PPAP and Part Sample Warrant (PSW) Requirements if a Machine is Moved
L
Laura M
Can the SQE in the next division/company say if you move it 2 feet you need to re-PPAP? Not sure, but I don't see the significance between 10 and 50. I've heard others state that if the PFD or PCP doesn't change, don't submit at all. And then an auditor will want to see a waiver!! Yikes!
When we moved 150 injection mold machines we showed the customer our re-PPAP plan. Basically the first mold run in the machine received a full PPAP. After that, other molds got "mini-qual's" basically verifying that the parameters previously used were still good. Kept a matrix and it "forced" us to do a better job at scheduling because we would only run certain molds in certain machines. Not easy (and production didn't like it)...but if you are of the mind to reduce variation, then its a good thing. I think "family" PPAP's were submitted with a copy of the matrix. I can understand wanting to verify no impact on the part..and our SQE had alot of common sense..so he worked with us to make it an affordable plan. Good luck.
Howard Atkins
Forum Administrator
The 3rd edition PPAP handbook seems to solve this problem.
I.3.3 situations where customer notification is not required.
Table I.3.3
2. Tool movement within the same plant (used in equivalent equipment....
3. Changes in equipment (same process flow.....
This appears to give the OK to move from one machine to another.
Mark Ashley
According AIAG, 3rd Edition, PPAP manual, resubmission is not required when moving a process/machine within the same building nor are you required to contact the customer.
Page 14, Table 1.3.3
V.Muthuraman
Reported Post by V.Muthuraman
Hi Friends,
My whole plant going to moved from existing location other location (New Plant) just 30 KM way, in this condition my customer asking to submit the PPAP as per 4th Edition. The location change going to take place another 4 months times,
My doubt is should i submit PPAP now or after changing the location.
Because my customer requested to submit PPAP for all product supplying to him currently.
Howard Atkins
Forum Administrator
Re: PPAP and Part Sample Warrant (PSW) if a machine is moved
You can only make PPAP parts when you have moved as this is the reason for resubmitting.
Re: Reported Post by V.Muthuraman
Hi Friends,
If you are supplying new salable parts to your customer from your present location, you'll have to do a PPAP submission, and then resubmit when you've moved and started production in the new location.
_steph_
For my answer, I'll presume that you have already an approved PSW.
In theory, you just have to make another PPAP. For plant moving, i'm used to ask a level 5 PSW submission.
You can do like this if you use SPC.
So you have your actual Cpk.
If you don't monitor you capability I would suggest to make a Capability trial, compute your Cm/Cmk and do the same after moving. If you have the same results you will be able to show to your customer that your old process in your new plant doesn't know deviation.
In the other case you should be able to identify the deviation and study it more precisely.
Remember to produce enought part in your security stock to cover the PPAP study and PSW approval ...
blue_cove
In the same mood there was a previous discussion on whether you need to PPAP each different machine that you run the injection on. Here again he agreed that this was a grey area but his feeling was that if you change machine if you do not re PPAP then how do you know that the product is the same.
It is an old post, but for a very interesting issue. How should we deal that kind of situation ?
If the company can produce the same part on several machines, whether such a company should prepare PPAP for each of the machines?
Frankly I have my doubts, but in this case, my inclination is that the PPAP should be prepared for each machine. How do we make sure that the parts are the same from every machine and meet the requirements of the customer?
I think a good solution would be to prepare the basic PPAP (level 3) at loud machine in the case of other machinery PPAP will be limited only to the dimensional report, MSA, SPC and PSW.
What do you think about this issue? What are your experiences on this?
I’m look forward to any suggestions and information from you.
Chennaiite
Never-say-die
If a Company *does* produce same part on several machines, say, in order to meet the Customer Volume requirements, one PPAP submission can be good enough, provided appropriate activities are done and relevant output documents are submitted. Ex. Inspection reports for each machine, Capability Study results for each machine, etc.
If a company *can* produce same part on several machines, say, in case of Maintenance, Breakdown, etc. and if i were the Customer, I wouldnt ask for the results from each machine during Initial PPAP submission. But I would ensure that the Control plan includes adequate controls during Process changeover.
Much depends on the complexity of the Manufacturing Process as well. Like, Heat Treatment and Pre-Machining process wouldnt be measured on the same scale.
sitapaty
We are planning to move several molding machines from one side of the plant to the other side of the plant and the question of "do we need to re-submit for PSW approval has
come up. The PPAP manual requires that we
contact our "Part approval Authority" and if they do not require a PSW we would need a part number specific waiver.
OK that's easy, now the problem is that we have never PSW'd to a specific machine only to a specific tonnage of machine and the result is that we have almost 500 part numbers that would require a specific waiver.
And we all know the "The Customer" is not going to issue 500 waivers for this.
So how can we meet the intent of the standard without killing ourselves in the process ??
Thanks in advance
Bill Smith
In the circumstances you have mentioned ,not only you have to submit new psw also you have to apply for a new certification audit.
-sitapaty
O PPAP'ed part manufacturer has discontinued production Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 7
abrego44 AIAG PPAP manual for service part APQP and PPAP 5
J Part submission warrant for Level 1 PPAP APQP and PPAP 1
Sidney Vianna AS9100 News PPAP in the Aerospace Sector - What is it? AS9145 - Requirements for Advanced Product Quality Planning and Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
H Informational What is PPAP (Production Part Approval Process)? APQP and PPAP 26
S Looking for a PPAP PSW, Part Submission Warrant, in Chinese APQP and PPAP 5
P Customer wants a Part Material Change - New PPAP required? APQP and PPAP 3
K FAI (First Article Inspection) vs PPAP (Production Part Approval Process) APQP and PPAP 16
C Is there age of part requirement for PPAP? APQP and PPAP 4
J PPAP for New Family Revisions when the Part has not changed APQP and PPAP 4
H PPAP for a US$2 Part Purchased from a local Distributor APQP and PPAP 3
M PPAP requirements when adding Part Transfer Robots between Machines APQP and PPAP 1
T Variable Dimensions / Part of Production / PPAP Dimensional Report Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Quality Standard as part of our version of PPAP - Suggestions APQP and PPAP 1
J PPAP (Production Part Approval Process) Requirements for Annual Revalidations APQP and PPAP 1
Fender1 PPAP-PSW Accuracy Concern - Laser Cut Holes In Formed Fabricated Steel Part APQP and PPAP 15
T Who signs PSW's? (PPAP Part Submission Warrants) APQP and PPAP 1
Q Feasibility of PPAP for Part Qualification in Medical Devices APQP and PPAP 2
M PPAP (Production Part Approval Process) files for Ford APQP and PPAP 11
B Help with Submitting Part Layout Dimensionals - My first ever PPAP (to GM) APQP and PPAP 5
A Plastic Parts Mass - Plastic part weight to be +/- 0.5% from PPAP parts APQP and PPAP 14
automoto PPAP Forms - Part Submission (Warrant) form .xls Document Control Systems, Procedures, Forms and Templates 2
5 Thousands of part numbers and various items - PPAP questions APQP and PPAP 9
A What is PPAP (Production Part Approval Process) Why submit it and/with PSW APQP and PPAP 2
P PPAP Approval - Customer approval of PSW (part submission warrant) APQP and PPAP 5
B Help for beginner - PPAP (Production Part Approval Process) APQP and PPAP 9
I Confused on PPAP re-submission - Help on PSW (Part Submission Warrant) APQP and PPAP 3
R Is Kappa Study Required during PPAP (Production Part Approval Process)? IATF 16949 - Automotive Quality Systems Standard 9
T Production Part Approval Process (PPAP) Presentation in ppt. format APQP and PPAP 3
F Who should Sign Supplier PPAP (Production Part Approval Process) documents? APQP and PPAP 13
H Who can require PPAP (Production Part Approval Process)? APQP and PPAP 7
S Tell Me All About PPAP (Production Part Approval Process) APQP and PPAP 7
L PPAP Part Supplied to Multiple Plants - Submit another PPAP or PSW to the new plants? APQP and PPAP 6
J What PPAP level would you use for a part provided by a distributor? APQP and PPAP 7
B Quality Stand Down form - Part of a PPAP submission to Johnson Controls Document Control Systems, Procedures, Forms and Templates 12
B New PSW (Part Submission Warrant) - 4th Edition PPAP Manual APQP and PPAP 38
G Customer part number for PPAP - Chain of distributors involved - Catalogue items, too APQP and PPAP 6
D Seeking CURRENT PPAP Part Submission Warrant APQP and PPAP 7
B Question about "When PPAP is required" - Tier 2 to GM - Fabric Density on Part APQP and PPAP 24
C New PPAP submission required when changing part number? APQP and PPAP 11
J AIAG PPAP (Production Part Approval Process) Manual Fourth Edition Released APQP and PPAP 69
A PPAP (Production Part Approval Process) - Where can I buy the AIAG Manual? Preventive Action and Continuous Improvement 2
J PPAP (Production Part Approval Process) Submission Level Differences - Forms attached APQP and PPAP 17
S Students trying find information on Producation Part Approval Process - ABC of PPAP APQP and PPAP 2
C Part Families and Single PFMEA - Can this be considered a part-family for PPAP? APQP and PPAP 1
N Is [email protected] part of PPAP? APQP and PPAP 1
W PPAP (Production Part Approval Process) - Clarify When submission is required APQP and PPAP 10
B PPAP Applicability - 10,000 Part Numbers - Control Plans for ALL part numbers? APQP and PPAP 18
B PPAP and the need to re-submit - Engineering change to a single component part QS-9000 - American Automotive Manufacturers Standard 1
A Can a customer send a claim during PPAP? IATF 16949 - Automotive Quality Systems Standard 11
