PPAP customer requirements in the APQP
Pau Calvo
#11
No, none of our customers ask for them and neither us ask them to the toolmaker.
This shocked me when I started on this company, in my previous job on a plastic injection molding company, was a requeriment from all customer and also from us.
I guess that for the aluminium injection it is not that critical...
#12
As we continue to peel back the layers, is your tooling made by an external source? If so, are you saying that you don't require dimensional reports (and your own confirmation of same) as a condition of tooling approval (and payment)?
Pau Calvo
#13
Yes, is outsorced and ofcourse that we made validation of the parts on the trials to ensure the quality and validate the tool but this is internal procedure.
I understand your point, but customer is making requeriments from thin air. If they need FoT dimensional reports for validation should be agreed before hand.
#14
As far as I have been informed, this requeriment was not in the purchase order, anyway customer did not send any global schedule for the project.
We, as standard, only include dimensional reports for the PPAP samples in the offer of the project. Further dimensional reports have to ordered outside the main order of the project. We proceed that way to avoid that our customer could keep asking for dimensional reports and overrun our metrological department.
Whomever it is that's responsible for the APQP process and submission of the PPAP should be well-acquainted with the purchase order and the customer requirements. You say that as far as you've been informed there is no requirement, which seems to mean that you're not sure. I'm sympathetic to the idea of not letting customers ask for things that weren't contractually agreed to, especially if those things weren't accounted for in pricing. The problem is that you indicate that the tooling qualification data is available and no additional expense will be incurred, so I don't know why you don't just give it to them. Presumably the tooling belongs to the customer, so it doesn't seem to be an unreasonable request. I know it might not be a part of a standard PPAP submission, and the customer should be specifying submission of the data before PPAP submission, but it should be enough now to (a) review the purchase order yourself and see what's there, and (b) if there is no mention of or reference to requirements to submit tooling qualification data, inform the customer of that fact and that in the future you will only be beholden to contractual requirements. In the meantime though, you should just give it to them.
Golfman25
#15
I am going to disagree. First off tooling dimensional reports are a standard requirement for any good supplier/customer relationship. It sets the standard so if there is an issue down the line everyone at least knows where they started. The supplier is basically saying -- "this is what we got, if it's good we are good to go."
toniriazor
#16
Hello all
In regards to FORD Customer Specific Requirement clause 8.6.2:
8.6.2 Layout inspection and functional testing
The organization shall perform annually a layout inspection (to all dimensional
requirements) on at least 5 parts.
Where tooling has multiple cavities, tools or centers, the organization conducts the
annual layout on at least one part from each cavity, tool or center, with a minimum
overall sample of 5 parts.
Note: 5 parts are not required from each cavity; tool or center, only a minimum of 1 part
is required from each cavity, tool or center.
The measurements are to be documented on the APQP/PPAP Evidence Workbook
(Prototype or Production Measurement Results section), available through
Home Realm Discovery ."
does this mean we as Tier 1 manufacturing plant of wiring harnesses EDS commodity need to perform end of each year 5 dimensional reports on a wire harness we choose or we cover this requirement with the 100% measurement of each wire harness in the beginning of the shift and when there is a part number change during actual production run?
I believe what we have in the process now covers the clause 8.6.2 because 100% measurement of a wire harness is performed more than 5 times annually in fact dimensional measurement it is performed each day but on the other hand the clause might be interpreted as a way to perform something like annual manufacturing process re-validation or at least our STA (supplier technical assistant) once insisted on that and explained it like that as far as I remember
What is your opinion and what exactly is the correct way to go ?
Thank you all for valuable input.
#17
With annual layouts, you're expected to perform and submit dimensional reports for each each assembly just as it was submitted in the original PPAP.
toniriazor
#18
and when is the right time to make the annual layouts ? at end of the year or is better after another event (big design change, process change, material change and etc) since the risk to have deviation in process is higher after such events ? also would it be OK to take the data which has already been collected throughout the last few months and put in a dimensional report form ?
#19
Unless you want to have a large backlog at the end of the year, I would space them out throughout the year and fit them in around hectic times. You can start by scheduling them approximately a year after the PPAP was submitted or approved. Don't paint yourself into a corner in your procedure either. Allow some flexibility in the schedule and consider vacations, holidays, etc. If you have scheduled downtime in the plant during parts of the year, you might consider using that time.
#20
In general, the annual-layout requirement clock starts ticking when the PPAP is approved. Also generally, it's expected that there will be 12 months between layout submissions. The requirements can vary widely among individual customers, so it's best to find out what's expected and not guess.
Y Customer Specific PPAP Level 3/4 Requirements - Fastener Manufacturer APQP and PPAP 2
S Can PPAP be submitted when not all customer requirements can be met? APQP and PPAP 5
H Requirements in TS for PPAP - Full PPAP or as per Customer Requirement? IATF 16949 - Automotive Quality Systems Standard 14
M DaimlerChrysler (DCX) Customer Specific Requirements for PPAP 4th Edition Customer and Company Specific Requirements 8
Sidney Vianna Chrysler Customer Specific Requirements For PPAP 4th Edition IATF 16949 - Automotive Quality Systems Standard 10
antoine.dias Customer Specific Requirements and PPAP submissions APQP and PPAP 13
C PPAP required by Customer not the same as the AIAG's PPAP Manual Requirements APQP and PPAP 2
L Reasons to submit a new PPAP or notify the customer APQP and PPAP 3
P Automotive Customer asking PPAP for catalogue parts IATF 16949 - Automotive Quality Systems Standard 16
P Customer wants a Part Material Change - New PPAP required? APQP and PPAP 3
G Customer wants PPAP on Old Parts to New Standards APQP and PPAP 8
N Customer wants a PPAP/PSW on some Prototype Parts APQP and PPAP 6
B Should I Request/Submit a PPAP from/to a Supplier/Customer for only Repackaging Parts APQP and PPAP 7
T PPAP - Complaint from a Tier One customer concerning Product Dimension IATF 16949 - Automotive Quality Systems Standard 26
T Customer requires Internal Specification to be met on PPAP APQP and PPAP 7
J Customer Complaint - PPAP - Issues not called out on the print APQP and PPAP 3
V Submitting Supplier Information in Customer PPAP APQP and PPAP 2
Stijloor GM (Supplier) and PPAP Requirement 3.1 Customer Notification APQP and PPAP 5
C AS9100 Customer requiring PPAP APQP and PPAP 3
W PPAP MSA for each new customer IATF 16949 - Automotive Quality Systems Standard 9
S Guidance to prepare and submit a Level 3 PPAP to a Customer APQP and PPAP 6
V PPAP to Customer with Deviation Request APQP and PPAP 4
K Looking for Ideas to Track Customer Requests and PPAP Data Packages APQP and PPAP 4
J Customer PPAP Approvals - Internal PPAP Possible? APQP and PPAP 7
V We put Old plating spec on supplier prints and need to PPAP to Customer. APQP and PPAP 1
V Can't PPAP to Customer because a Supplier was Re-Sourced APQP and PPAP 2
R Customer using their own version of the AIAG PPAP Forms APQP and PPAP 5
E PPAP PSW Approval: Customer Drawing or Supplier Drawing APQP and PPAP 4
I Repair and Service Facility - Customer wants PPAP for Refurbished Equipment APQP and PPAP 3
P ISIR vs. PPAP - Customer is requesting an ISIR Cover Sheet according VDA Quality Manager and Management Related Issues 5
M PPAP including FAI Parts - Customer is requiring 5000 measurements APQP and PPAP 15
B Cost for PPAP - Customer pays for samples and PPAP documentation from supplier APQP and PPAP 8
D Outsourced Material - Customer who is asking us for a level 3 PPAP APQP and PPAP 8
S PPAP for VW QPN - PPAP documentation for Volkswagon customer APQP and PPAP 4
S Customer PPAP notification and submission for a Change APQP and PPAP 2
P PPAP Approval - Customer approval of PSW (part submission warrant) APQP and PPAP 5
H How to refuse PPAP submission to a customer? APQP and PPAP 7
P PPAP submission for a new customer of an existing product APQP and PPAP 7
M PPAP Review Updated yearly but not send to Customer - Is it Right? APQP and PPAP 12
M How can I say no to a customer PPAP request APQP and PPAP 14
D Level 3 PPAP for Customer - We are outsourcing the processing FMEA and Control Plans 6
R PPAP customer notification - what do you think? APQP and PPAP 12
5 PPAP Request from our Customer for an Assembly we Purchase APQP and PPAP 9
S Supplier requesting Customer PPAP submission APQP and PPAP 5
kedarg6500 PPAP for Continuous Process like Copper Wire Enameling but SWG differs per customer APQP and PPAP 3
M Customer Notification Rules under PPAP 3.1 APQP and PPAP 2
K PPAP per QS-9000, rev.4 - Customer rejected our normal PPAP APQP and PPAP 3
R Engineering changes for customer notification - PPAP Submission APQP and PPAP 5
S PPAP on Prototype tooling? Producing components for internal customer (assembly) APQP and PPAP 5
C Notice Received from Customer Regarding PPAP's & FAIR's APQP and PPAP 8
