems Standard 1
P Automotive Customer asking PPAP for catalogue parts IATF 16949 - Automotive Quality Systems Standard 16
V PPAP documentation - Submission required in English APQP and PPAP 3
H Informational What is PPAP (Production Part Approval Process)? APQP and PPAP 26
J What level PPAP for 5 critical parts? APQP and PPAP 8
S PPAP Levels compared to Interim Class APQP and PPAP 1
E PPAP Workbook 4th APQP and PPAP 3
N Can you use parts from Run at Rate to use in your PPAP? APQP and PPAP 4
N Who shall manage PPAP process? APQP and PPAP 4
kedarg6500 APQP & PPAP for Process Industry - Concept for Waste to Energy Program APQP and PPAP 0
